Recommended Dry Lubes
Old 05-23-21, 09:31 AM
  #76
eduskator
eduskator's Avatar
Bikes: TCR Pro 0 / Revolt 2
Quoted: 446 Post(s)
Liked 259 Times in 196 Posts
Originally Posted by Doomrider74 View Post
That's what I'm using at the moment. Its far from quiet, IME.
Exactly how much do you put on your links? What's your relubrication intervals? I did mine every 100kms with the regular and every 150-200 now with the C3 and I don't ''hear'' the chain at all.
eduskator is offline
Old 05-23-21, 09:35 AM
  #77
Doomrider74
Quoted: 130 Post(s)
Liked 93 Times in 51 Posts
I dont touch the C3 as it turns the chain into a black, sticky mess. I use the dry. Yesterday, I applied it liberally, let it dry, and went for a ride: it lasted about 1.5 hours before the chain started to squeak.
Doomrider74 is offline
Old 05-23-21, 09:39 AM
  #78
eduskator
eduskator's Avatar
Quoted: 446 Post(s)
Indeed... I wipe mine off after every ride to avoid this and to make sure it stays clean. There's a lot of excess lube leaking out of the rollers for sure.
1.5 hours? That's really weird.
Old 05-24-21, 06:59 PM
  #79
WorldIRC
Canadian eh?
Bikes: 2021 BMC Roadmachine 01 THREE
Quoted: 126 Post(s)
Liked 81 Times in 45 Posts
I may have dried off too much of the Absolute Dry lube I applied a bit more (it wasn't sopping wet this time) and am letting it dry properly. Will take for another ride tomorrow!
WorldIRC is offline
Old 05-24-21, 10:02 PM
  #80
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 987 Post(s)
Liked 629 Times in 438 Posts
First ride this morning with my Absolute Dry. Definitely noisier than my MucOff. Will give it more time.
2cam16 is offline
Old 05-27-21, 02:07 AM
  #81
canklecat
canklecat's Avatar
Quoted: 4185 Post(s)
Liked 2,089 Times in 1,337 Posts
If you want quiet, stick with wet oil lubes. Paraffin/wax, PTFE, moly and other dry/dry-ish lubes I've tried all sound a bit clinky within a few miles. In this case noise doesn't seem to translate to increased friction, per Friction Facts tests. Rock 'n' Roll Gold seems to be the compromise, adding a bit of light oil to the PTFE in naphtha carrier/solvent.
A GCN video a couplafew years ago basically said the same thing.
canklecat is offline
Old 06-13-21, 08:03 PM
  #82
WorldIRC
Canadian eh?
Quoted: 126 Post(s)
Been a few weeks and the Absolutely Dry is definitely not quiet. Clean… but not quiet.
WorldIRC is offline
Likes For WorldIRC:
Old 06-14-21, 04:06 AM
  #83
PeteHski
PeteHski's Avatar
Quoted: 499 Post(s)
Liked 461 Times in 308 Posts
I can’t imagine ever going back to an oil based chain lube. Without exception you soon end up with a black grinding paste, which is the last thing your chain needs for longevity.
My latest experiment with Silca SS is going really well. The chain is so clean that it’s hard to tell if there is any lube on there at all. The drivetrain runs quietly too. I haven’t done enough mileage on it to check on chain wear, but the tests Zerofriction did were very encouraging.
I’m still using up the last of my Squirt on my Mtb and that is definitely more sticky on application and doesn’t seem to get inside the links so readily.
PeteHski is online now
Old 06-14-21, 01:33 PM
  #84
Greatestalltime
Greatestalltime's Avatar
Bikes: Tcr advanced sl & Protos
Quoted: 103 Post(s)
Liked 42 Times in 26 Posts
Squirt
Greatestalltime is offline
Old 06-15-21, 02:17 AM
  #85
Brambo
Liked 6 Times in 2 Posts
My experience with the Muc-Off C3 Dry has been mostly good. Lasting pretty good. Chain gets a bit dirty, but I just wipe it down and reapply.
The big downside is that when it starts raining, the lube washes away pretty quickly and the chain makes a terrible grinding noise over the chainrings.
Brambo is offline
Old 06-15-21, 07:50 AM
  #86
Chandne
Bikes: 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Yeti SB4.5, Pivot Shuttle
Quoted: 315 Post(s)
Liked 40 Times in 25 Posts
I keep trying others- Prolink, Dumonde Tech, Dumonde Tech Lite, WD-40 chianlube, Squirt, White Lghtning, and so many others. I keep coming back to the Rock N Roll Lube line...usually the Gold or Extreme. They keep the drivetrain the quietest and cleanest.
Chandne is offline
Old 06-15-21, 12:58 PM
  #87
tankist
Quoted: 54 Post(s)
Liked 46 Times in 27 Posts
Tried many dry and wax lubes. Too much work and results are not that good IMHO. Then tried Chain-L and liked it the best. Quiet, chain shifts well, apply once in about 3 weeks. Disclaimer - I do wipe the chain after each ride to keep it clean.
tankist is offline
Old 06-15-21, 05:59 PM
  #88
2cam16
2cam16's Avatar
Quoted: 987 Post(s)
I gave mine away to my brother. lol I'm sticking to my MucOff Ceramic.
2cam16 is offline
Likes For 2cam16:
Old 06-15-21, 10:00 PM
  #89
NoWhammies
NoWhammies's Avatar
Quoted: 668 Post(s)
Liked 303 Times in 199 Posts
Gotta say, I'm a Rock N Roll convert. I have been giving a go a various lubes, landing most recently on RnR Gold. So far, after a couple of rides I am impressed. Drivetrain is keeping clean and quiet. I think I've found my lube of choice.
NoWhammies is offline
Old 06-16-21, 10:41 AM
  #90
WorldIRC
Canadian eh?
Quoted: 126 Post(s)
I've ordered some RnR Gold based on further recommendations here.
WorldIRC is offline
Old 06-18-21, 07:20 PM
  #91
NoWhammies
NoWhammies's Avatar
Quoted: 668 Post(s)
WorldIRC That's pretty much what convinced me to give it a try.
Old 06-18-21, 07:48 PM
  #92
popeye
Bikes: S works Tarmac, Felt TK2 track
Quoted: 308 Post(s)
Liked 105 Times in 75 Posts
I refill that from the big bottle.
popeye is offline
Likes For popeye:
Old 06-18-21, 08:12 PM
  #93
WorldIRC
Canadian eh?
Quoted: 126 Post(s)
Just got it today. Will apply and test tomorrow.
WorldIRC is offline
Old 06-19-21, 08:28 AM
  #94
noodle soup
noodle soup's Avatar
Quoted: 4670 Post(s)
Liked 1,804 Times in 977 Posts
+1
1 big bottle per year.
noodle soup is offline
Old 06-19-21, 11:28 AM
  #95
WorldIRC
Canadian eh?
Quoted: 126 Post(s)
Just applied the Gold. Definitely "wetter" than the absolute dry. Will give it the night to dry and test run it tomorrow.
WorldIRC is offline
Likes For WorldIRC:
Old 06-20-21, 10:31 AM
  #96
WorldIRC
Canadian eh?
Quoted: 126 Post(s)
Drivetrain “sounds” amazing now with the Gold lube applied and dried.
And a shout out to Bettershifting.com for their amazing guides!
WorldIRC is offline
Likes For WorldIRC:
Old 06-23-21, 05:00 PM
  #97
WorldIRC
Canadian eh?
Quoted: 126 Post(s)
So far so good. Been several days, including a dirty gravel ride. Lots of dirt caked onto the frame and tires but the drivetrain remains quite clean. Nothing more than a quick wipe with a rag.
WorldIRC is offline
Likes For WorldIRC:
Old 06-24-21, 02:17 AM
  #98
canklecat
canklecat's Avatar
I've mostly been using R'n'R Gold on my road bikes for the past year. No problems. I used Absolute Dry for about a year before that. Gold seems to have a tiny bit of oil of some kind, in addition to the PTFE and naphtha. It's a bit quieter and doesn't pick up much gunk. I apply about a dozen droplets, using a needle dropper, every ride or so, randomly distributed. So far, so good.
Old 06-24-21, 08:05 AM
  #99
Chandne
Quoted: 315 Post(s)
As we get closer to winter or if I know there is a chance of quick storms in the mountains, I use the Extreme version (blue in color). It holds on to the chain better when wet. I also use it on my mountain bike in the Fall/Winter. Between those two, I have never found a better lube though I suspect waxing chains is excellent. I just can't do all that chain disassembly, cleanup, soaking in a crockpot, etc.
Chandne is offline
Old 06-25-21, 03:46 PM
  #100
DaveSSS
Bikes: TWO Cinelli superstar disc with SRAM Force AXS
Quoted: 683 Post(s)
Liked 315 Times in 253 Posts
I've been using my own home brew paraffin based lube for almost 3 years now. 1 part paraffin with 20-30% gear lube, dissolved in 4-6 parts naphtha or camp stove fuel. I relube about every 150 miles. It's a very clean lube that does not attract dirt, but it does need to be warmed in hot tap water to restore its water like viscosity.
DaveSSS is offline
