Pedal Assist Stops
Pedal Assist Stops
Old 05-13-21, 12:57 PM
LennyG
Pedal Assist Stops
MAY 13, 2021
This is a TREK 1100 modification with a front 500w drive.
PROBLEM: Pedal assist works correctly at first. If I stop pedaling, then start again, the assist goes away completely.
The only way to get assist back is to shut the display off, then back on. I have even tried resetting to defaults and re-programming.
This is VERY dangerous when riding in traffic.
Maybe someone has dealt with this before?
Here are my KT-LCD3 SETTINGS
P1=100, P2=1, P3=0,P4=0, P5=15
C1=6, C2=0, C3=0, C4=0, C5=10, C6=3, C7=0
C8=0, C9=0, C10=n, C12=4, C13=0, C14=2
LennyG is offline
Old 05-13-21, 01:22 PM
Rick
Quoted: 285 Post(s)
Liked 139 Times in 90 Posts
Send picture of sensor position. Try adjusting sensor position.
Rick is offline
Old 05-13-21, 02:12 PM
LennyG
Ped sensor
The PED sensor is a KT-V12L, self contained, no external magnets.
LennyG is offline
Old 05-13-21, 06:43 PM
Rick
Quoted: 285 Post(s)
[QUOTE]Spin the crank backwards and see if the inner part of the sensor that makes contact with the spindle is not slipping. If it is slipping then you need to glue it to the spindle somehow.
Rick is offline
Old 05-14-21, 09:48 AM
Doc_Wui
Doc_Wui's Avatar
Quoted: 277 Post(s)
Liked 104 Times in 77 Posts
Did you install the throttle? What happens if you blip the throttle, does the controller wake up again?
I have kind of seen this intermittently on a 22A KT controller, but it's more like PAS takes an extra half rotation to start. I ride several ebikes, and it's so rare I cannot recall which bike has it. I'd replace the controller in your case.
Doc_Wui is offline
