Road Bike and Gear Choice Advice.
Old 06-04-21, 10:08 PM
Epika
Quoted: 5 Post(s)
Hi. I want to buy a Road bike. But i don't know which gears i must to select. Is there any advice to low price road bikes and gear options?
Epika is offline
Old 06-04-21, 10:22 PM
big john
big john's Avatar
Quoted: 2951 Post(s)
Liked 2,291 Times in 1,255 Posts
We don't know how much you want to spend or what is even available where you are. Do you have good roads or do you need a bike that can be ridden in dirt sometimes? Do you need to climb hills? If you're not climbing hills any geared bike will work.
If you've never had a road bike you should get a less expensive one to start on. Just make sure it's the right size for your body.
big john is offline
Likes For big john:
Old 06-04-21, 10:30 PM
Epika
Quoted: 5 Post(s)
In my country we don't use dolar so i cant explain how much can i spend for bike. But i can say i want a entry-mid bikes. In our country, we have good and bad roads in same times. But i want to go long ways so i gonna use the good ways. This why im want to buy road bike. But i dont know the gear things. I search some videos and i saw " Gear Rate". I dont even know what it is, and how i can select the true gear rates (btw thx for the help )
Epika is offline
Old 06-05-21, 02:42 AM
cubewheels
Bikes: A really old BMX bike, Phantom 20 kid's MTB, Jackal Mio Gravel Bike
Quoted: 763 Post(s)
Liked 363 Times in 292 Posts
Having a "compact" 50/34 crankset and 11-36 cassette will give you enough coverage for bombing downhills at incredible speed and dealing with very steep climbs.
cubewheels is offline
Old 06-05-21, 02:44 AM
dabac
Quoted: 1035 Post(s)
Liked 226 Times in 168 Posts
Gear Ratio
the gear ratio determines how much the rear wheel turns for each turn of the crank. This influences how hard it is to push the pedals. To go uphill you want the rear wheel to make few turns for each turn of the crank. To go fast on the flat you want many turns of the wheel for each turn of the crank.
Humans, like all engines, work best in a certain combination of resistance and rate-of-turn.
It is generally recommended that you pick a gear that lets you turn the pedals 80-100 revolutions/minute.
dabac is offline
Old 06-05-21, 07:28 AM
big john
big john's Avatar
Can you post a link to any bikes you are considering? Or can you tell us what brand and model bike you can get there?
big john is offline
Old 06-05-21, 11:48 AM
Jack Tone
Quoted: 200 Post(s)
Liked 117 Times in 83 Posts
I think something like this could do anything you want.
https://www.ribblecycles.co.uk/ribbl...himano-tiagra/
Jack Tone is offline
Old 06-05-21, 05:12 PM
big john
big john's Avatar
I like it! I wonder if you can get one in Turkey.
big john is offline
Old 06-05-21, 07:47 PM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 1263 Post(s)
Liked 482 Times in 352 Posts
And it'll leave you with big jumps between each gear, which doesn't bother some folks but you might hate it. If you want to stay at your most efficient cadence (RPM), you want close gears that don't spread as wide, if you don't need all that range. I don't do much climbing so it's 53/39 x 12-25 on my bike. If I could get 13-25 in 11s, that'd be on there.
Kimmo is offline
Old 06-05-21, 10:28 PM
veganbikes
Clark W. Griswold
Quoted: 2378 Post(s)
Liked 1,380 Times in 925 Posts
Specialized Allez Elite is a great entry level road bike with decent components there is a shop in Istanbul that deals with Specialized (and might be more around the country) that would be a reasonable consideration as it is generally a popular one near me and I have sold a bunch of them over the years.
veganbikes is offline
Old 06-06-21, 12:23 AM
Dean V
Quoted: 1023 Post(s)
Liked 211 Times in 124 Posts
Not enough information to give any useful advice.
But I would say that you don't normally choose a bike by the gearing it has.
Dean V is online now
Old 06-06-21, 12:46 AM
Epika
Quoted: 5 Post(s)
I saw the link, but i think more like bianchi slr 400. Or close to that. Btw like kimmos said, i dont want climbing too much. Is this gear ok for me? Thanks for all advices. Im gonna ask for price to ribble in our country. What a great community
Epika is offline
Old 06-06-21, 09:07 PM
cubewheels
Quoted: 763 Post(s)
Some low-high gear cassettes only have big jumps at the lowest gears (36T to 30T). 28T and below is more or less normal jumps and has similar jumps to a 28-11t 9 speed cassette.
Not everyone starts at >11 speed cassette. Most riders I know started with 8 speed cassette. It never bothered them and was totally happy with it......Until they upgraded to >10 speed cassette.
Old 06-06-21, 09:22 PM
cubewheels
Quoted: 763 Post(s)
The more you don't like climbing, the more you need lower gears. Climbs will be eaiser and more bearable with lower gears. You cannot avoid climbs totally unless you don't plan doing long rides and only stick to one place where it's almost flat everywhere.
Old 06-07-21, 06:34 AM
Kimmo
bike whisperer
Kimmo's Avatar
I started with six cogs, and it was a matter of choosing carefully. I chose to go without the rarely used extremes so I'd have the cogs I wanted often.
Kimmo is offline
Old 06-07-21, 06:51 AM
cubewheels
Quoted: 763 Post(s)
Those I knew with 8 speed had 28-11t with compact crankset. Their main complaint was not enough low end gearing for climbs. Many in the group are >50 year olds. Never heard them complain about the jumps of 8 speed. Maybe they have no idea what "jumps" are all about in relation to cadence.
Old 06-07-21, 07:01 AM
Kimmo
bike whisperer
Kimmo's Avatar
Everything depends on how many hills are around.
Kimmo is offline
Old 06-07-21, 10:00 AM
Chuckles1
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 124 Post(s)
Liked 89 Times in 61 Posts
If you live in hilly area or are oldish this is excellent advice. Both apply to me, and my 39/48 cyclocross bike with 11-36 cassette and road tires has given my "road" bike a new life since putting on the 11-36 and a Sora GS RD to replace the original 12-25 cassette. Those 12-25s are for young fellers and flat-landers...
Chuckles1 is offline
Old 06-07-21, 10:08 AM
big john
big john's Avatar
I don't think they sell that model in America so I can't find any information on it. I do think Bianchi makes some nice bikes and if you have a dealer you can trust they can probably help you make the right choice.
big john is offline
Old 06-11-21, 02:39 AM
Epika
Quoted: 5 Post(s)
Yes, i get gear means now. Thanks everyone. Like big john's said, i hope the dealer make the right choice for me.
Epika is offline
Old 06-11-21, 02:48 AM
SoSmellyAir
Method to My Madness
Bikes: Cannondale Synapse, Trek FX 2
Quoted: 236 Post(s)
Liked 159 Times in 121 Posts
Most bikes come with pretty big gear ranges nowadays (50/34 chain rings, 11-32 cassettes), so if anything, you might want to reduce range if you do happen to end up riding only in relatively flat areas.
SoSmellyAir is offline
Old 06-17-21, 06:28 PM
teejaywhy
teejaywhy's Avatar
Bikes: 2019 Specialized Roubaix Expert; 2018 Breezer Thunder Expert
Quoted: 85 Post(s)
Liked 49 Times in 34 Posts
This is not gearing that would be recommended for any beginning rider.
teejaywhy is offline
Old 06-17-21, 10:40 PM
Kimmo
bike whisperer
Kimmo's Avatar
I'd say that depends on where they live, and furthermore it wasn't a recommendation so much as making the point that there's a cost many ignore to having unnecessarily wide ratios.
Kimmo is offline
Old 06-18-21, 02:03 PM
aliasfox
Quoted: 91 Post(s)
Liked 35 Times in 29 Posts
If the bike you're looking at is the Bianchi SLR 400 on Trendyol, then that's a fine bike to start on. The listing there doesn't say what the crank (gears directly attached to your pedals) gears are, but I would assume 50-34. The cassette is 11-30, which should give you a decent range of gears for flat to mildly hilly. If you live somewhere with steep hills that you'll be riding regularly, I'd change to a wider cassette, like 11-34. But for your typical roads, 11-30 is quite good.
How many KM are you planning on riding per week? Per year? Are you going out in all four seasons, wet/cold and dry/hot? If you plan on riding a lot (say, >2k km/year), you might find some value in looking at bikes equipped with Shimano Sora, rather than Claris. Claris is fine, but Sora will shift a little better and is likely built a little better for heavier use. Of course, that comes at a price.
Just a few things you're going to want to factor in when you get a bike and start riding more than 30-60 minutes at a time:
- Get a saddle bag, and fill it with two tire levers, a tube, a patch kit, and a CO2 canister. If you can't get a CO2 canister, then get a mini pump to mount to your bike
- Learn to repair or replace your tube - you say not all roads are good, glass and rocks can easily cause a puncture. Fixing a flat tire by replacing or patching a tube is a lot more fun than walking 10-20km until you can get a ride
- Also, once you're riding more than 60min regularly, might want to look at cycling shorts or clipless pedals. Not everyone's taste, but they do make longer rides more enjoyable
- If you're looking to save weight on your bike, the first, and most useful upgrade will be the tires. I know nothing about Chaoyang tires, but I doubt they're lightweight or fast rolling. Switching out to a moderately priced folding bead tire such as Continental Ultra Sport Folding or Vittoria Rubino Pros (among others) could save you 0.5 kilo.
aliasfox is offline
