Ti Bike: "The Last Bike You'll Ever Buy" What About Carbon Bikes?
Old 06-17-21, 01:26 PM
  #76
terrymorse
climber has-been
terrymorse's Avatar
Bikes: Scott Addict R1
Quoted: 895 Post(s)
Liked 689 Times in 391 Posts
Originally Posted by Chandne View Post
Do you carry your undergrad "CV" and metallurgy white papers around on your rides too or just here?
I never need to cite my professional credentials on rides, but here it's a quick way to shut down the unscientific myth repeaters.
Ride, Rest, Repeat
terrymorse is offline
Old 06-17-21, 01:34 PM
  #77
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 895 Post(s)
Hah! Bending metal changes their crystalline structure, IIRC. Maybe I dreamed that years ago. Bending them slightly as they deform as in a rim, continues to happen hundred of thousands of times. Over years, metal will fatigue. Resin will break down too with enough cycles. This is why alloy wheels like Stan's Crests "soften up" and need to be trued more and more often till they are trash.
None of what you wrote above explains how a metal's stiffness might change over time.
Nothing you write can, because it doesn't change.
One more time: no amount of stress cycling will soften a metal.
Please stop, this is embarrassing.
Ride, Rest, Repeat
Old 06-17-21, 01:37 PM
  #78
StanSeven
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 875 Post(s)
Liked 798 Times in 581 Posts
Enough of the personal insults here. No names mentioned for now. I’ve cleaned up the thread so let’s let it continue the way it should.
StanSeven is offline
Likes For StanSeven:
Old 06-17-21, 01:39 PM
  #79
Eric F
Habitual User
Eric F's Avatar
Bikes: 2018 Storck Fascenario.3 Platinum, 2003 Time VX Special Pro, 1977 Nishiki ONP, 1999 Trek 9900 SS
Quoted: 635 Post(s)
Liked 1,284 Times in 615 Posts
Didn't take me long to find this...
Originally Posted by Kestrel
...carbon composites themselves are not subject to fatigue failures as metals are. So the fatigue life of a properly made carbon composite is “infinite”.
Originally Posted by Look
There is no limitation because carbon has a natural flexibility. It can be used a hundred years while maintaining the same stiffness.
Please stop spouting false information.
Eric F is offline
Old 06-17-21, 02:46 PM
  #80
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 895 Post(s)
The "metal softening" myth does pop up periodically.
Jobst Brandt contributed some comments about Frames Going Soft it in rec.bicycles.tech in 1998. His "technically correct but colorful" comments hold up pretty well.
Ride, Rest, Repeat
Likes For terrymorse:
Old 06-17-21, 03:44 PM
  #81
Trakhak
Quoted: 914 Post(s)
Liked 688 Times in 406 Posts
Continuing the theme of materials engineering, here are the results of fatigue tests of 12 high-end frames reported in the German Tour magazine back in 1997. Note that two aluminum frames and one carbon fiber frame passed the tests with flying colors while all of the steel and titanium frames failed. (The testers observed that the failures were mostly the consequence of errors in design and fabrication.)
Trakhak is online now
Likes For Trakhak:
Old 06-17-21, 04:05 PM
  #82
Chandne
Bikes: 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Yeti SB4.5, Pivot Shuttle
Quoted: 315 Post(s)
Liked 40 Times in 25 Posts
Like I said, the carbon fiber does not seem to break down but the resins do...the resins that are the glue, essentially. Now, I do not work with carbon but am close to the composites made for the aerospace industry (by hexcel, for example). In the bike industry, they use similar composites but often much more resin. The resin can break down over time (and with heat). Bikes may take way too long to notice and maybe you never will in most cases. Ti is probably still the king if welded very well. Now the alloy thing is also from personal experience with some softer alloy rims that were great at first but eventually after a couple of years, started to feel a bit softer and needed more truing. I did not examine the alloy at a molecular level, obviously. When I called Notubes, they said that the lighter rims would break down and soften up over time and to stick with the Flows or stiff carbon rims. My wheelbuilder (who may have read the same "soft alloy" discussions) said basically the same think. What happens from a crystalline structure level is obvious in metals when you heat and bend them but in rims over time/beating...does the crystalline structure slowly change too? Good debate and discussion. Fine...let's keep the alma mater out. It made me no smarter, though my dad's lessons probably was more of a nourishing mother.
Chandne is offline
Old 06-17-21, 05:02 PM
  #83
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 895 Post(s)
Resins used in carbon composites remain stable for a very long time. They do soften at high temperatures, but the temperatures that bicycle components experience are nowhere near high enough to induce this softening.
The one exception: carbon rims with rim brakes. Extended braking downhill can generate enough heat to raise the rim temperature above the resin softening point, and the rim will fail. To avoid this, manufacturers now use higher temperature resin in rims.
Notubes was mistaken. The metal in those rims rims wasn't softening up. The rim was probably failing. Lightweight aluminum rims usually fail from cracks near the spoke holes.
Your wheelbuilder was also mistaken.
No. The crystalline structure of aluminum alloy does not materially change from stress cycles. And even if it did, the stiffness of the metal wouldn't change.
But cracks do form in aluminum rims, and grow, leading to failure.
Ride, Rest, Repeat
Old 06-17-21, 05:27 PM
  #84
Chandne
Quoted: 315 Post(s)
Except in my case, there were zero cracks or fissures I could see when laced up or unlaced...not in the Crest and not in the Arch. We examined them closely and did not find a single crack. If there were not visible to the naked eye, then that is certainly odd. I moved to carbon Knights and Nox rims and have had no issues. I'm not a particularly aggressive mountain biker (no drops over two feet and no drops to flat) but carbon seems to serve me better on the mountain bike and feels the same for the three years I have had them, unlike the alloy rims which started to feel softer and less precise on hard corners in under two. They started out great and were quite comfy too, though the carbon rims are just sharp handling.
Chandne is offline
Old 06-17-21, 07:38 PM
  #85
BillyD
Administrator
BillyD's Avatar
Quoted: 8964 Post(s)
Liked 2,605 Times in 1,473 Posts
Originally Posted by lifanus View Post
Yes it is... It's the Gov Mario M. Cuomo Bridge between NJ/NY.
aka the New Tappan Zee Bridge. #pushback
btw the bridge does not connect to NJ, it connects Westchester county to Rockland county.
BillyD is offline
Likes For BillyD:
Old 06-17-21, 07:56 PM
  #86
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 2963 Post(s)
Liked 3,035 Times in 1,537 Posts
I dunno. "The Last Bike You'll Ever Buy" sounds sorta like a threat.
genejockey is offline
Likes For genejockey:
Old 06-18-21, 04:02 AM
  #87
PeteHski
PeteHski's Avatar
Quoted: 498 Post(s)
Liked 460 Times in 307 Posts
Your alloy rims probably had worn spoke nipple seats. Stress concentration around the spoke holes where the nipples are seated eventually leads to local deformation and then the spoke nipples only contact on one side of the hole. Eventually you get micro cracking around the holes and later on much more visible cracks propagating out from the holes. The rim material itself doesn’t soften up. But once the spoke holes start to wear and deform it becomes more difficult to maintain consistent spoke tension.
The only time I’ve seen carbon “soften” is due to excessive heat (exhaust gases blowing over carbon suspension wishbones on F1 cars). I’ve been involved in testing stiffness of many carbon race chassis and IME they don’t lose stiffness with normal use. Only delamination from severe impact damage causes problems with longevity. I would expect a well designed carbon bike frame to last pretty much indefinitely unless heavily crashed.
PeteHski is offline
Likes For PeteHski:
Old 06-18-21, 11:29 AM
  #88
Quoted: 13341 Post(s)
Liked 6,007 Times in 3,082 Posts
For old times' sake.
Likes For indyfabz:
Old 06-22-21, 07:33 PM
  #89
SoCal_Cyclist
I've tried titanium. Carbon bikes are lighter and more comfortable for me. More shock absorption and vibration dampening, plus lighter.
The only real advantage of titanium is durability if you're going to travel with it and bang it up.
SoCal_Cyclist is offline
Old 06-22-21, 07:34 PM
  #90
SoCal_Cyclist
Originally Posted by PeteHski View Post
Some good points here.
Threaded BBs are making a comeback on carbon frames, so that’s one less potential longevity problem.
Impact protection can be improved with use of protective film etc and hasn’t really proven to be a major problem with MTBs and even less so with road bikes. But I agree there is more vulnerability to casual abuse with a carbon frame. With some super-light frames you are even warned not to sit on the top tube. But that’s more of a design compromise than an inherent material weakness. A super-lightweight metal frame would also be more fragile.
The Achilles heel of a Ti frame is the welded joints, which are prone to fatigue sooner or later.
I think the classic look of a metal framed bike is really what drives their longevity. Carbon frames are more of the moment, but I’m not sure there is much further for them to go in design evolution from this point. Aero optimisation will converge on a single design point and non-aero designs like the Aethos are driven by FEA, the results of which again will not vary much. Perhaps any future change in UCI regulations could drive a more radical change in design.
What is FEA?
Old 06-22-21, 08:19 PM
  #91
palesaint
Bikes: 2008 fetish illustre
Quoted: 10 Post(s)
Originally Posted by SoCal_Cyclist View Post
What is FEA?
Federal Everythingbutcarbonbikes Association
palesaint is offline
Old 06-22-21, 09:54 PM
  #92
Litespud
Bikes: 2000 Litespeed Vortex Chorus 10, 1995 DeBernardi Cromor S/S, Nashbar 3sp commuter
Quoted: 510 Post(s)
Liked 537 Times in 301 Posts
Hah! Bending metal changes their crystalline structure, IIRC. Maybe I dreamed that years ago. Bending them slightly as they deform as in a rim, continues to happen hundred of thousands of times. Over years, metal will fatigue. Resin will break down too with enough cycles. This is why alloy wheels like Stan's Crests "soften up" and need to be trued more and more often till they are trash. Do they still have Holiday Inn Expresses, or are you just saying that to appear witty?
the steel hairspring in my watch coils and uncoils 8 times/sec, day in day out. That’s ~250 million times/year, and will do this for decades. This is in a mechanism where the most infinitesimal change in the behavior of the material will manifest itself in measurable speed variation. Since my watch has run 24/7 for the last 5 years, we’re looking at ~1.25 Billion flexes without change. Tell me again how metal inevitably fatigues or “softens” 🤔
Litespud is offline
Likes For Litespud:
Old 06-22-21, 10:45 PM
  #93
Chandne
Quoted: 315 Post(s)
Your watch spring is not under near as much load and is built to basically be an extremely tensile leaf spring, I assume. Since we are talking about stiffer alloy rims, they do fatigue like any high-strength alloy will. The frame is probably not under that type of deflection stress. In the transportation industry (for example) over 70% of failures are due to fatigue caused by alternating stress. It is sort of if you keep bending a thin fork or an alloy clip- they don't have tensile strength. They will break. This is called microplasticity and you can easily find this issue in several industries where they keep trying to strengthen alloys for this reason. It causes a permanent weakness in the weak points of the microstructure and starts to weaken or soften it, and then eventually leading to a crack or fissures that permanently weakens or destroys the part. Alloys have developed very good tensile strength so they can bend early in this potential fatigue cycle to avoid this but it is not infinite and very high tensile strength cannot be applied in many parts due to rigidity etc needed. It isn't like the bike or rim will simply become putty-soft. Your watch probably has a pretty cool tiny leaf spring instead of a coil spring. Leaf springs are springy and built to avoid the type of weakness/softening and eventual fissure or crack because of the design. It is a totally different material than an alloy rim which is probably designed to deflect at its contact points with the ground over and over but not forever and certainly not designed to take too many impacts while doing that. I hope this has helped, since your watch spring's incredible fatigue life appears to have perplexed you.
Chandne is offline
Old 06-22-21, 10:57 PM
  #94
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 895 Post(s)
What is FEA?
FEA: Finite Element Analysis. It's a numerical method for determining the stresses in a structure. Or heat transfer.
Ride, Rest, Repeat
Old 06-22-21, 11:04 PM
  #95
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 895 Post(s)
<sigh>
For the last time: METAL DOESN'T SOFTEN FROM STRESS CYCLING!
A stressed component maintains its stiffness, right up to the point when it fails.
Ride, Rest, Repeat
Old 06-22-21, 11:17 PM
  #96
Chandne
Quoted: 315 Post(s)
Are we still talking about watch springs or titanium frames? Hopefully we have the resin situation sorted out.
Chandne is offline
Old 06-27-21, 10:09 PM
  #97
Sorcerer
Sorcerer's Avatar
Location: '16 StumpJ, Salsa Mukluk, Soulcycles SS, Dean Colonel HT, BMC FourstrokeTrail, Dean Torres CX, Santana Visa Tandem, Trek T2000 Tandem, Cupertino MTB Tandem, FreeAgent26"Xtracycle, Dirt Drop Dingle, Jamis Dragon Dingle, Airborne Skyhag SS, SSDean Cols
Quoted: 34 Post(s)
Liked 50 Times in 25 Posts
This became a mildly contentious thread didn't it.
All in good sport.
A 6'4" friend of mine stopped riding his Ti mountain bike because of a crack which was slowly spreading near the top of seat tube below the seat post clamp area across the middle of the seat tube and not across the weld(s).
There are threads about this sort of titanium frame failure with photos and some frames have been repaired. It might not be worth it.
I'd I had an unlimited budget I would have disc brake bosses welded on the rear ends of my old frames, but I can't, won't, and will ride a more appropriate bike when the conditions are slimy if I can.
After reading through this thready conclusion is that titanium bike frames are not forever or the last one you will ever own or need. Titanium isn't perfect or infallible.
One thing is certain to me is that riders get used to what they ride and riders, not all but most, will compensate for the shortcomings with their riding style and technique and expectations.
I ride a a variety of bikes like most here do and I like them all. I know that my two old titanium mountain bikes which are single speeds are very capable especially with good tubeless wheels on them, but they aren't any near as good as it gets.
A late model carbon hardtail will blow my old bikes away - no contest.
There is a certain aesthetic about titanium.
As I write I'm catching up on the TDF and I see so many wrecks on the first stage! Tragic stuff.
Now I ask you and me, which crashed bike would you choose to be more likely worthy to continue to ride given an inspection for visual damage? I'd pick Ti. Carbon may have concealed damage.
​​​​​​Mind you that's just an opinion.
Back in the day I drove a Giant Cadex on a roof rack into an overhang and it pulled the bike rack off the car and the bike showed no damage at all! I kept rising it for a few more years before selling it to someone at work who rode it in Washington on trails for a dozen more years.
Anecdotes abound. Anything can fail. Nothing is Forever.
Sorcerer is offline
Old 06-28-21, 01:38 AM
  #98
Trakhak
Quoted: 914 Post(s)
<sigh>
True. The term of art is work hardening, not work softening.
Likes For Trakhak:
Old 06-29-21, 12:26 AM
  #99
tempocyclist
tempocyclist's Avatar
Quoted: 27 Post(s)
Liked 66 Times in 28 Posts
Originally Posted by Bassmanbob View Post
He said that as long as it's taken well care of, longer than I'll be alive.
Do carbon fiber frames last 20- 30 years?
Carbon can and does last. It's not as fragile as many people make it out to be. I've got a carbon fibre road bike that is 20 years old and still going strong.
tempocyclist is offline
Likes For tempocyclist:
Old 06-29-21, 10:02 AM
  #100
pgjackson
pgjackson's Avatar
Bikes: Rossetti Vertigo
Quoted: 156 Post(s)
Liked 81 Times in 47 Posts
Man, I disappear for 5+ years and people are still arguing steel vs aluminum vs CF vs titanium. Some things never change.
pgjackson is offline
