Tubeless Tires on Road bike. Yuck!
Old 06-14-21, 11:32 AM
  #101
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
Liked 519 Times in 345 Posts
Originally Posted by GBK233 View Post
I got the whole “rolling” the tire thing from a GCN YouTube video. He actually had the wheel on a table and rolled and squished the tire to spread sealant all over the inside of the tire.
Yeah not sure about squishing the tire and such....but you'll get it figured out. It really is simple once you get it. If I lived near you I would help you out.
jadocs is offline
Old 06-14-21, 02:03 PM
  #102
sfrider
Asleep at the bars
sfrider's Avatar
Quoted: 212 Post(s)
Liked 176 Times in 112 Posts
Originally Posted by eduskator View Post
As I said, Giant products are crap. Try other TL tires, you'll see! I can mount my Schwalbe Pro Ones on my OEM SLR rims even without an air compressor.
I've never used a compressor. A regular floor pump does the job just fine for me.
Why someone wants to disassemble their bike to swap tubes on the side of a road every time they run over a staple is beyond me. But to each their own.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
sfrider is offline
Likes For sfrider:
Old 06-14-21, 02:50 PM
  #103
Psimet2001
I eat carbide.
Psimet2001's Avatar
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1131 Post(s)
Liked 820 Times in 370 Posts
Then you haven't done much tubeless then. As a shop owner I have run into piles of combinations that took some finesse even with a compressor that were absolutely impossible with a regular floor pump. One of the tubeless ones with a chamber can usually get the job done.
On the "why would anyone" bit... For the number of flats I have had with a tube (1 in the last 5 years or so) I have absolutely had to do way more for the tubeless systems I have ran than for any tube.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Psimet2001 is offline
Likes For Psimet2001:
Old 06-14-21, 03:22 PM
  #104
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 530 Post(s)
Liked 172 Times in 122 Posts
You don't have to. Just throw a little sealant in the tube.
dmanthree is offline
Old 06-14-21, 03:23 PM
  #105
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 530 Post(s)
And *that* is why I prefer tubes. Just so damned easy to work with.
Old 06-14-21, 07:24 PM
  #106
GBK233
Bikes: 2020 Giant Defy Advanced 2, Marin Lucas Valley Flat Bar
Quoted: 138 Post(s)
Liked 60 Times in 25 Posts
I see it both ways now. Tubeless def has its advantages. If I do get a flat on the road….I’ll simply throw a tube in and inflate and be on my way. It’ll obv be not different than if I get a flat with a tubes setup. I bought a CO2 inflator head and CO2 cartridges, so roadside repair should be easy peasy. I also have a mini pump.
The extra “hassle” will be at home…getting the tire re-seated after repairing the tire. I’ll either just bring the wheel to work and use the compressor…or maybe I’ll pickup a pancake compressor. Would probably come in handy for other inflation needs at home.
im loving the 32mm tires. I ran 28mm Conti 4-seasons on my Felt, but they barely cleared the frame….so I went down to 25mm.
The 28mm tires aren’t being used, so I can always mount them (w/tubes for course) on my Defy should I have some catastrophic failure with the Fondas.
GBK233 is offline
Likes For GBK233:
Old 06-15-21, 09:32 AM
  #107
noodle soup
noodle soup's Avatar
Quoted: 4670 Post(s)
Liked 1,805 Times in 977 Posts
Originally Posted by branko d View Post
i just don't see myself ever using tubes anymore
fify
noodle soup is offline
Likes For noodle soup:
Old 06-15-21, 09:37 AM
  #108
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
Leyzene Pressure Overdrive Floor Pump hasn't failed me yet.
jadocs is offline
Old 06-15-21, 09:43 AM
  #109
GBK233
Quoted: 138 Post(s)
Airshot failed me, so I’m guessing a Lezyne would fail me(with this tire/wheel combo) also. $150 for a bike pump doesn’t make sense to me…when I can get a pancake compressor and all accessories for $100.
GBK233 is offline
Old 06-15-21, 10:07 AM
  #110
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
The thing you have to consider with compressors is it needs a high pressure blast with some tires vs. just having a constant flow at lower pressure or a slow build up of pressure. Removing the core helps but can be problematic replacing it in time for tires that come unseated easily. I know the compressor at my bike shop could not seat a tire that my Leyzene could. I can get the Leyzene up to 200psi before I release it. Anyway just some random thoughts.
jadocs is offline
Old 06-15-21, 11:16 AM
  #111
GBK233
Quoted: 138 Post(s)
Agreed. Using a high pressure nozzle with the compressor will/would give the blast needed. Compressors don’t just air up things slowly obviously…it all depends on what nozzle you use.
The big diff between the 2 is that I don’t have to manually pump up pressure between blasts when using a compressor. Took me multiple attempts even using the compressor at work. After pumping the AirShot for a few attempts….I tired of the hassle in a hurry.
GBK233 is offline
Old 06-15-21, 11:22 AM
  #112
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
Another thing that can help with problem tires is double wrapping the tape. Start at one side of the valve hole, go around twice and end on the other side of the hole. This keeps it single ply around the valve hole and double everywhere else. Obviously when you start do not immediately wrap over the hole.
jadocs is offline
Old 06-15-21, 01:06 PM
  #113
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 530 Post(s)
I made that very repair a couple of years ago, but by the time I got home the tube and former tubeless tire were permanently welded together. I tossed both of them.
Old 06-15-21, 01:42 PM
  #114
WhyFi
WhyFi's Avatar
Quoted: 16905 Post(s)
Liked 5,611 Times in 2,906 Posts
... but by the time I got home the tube and former tubeless tire were permanently welded together. I tossed both of them.
That's... odd. What sealant was this? I've only ever used Orange Seal (no reason to change), but it'll peel off of the inside of any tire that I've ever used. so I can't imagine that kind of bonding.
WhyFi is online now
Likes For WhyFi:
Old 06-15-21, 01:59 PM
  #115
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 530 Post(s)
It was Stan's. Stuff is pure evil if spilled.
Old 06-15-21, 02:32 PM
  #116
WhyFi
WhyFi's Avatar
Ah, another feather in its cap - its performance (or lack thereof) also has a reputation for turning road cyclists off of tubeless altogether. Ish.
WhyFi is online now
Likes For WhyFi:
Old 06-15-21, 03:12 PM
  #117
Trsnrtr
Super Moderator
Trsnrtr's Avatar
Quoted: 8371 Post(s)
Liked 1,868 Times in 910 Posts
That reminds me, I need to order more orange seal.
Dennis T
Where there is a will, there's a way. Where there is no will, there's an excuse.
Trsnrtr is offline
Likes For Trsnrtr:
Old 06-16-21, 08:59 AM
  #118
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 530 Post(s)
Some remnants of it still remain on my garage floor. Never again. Ironic that a company dedicated to tubeless turned me away from it.
Likes For dmanthree:
Old 06-16-21, 09:51 AM
  #119
Psimet2001
I eat carbide.
Psimet2001's Avatar
Yeah Stans has no place in road. I get so many customers that love it for mtb and I can't tell how much of that is just nostalgia or if it somehow actually performs in those applications but for road it just has never really worked. Yet at the distributors they blow through pallets of it as soon as it hits their warehouse.
Old 06-16-21, 10:12 AM
  #120
Dancing Skeleton
Dancing Skeleton's Avatar
Quoted: 59 Post(s)
Liked 25 Times in 18 Posts
I gotta agree.
I tried Schwalbe Pro One's, and although I really liked the smoothness of the ride, I grew tired of cleaning sealant off my frame after most rides.
The tires got small holes on almost every ride, but sealed up right away. They just made a mess of my bike.
I hate to think of how difficult it would be if I had to put in a tube on the road.
I went back to tubes.
Next I'll try the Aerothan lightweight tubes.
No more road tubeless for me.
Dancing Skeleton is offline
Likes For Dancing Skeleton:
Old 06-16-21, 10:22 AM
  #121
GBK233
Quoted: 138 Post(s)
Originally Posted by Dancing Skeleton View Post
I gotta agree.
do you ride in crappy areas or did you find that the Schwalbes aren’t really that puncture resistant? The Aerothan tubes have piqued my interest as well
GBK233 is offline
Old 06-16-21, 10:42 AM
  #122
Psimet2001
I eat carbide.
Psimet2001's Avatar
Inconsistencies with Schwalbe quality over the years has led me to never stocking, using or selling any of their tires. Ever. Everyone has problems with product...but I have only ever seen Schwalbe have the gross structural integrity problems I have seen from them.
Some people here love their tubeless product. I have always chalked that up to them being one of the first and having the longest amount of time for refinement. The other side of that coin though is that the higher quality tire companies stayed out of tubeless because they knew all of the problems that existed. They are now coming into the tubeless game and have much better product stemming from their long experience producing better quality tires.
In other words I see Schwalbe getting credit for being willing to be the kid who throws the cooking pot on their head and storms across the trenches into the face of overwhelming opposition while the rest of them stood back and watched and took notes.
YMMV - quite literally.
Old 06-16-21, 10:48 AM
  #123
terrymorse
climber has-been
terrymorse's Avatar
Bikes: Scott Addict R1
Quoted: 910 Post(s)
Liked 711 Times in 401 Posts
If not Stan's, what's a decent sealant for road use then?
My personal use would be inside a latex tube, something to keep me rolling on my more remote rides.
Ride, Rest, Repeat
terrymorse is offline
Old 06-16-21, 10:49 AM
  #124
Psimet2001
I eat carbide.
Psimet2001's Avatar
Orange Seal Endurance formula. We use it exclusively.
Old 06-16-21, 11:33 AM
  #125
WhyFi
WhyFi's Avatar
I gotta agree.
The original Pro One was notoriously fragile - your problem wasn't tubeless, so much as it was your tires.
WhyFi is online now
