I Need Battery for my Blix Vika+ Folding Ebike ...
Old 06-07-21, 05:05 PM
vja4Him
GadgetJim57
vja4Him's Avatar
Bikes: Yuba Sweet Curry eBike, Surly Long Haul Trucker
Quoted: 50 Post(s)
Liked 7 Times in 4 Posts
Can anyone recommend an after-market battery for my Blix Vika+ Folding Ebike ? Blix does not have any batteries available.
vja4Him is offline
Old 06-07-21, 07:09 PM
cat0020
Ride more, eat less
cat0020's Avatar
Quoted: 333 Post(s)
Liked 151 Times in 104 Posts
Check Alibaba, do need to know the specifics about your battery to offer better sources.
cat0020 is online now
Old 06-07-21, 09:37 PM
2old
Quoted: 534 Post(s)
Liked 312 Times in 228 Posts
Surprised that Blix doesn't have replacements, but maybe they can help locate one. If I had that problem I'd examine the feasibility of having the battery rebuilt.
2old is offline
Old 06-09-21, 07:15 AM
Doc_Wui
Doc_Wui's Avatar
Quoted: 277 Post(s)
Liked 105 Times in 78 Posts
Probably wants a spare. Perhaps if he contacts a battery rebuilder, like FTH, they may know what kind of case is used by the Blik, and they may even tell him, although I am dubious about either possibility. A good ebike shop that sells Blik and other brands should also know, but whether they let the info out is also dubious.
In this case, the battery looks like it could be a Hailong type, but the variables include how many volts, how many AH, and whether it's 4 pins or 5 pins in the cradle.
Doc_Wui is offline
Old 06-09-21, 09:57 AM
2old
Quoted: 534 Post(s)
DW; how many different battery to controller connectors have you seen? There are completely different ones on my Haibike, my daughter's DIY Dillenger kit and, of course, the XT-60's, XT-90's and bullets on other kits. It seems to me that most different companies producing e-bikes have proprietary systems. Then, there are those with the batteries in the frame tubes.
2old is offline
Old 06-09-21, 01:11 PM
Doc_Wui
Doc_Wui's Avatar
Quoted: 277 Post(s)
Yes, this is really hard to do without lots of pictures and measurements.
Some of those Hailongs use round pins too. Luna has a pack called the Shark, and the Whale. Then you have the Dolphin packs. a design which is at least 8 years old.
You can have Silverfish packs. of different heights. with either 4 or 2 pins, plus they often flip the pin polarity. I recall one poster had two of these. One worked, and one did not. Turned out they did flip polarity, but the battery was well protected. When it was inserted and turned on, the BMS saw the dead short and simply powered off. No drama. No sparks.
Doc_Wui is offline
Old 06-09-21, 01:55 PM
2old
Quoted: 534 Post(s)
Seems like it behooves the OEM's (major and minor) to have a proprietary system since then customers need to buy extras/replacements from them and they can charge whatever they can get away with. If they don't happen to have extras at any given time, it's no sweat off any part of their body.
2old is offline
Old 06-09-21, 05:40 PM
alloo
alloo's Avatar
Bikes: 2020 Blix Aveny
Quoted: 156 Post(s)
Liked 114 Times in 86 Posts
Do you need a battery immediately? Order one from Blix.
alloo is offline
Old 06-09-21, 05:50 PM
cat0020
Ride more, eat less
cat0020's Avatar
Quoted: 333 Post(s)
Back in 10 DEC 2020, I ordered two spare batteries for my employee's e-bikes through Alibaba.
48v, 10Ah, $195 each, free shipping, comes with chargers, received on 27 DEC 2020 of placing the order.
The same manufacturer have many other type of e-bike batteries available.
Pretty sure I will order again if I have need for e-bike replacement batteries.
Likes For cat0020:
Old 06-13-21, 11:08 AM
creativepart
Age before beauty
creativepart's Avatar
Quoted: 5 Post(s)
Liked 7 Times in 5 Posts
I have a Blix Vika +. But no extra battery.
Here's the battery and it's connection type:
creativepart is offline
Old 06-13-21, 03:43 PM
cat0020
Ride more, eat less
cat0020's Avatar
Quoted: 333 Post(s)
Maybe this would fit?
https://www.alibaba.com/product-deta...485644660.html
Old 06-13-21, 10:04 PM
Doc_Wui
Doc_Wui's Avatar
Quoted: 277 Post(s)
It looks like a Hailong battery case to me. You will have to look at your pack to see if it is a 4 pin or 5 pin version. The above alibaba link is for importers. Look at ebay or aliexpress for a single unit. I think it might be hard to find a 4 pin version. Unit Pack Power, one of the large China vendors says they moved away from 4 pins.
You can always ask the vendor to quote a price on a 4 pin pack, and also ask for brand name Samfung or LG cells. The latter will raise the price.
Doc_Wui is offline
Old 06-14-21, 09:49 PM
speedy25
Bikes: Specialized, Trek, Diamondback, Schwinn, Peugeot
Quoted: 127 Post(s)
Liked 19 Times in 16 Posts
A quick tip I found from another Blix. Their spring battery contacts were the cheapest crap I ever encountered. Pry them toward the center of each contact and it might just come back to life.
This solved a battery problem for a customer last year.
-SP
speedy25 is offline
