Front Derailer - H limit & Drop chain issue
Old 06-11-21, 01:49 PM
Kezzzzz
I am having a problem with chain drop off the big ring on a 2nd hand bike I bought. Sram red 10spd.
The chain keeps on jumping off the big ring and if I adjust the H limit to sit closer I can't shift from the small to big ring.
What I have tried:
- reset the derailer position, straight and just a few mm off the big chain ring
- set the L limit screw whilst on the small ring
- tension the cable by hand whilst on small ring
- moved to big ring, adjusted the H limit screw. It was pretty far out.
- problem, now i can't shift from small to big ring.
- I let the H limit screw out, I can shift again, but the gap is large and I drop chain off big ring quite a bit.
​​​​Can anyone help me troubleshoot this? TIA
Kezzzzz is offline
Old 06-11-21, 03:59 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 802 Post(s)
Liked 1,001 Times in 568 Posts
Which Red front derailleur do you have? The Ti cage one that was the first version?
cxwrench is offline
Old 06-11-21, 05:29 PM
Kezzzzz
Yep, I believe it was the first version. This is a 2015 sworks venge bike build.
I would post a photo but can't do it yet (too new to the forums)
Kezzzzz is offline
Old 06-11-21, 09:48 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 802 Post(s)
If it's this derailleur:
Throw it away and buy a current model. ^This^ derailleur was awful, very flexible and the shape of the outer plate (not curved) caused all sorts of problems w/ thrown chains. If you're using the one shown with a compact crank it's even worse. The angle of the cage plates was ok with standard chainrings (53/39) but needed a 3* shim to work well w/ smaller rings.
ETA: This thread should be in 'bicycle mechanics' for obvious reasons, not GD.
cxwrench is offline
Old 06-16-21, 09:23 PM
Kezzzzz
Thanks heaps for the help. I did have an old titanium from derailer and purchased a new one and installed it just now. 10 fold better result.
Thanks and appreciate your help.
Admin, please feel free to move to mechanic's.
Kezzzzz is offline
Likes For Kezzzzz:
