Has anyone tried these cheap Chinese TPU tubes?
Quoted: 1557 Post(s)
Liked 1,732 Times
Does anyone else notice that it seems to take more strokes to pump up the TPU tubes? Seems like there is a higher volume of air inside these tubes. On my Look bike I have a TPU tube in one wheel and a regular butyl tube in the other. I can say for sure that the butyl tube loses more air over time. Or I should say the butyl loses more pressure over time. Maybe they both leak the same amount of air, but since the TPU tube held more air to begin with, that same leakage amounts to less pressure loss.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,095 Times
Likes For livedarklions:
Quoted: 3490 Post(s)
Liked 2,909 Times
Liked 2,909 Times
But how many extra strokes could that result in? Admittedly, I'm basing these comments on my 700 X 23s, which don't have a huge volume to begin with.
Likes For smd4:
Quoted: 445 Post(s)
Liked 1,040 Times
My RideNow tubes are holding up great. I use them specifically for my hill climbing wheels. Unlike latex, the TPU tubes hold air with very little to no leakage. I hope these become more popular, I do see these as the go-to for road clinchers especially over latex and butyl.
Likes For jonathanf2:
climber has-been
Quoted: 3408 Post(s)
Liked 3,540 Times
OM boy
Bikes: a bunch
Quoted: 504 Post(s)
Liked 631 Times
Ran the wheels with the TPU again yesterday's longer ride. checked tire pressure before, it was identical to pressure when I last used them, the Monday before - 6 days back.
I don't use CO2, only footpump air...
As my butyl tubes become used up, I'll be shifting over to TPU.
Ride On
Yuri
Likes For cyclezen:
Quoted: 445 Post(s)
Liked 1,040 Times
I'll agree with that.
Ride On
Yuri
Ride On
Yuri
Quoted: 2975 Post(s)
Liked 1,178 Times
I try to get tubes and stuff online...
It's usually cheaper than the bike store and allows me to keep more money in my pocket. Plus I don't have leave the house and burn up gas and wear on tear on my car...So I save even more $$$ by not going to the bikes store.
Likes For prj71:
Liked 2,909 Times
How do TPU's compare to latex?
I just bought one of the cheapie TPU tubes, but I won't have it for a few days. The latex tubes I'm running now deflated by probably 1/2 their pressure or less in a week. Are the TPUs lighter? More flat resistant?
climber has-been
Liked 3,540 Times
TPU tubes vs latex:
- lighter (as much as 60 grams per tube)
- thinner
- more resistant to pressure loss
- slightly higher rolling resistance
Ride, Rest, Repeat. ROUVY: terrymorse
Liked 2,909 Times
TPU tubes vs latex:
- thinner
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,825 Times
Waiting for a tpu tubular tire.
Did I miss it?
Did I miss it?
Likes For Wildwood:
Still trying
I like the Aerothans in my road tires. Roll and road feel similar to when I had them tubeless, seem tougher than latex and don't lose air. Knock on wood, did a full season with no flats.
Tubilito makes a TPU in an interesting variety, for touring. It's double thick, 90 grams, tough AF, and still rolls better than butyl.
I will say that the slick plastic valve stems suck. The manufacturers have to know that pump heads blow right off them. They should make them rougher or put some ridges on them for my pleasure
Likes For hankj:
Usually ride my bike to local bike shop,
SUPPORT YOUR LOCAL BIKE SHOP !!!,
while you still have one !
Likes For martianone:
Anyone know if it is safe to move a RideNow tube from a larger tire after some use to a smaller one? In this case the gravel version (32-47C) from a 36c to a 34c tire. I thought I read somewhere this is a no no as the TPU cannot shrink back and can only be used in the same size or larger tire.
Quoted: 1391 Post(s)
Liked 1,852 Times
My Silca pumps worked on any and every tube - until I got the Aerothan tubes ; the chuck/head kept blowing off.
So I got a Hiro chuck/head - $ expensive - but never did try it because I began to use another method.
Now I use a schrader/presta adapter and a battery powered portable inflator.
First screw the shrader/presta adapter on to the Aerothan valve stem - and then screw the hose of the inflator to the adapter. Inflate the tire - and then when tire is inflated unscrew in reverse. Takes seconds. Have not used a hand pump since I began using the portable inflator.
Liked 1,852 Times
OM boy
Bikes: a bunch
Quoted: 504 Post(s)
Liked 631 Times
only reference I could find for TPU re-use was in this online article:
TPU Inner Tubes Part II: characteristics and market overview
Quote: " Re-using tubes: TPU Tubes can only be reused with tires of equal width or wider than the previous one (this has to do with the limited elasticity of the material)"
which was comprehensive, but also not a study, nor referencing evidence on many of the statements - focusing mainly on performance comparos and such...
so where did the 're-use statement evidence come from? manufacturer - CYA and also revenue booster?
I'd prolly think 2x before re-using a TPU in a 32mm, which was in a 45mm tire before... But I think this is a matter of degrees... 'Hand Grenade Close" should apply here.
I wouldn't lose sleep... especially at the pressures I run my tires...
Ride On
Yuri
EDIT: I'm actually thinking of going from 'Tubeless' to TPU on my MTB - I ride it so seldom now (when riding local I mostly use the gravel...) that paying attention to the Tubeless sealant re-charge is just another 'maintenance' thing... So when I forget, and the tire loses pressure and sealant gets dry... TPU will go on...
It's not like I do massive air or charge rock cliff faces for Mountain goat-like Gnar... I ride to survive.... LOL!
Likes For cyclezen:
Liked 2,909 Times
The one I ordered as a spare came in today. It is shockingly light, and the material shockingly thin. The analogy to grocery bag plastic isn’t far off—maybe Hefty garbage bag plastic is a little closer. I won’t get a chance to use this until I get my next flat, though. I am intrigued.
OM boy
Bikes: a bunch
Quoted: 504 Post(s)
Liked 631 Times
UPDATE:
It is now 'O-Fish-L thorn season in my area...
picked up a very small thorn - about 3mm long - which went thru the thread, just below the normal riding surface, so a thinner area on my Rubino Pros...
I had TPU tubes.
On removal of the tube/ I was able to determine where the puncture was - it was almost undiscernable... tiniest puncture I've ever had - but a puncture, none the less.
Replaced with Butyl backup tube.
On getting back to the yurt, I proceeded to do the repair... cleaned the tube, lightly scuffed the TPU tube in the area of the puncture, then cleaned again with isopropyl alcohol.
Placed Park Tools GP2 adhesive patch (claimed to work with TPU...) centrally over the puncture.
Mounted TPU tube to wheel and pumped to riding pressure - 72 psi.
Seemed to hold pressure - but not for any length of time - became quite soft in 2 hours...
not good...
so I might go to LBS and see if they have the tubolito patches...
Has anyone else had to patch their TPU tube ??? Sucessful ??? What did you uses/do???
Ride On
Yuri
I had TPU tubes.
not good...
Ride On
Yuri
Quoted: 7648 Post(s)
Liked 3,465 Times
OK, Quick update on the Ride Now TPU Tubes 700 x 18-32mm used in 700x23 tires Rubino Pros
2 weeks since receiving, ridden 4 times spread over the 2 wks, roughly 35 - 40 mi/ride.
... wheels do feel as thought they spin up a bit quicker - but that could be because I'm finally getting some recent relief from now being off the 3+ years of regular chemo....
