Shimano Introduces "Warp Resistant" Road Disc Rotors
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 389 Post(s)
Liked 325 Times
Somewhat eclipsed by the announcement of the new Shimano 105 Di2 group set, Shimano also announced new disc brake rotors that are less prone to warping...
New SHIMANO Rotors Deliver Quieter, More Consistent Braking Performance
I wonder how these rotors compare to XTR rotors in terms of their ability to not warp. I'm running XTR rotors on my Ultegra Di2 setup and they do make noise after hard breaking, like when there's a stop sign at the bottom of a long descent. The XTR rotor carriers are already more "beefy" than the road discs. Perhaps a "Dura Ace vs XTR rotor warp comparison" could be a future GCN episode.
Warp resistant rotors sound great. Now all we need is a warp capable bike.
Likes For jgwilliams:
Likes For prj71:
The main gist seems to be that they will run cooler (I wonder about that) and less apt to warp due to heat. Will an aluminum carrier be more prone to failure due to repeated braking stresses? It'd be a Bad Thing(tm) if your brakes ran without rubbing, but you could eventually count on them to explode on a big downhill.
Most mechanicals work by warping the rotors. Will they work with these new rotors?
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
can I get some for my Honda minivan
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Liked 2,969 Times
it might just be Shimano venting out a product for those that can ride fast, but don't have the best braking judgement.
-Oh Hey!
-Oh Hey!
Quoted: 1397 Post(s)
Liked 1,877 Times
I believe Shimano has offered the three layer rotors for a number of years - and the 'Freeza ' or similar version since 2018 or so ???
XTR RT99 rotor ... 2018 or so ?
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
Shimano at least on some bikes we had, came with warped rotors for a while, every once and while we still get them. Less common on other brands but I am sure it happens once and while. More warp resistance could be good. Really just a good stiff rotor is a positive, I am game.
I'm trying to think of a way to adjust the warp in the same way one would straighten a rim by the spokes.
I suppose the rotor would have to be thin enough to take adjustment. Let's say you had a bolt system either inside or outside the rotor with very smallphilips...allen... TORX fasteners you could adjust inwardly or outwardly to straighten the rotor. Or shim it.
Just a thought
Just a thought
My $2 disc rotors doesn't warp unless I come across a dense cloud of tachyon particles.
Seriously, I didn't even know rotor warp exists until this thread. I've gone long mountain descents, emergency braking during these descents with my cheap $2 single piece steel rotors and never had anything but consistent and smooth braking. Imagining a problem that doesn't really exist??
Liked 1,877 Times
you've never experienced brake pedal 'pulsating' when applying the brakes on your car ?
The brake pedal pulsating on the car I think happens to be the action of some primitive 90's era ABS (Anti-lock Braking Systems) because I ONLY experience those pulsating feedback when braking over loose surfaces like mud, sand, regardless of ambient temperatures OR when I'm using summer tires on wet roads and I'm skidding all over the road. It doesn't feel like a rotor warp but rather feels a lot like a mechanical feedback because it can feel pretty rough depending on the car model.
The pulsating seems to release the brakes intermittently and helps me steer when braking at the same time over loose surfaces. Before on 80's cars without ABS if I lock the front wheels, there's no way I can steer the car.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2581 Post(s)
Liked 5,637 Times
My new, 1 month old front rotor is already warped.
These are what I have been looking for. Thanks for posting. Will get an order in with my LBS ASAP.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
I have one of those -- just stuck it on my wife's bike. She drags her rear brake, and the crappy stock rotor turned multi-colored. This one seems to handle her abuse much better.
Multicolored means the brake rotor would have been glowing red hot (you won't see the glow unless it's night). You might want to inspect brake pads and the brake calipers as well. On long descents where I might have dragged the brakes like due to plenty of tight turns on the way down, I just sit in a more upright posture and unzip my jersey to create as much aero drag as possible. That helps reduce my speed without depending too much on the brakes.
Liked 1,877 Times
Hmmm. Never did.
I mentioned a different type pulsating - pulsating due to warped or glazed rotors - fairly common (especially for those that often brake late / hard)
Liked 1,877 Times
Liked 3,434 Times
Grupetto Bob
Liked 5,637 Times
I can't imagine warping the brake rotors of a car, they are much thicker, especially the front disc.
I seldom do hard / abrupt braking on the bike and never for no reason. If did, it's usually for motorists who cut me off and stop right in front of me on the bike lane. Even then, I don't brake hard enough and in few cases, I left a dent in the car's body work. They probably deserved it anyway!
Liked 1,877 Times
Likes For t2p:
Liked 3,434 Times
Likes For Polaris OBark:
Quoted: 800 Post(s)
Liked 512 Times
I am up for warp resistant rotors. Where I live we have a LOT of mountains/hills. On those descent my rotors, specifically my front, tend to warp. Of course once they cool down the rotors return to their normal state. But sure. I am interested in more warp resistant rotors. Would I pay more for them? Probably not.
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 463 Post(s)
Liked 546 Times
The IceTech rotor on the back of my tandem did warp. Replaced it with a vented Hope rotor which has been just fine.
The vented Hope rotors are thicker than most bike rotors and are interested for use with the V4 calipers..
