Totally Tubular
#2376
Quoted: 830 Post(s)
Liked 2,110 Times
I have a similar "French" challenge. The wheel in question is a rear Roval and I actually broke two spokes on the drive side when the RD decided to come loose from the hanger and was sucked (with the chain) into the spokes at about 15mph. Since the broken spokes were about 100 degrees separated, I decided to remove the tire and tape completely.
The original spokes seem to be unobtanium. They are straight pull, bladed, and have a unique head and 1.8mm threaded unique nipple. As best I know, the Roval nipples must be used with the Roval rims.
I've not been able to find any compatible replacements. I've attempted to modify a similar modern spoke and had success with re-shaping the head. However, it is threaded 2.0 mm. I tapped the nipple to 2.0mm but the nipple refuses to thread onto the spoke. I tried to cut new threads on the spoke, but with no luck. Frustrated, I set the project to the side in May, and have been busy moving south ever since.
Modified spoke head on left next to original Roval spoke on right.
The unique Roval nipple.
What's the length of your Roval spokes? I do have some extra Robergel French-threaded (1.8mm) spokes and nipples in my stash. If I have a matching length, and you think you might be able to use/reshape them for your project, I'd be happy to send a couple your way.
#2377
Quoted: 1946 Post(s)
Liked 2,004 Times
obuckler Try a pair of vise grips or clamps to restrict the air flow and move them along methodically to locate the leak.
#2379
Quoted: 4792 Post(s)
Liked 3,918 Times
Second flat - a roofing nail clear through the tire twice (and I am sure the tube also) and through the rim bed! (Deep rim so it didn't reach the inside TG.) First road ride ever on that wheel. Velodrome wheel picked up cheap of unknown history. From Bike Central owner's stash of velodrome wheels and rims; the shop having been closed for years and the velodrome (Alpenrose) now gone.
In that stash, a gem. Gold pair of Miche double sided track hubs, Gel330s, butted, tie and soldered spokes. Warmup (and showcase) wheels for the Nats for a woman I consider a sister. (We share fights back from injury to racing form. Also the best ally I've ever had for getting odd fix gear parts.) These wheels are literally gems. Absolutely beautiful and perfect. Built by the best. Neatest tie and solder I've ever seen. They have track rubber now but will get Corsa Speeds when it's time. Get re-spaced to 126 with a touch of dish and go on my freshly painted Mooney for very special occasions. My first ride will be the first time those rims have ever seen brakes. And every ride, I'll think of Jen.
Likes For 79pmooney:
#2380
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4336 Post(s)
Liked 2,977 Times
#2381
“Senior” Member
yes. I found the leak with a water dunk. But it exhibited out a random area of the sidewall that was not the puncture location. No puncture to be found. Used a glass looking for any sign of one to to avail. Especially for this pesky small wires that cause flats now and then. Will be a bit before I get back to this.
I am really irritated by the tube sticking to the tire carcass because of the excess seam tape glue seeping inside the tire. That meant I couldn’t pull a healthy amount of tube out from the five inch unsewed section.
#2382
Quoted: 2337 Post(s)
Liked 2,813 Times
doesn't that prove it the tire is guilty of witchrcraft or not?
Likes For squirtdad:
#2383
Quoted: 261 Post(s)
Liked 346 Times
I installed a tubular tire for the 1st time yesterday. It was really messy but you got to start somewhere. I got glue everywhere the brake track on the rim. Is there any way to remove it without damaging the tire or rim. I can't just have the brake pads rub it off as I ride fixed gear with no brakes.
#2384
Liked 2,004 Times
Funny Grant40.
Today, I punctured on a rather significant descent. This is where tubulars excel and I came to a stop at the end of a bend without hitting the curb.
#2385
Bikes: many
Quoted: 1442 Post(s)
Liked 1,388 Times
#2387
Bikes: many
Liked 1,388 Times
Got some glue left? Spread it on a bit of aluminum (maybe an unused rim), let it dry, then try the acetone. Alternatively, apply to a paper towel and just rub carefully along the brake track. Unless you're just pouring it on the rim you're not going to bother the glue under the tire.
#2388
Quoted: 1607 Post(s)
Liked 2,214 Times
Both Acetone and Mineral Spirit's work. I just mounted a tire this morning.
The ride on Saturday experienced a flat on a Challenge Elite. Not too impressed with these tires but hey, they work. Max pressure is 105 psi. I had them at a lot more. My bad for not reading the label. I am use to pumping the Vittoria G+.
Tiny hole that could only be found in a water dunk and very slow. I didn't notice it until I went to do a t lane U tern. The front tire washed a bit but I was able to recover while watching the tire try to roll off the rim. It didn't.
There was enough pressure to ride it for 2 more miles before the rim started hitting the road surface on bumps.
At that Point I debated about filling it up with a cartridge or changing the tire. I still had about 5 miles to get home.
I decided to swap tires and save maybe one cartridge, thinking I would use two to get home, maybe.
Changing was really fast. A testament to using sew-ups. The spare is a Challenge Roubaix with a higher PSI limit.
These are 25mm tires that barely fit between the caliper shoes when they are released.
Now I have two tires to complete the repair. Its been over 40 years since I have done this. The last tire was sent to tire repair in FL.
I know this new one could be addressed with an injection. I just don't want to deal with the mess later.
Hopefully this is a butyl tube. Holds air for days comparted to the latex.
#2389
Liked 2,004 Times
I've had no luck with acetone or mineral spirits. I have had good luck with Citristrip adhesive remover which is kind of gooey and stays on the rim to soak and soften the Continental or Vittoria glues. Sometimes applying twice.
#2390
Quoted: 9 Post(s)
Liked 39 Times
I picked up an incredible deal on an older Japanese track bike and both the wheels are tubs.
On my other bike, another old Japanese track bike, I run Conti Gatorskin tubs in the rear and they seem really durable. Even with heavy city riding they've lasted for years.
I haven't decided if I want to sell or keep the new bike. The wheels are Suzue Pro Max high flange hubs with Wolber Super Champion Aubisque tubular rims. I love the look of them.
If I keep this bike, it will be lightly ridden. But again, I'm not sure if I'm going to sell it. Regardless, I'm not spending $60 per wheel on tubulars.
2 questions....
-Here is a link to the Wolbers. https://velobase.com/ViewComponent.a...m=107&AbsPos=2
Am I going to have any issues trying to do a 25mm tubular on these rims or should I stick with 23mm? They're just a really small profile rim.
-Is there any current tubulars that are somewhat decent that I can pick up for less than $100 a set? I'm tempted to just throw on Panaracer Trainers or Vittoria Rally that I could get for $75 a set. If I bump my budget up to $100 (for a pair), is there anything significantly better?
Thanks.
2 questions....
Thanks.
#2391
Liked 3,918 Times
#2392
Liked 2,004 Times
Continental Sprinters can be had for that at times on sale and they ride much better than Gatorskin Sprinters. I might ride Rally’s again if they were free. I don’t know about the Panaracers.
25s will be fine.
25s will be fine.
#2393
Quoted: 9 Post(s)
Liked 39 Times
Thank you for the response. Looks like I can do a pair of Sprinters for around $100.
BTW, any reason why tubs are so much cheaper in Europe? Like every time I come across a model I'm looking for, it's almost 30%+ cheaper but then I see the "tyres" in the title.
Like it's not even close to US online prices.
#2394
Liked 2,214 Times
I -Is there any current tubulars that are somewhat decent that I can pick up for less than $100 a set? I'm tempted to just throw on Panaracer Trainers or Vittoria Rally that I could get for $75 a set. If I bump my budget up to $100 (for a pair), is there anything significantly better?
Thanks.
Thanks.
I still have the 3/50 from Yellow Jersey running on my infrequently used Colnago (frame is a bit small). They are just enough to get by. One is in the queue for being sewn up.
I have settled on Vittoria G+ series. They were often on sale and provide a really good ride. With the supply chain issues and inflation, they may be way out of your range, as many might be.
In any case, I would rather run sew-ups than clinchers.
#2395
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 386 Post(s)
Liked 691 Times
Shipping might be a bit though, but perhaps you can amortize that across multiple purchases.
#2396
Quoted: 9 Post(s)
Liked 39 Times
If you're ok with black sidewalls and 30mm width, the Corsa Control G2.0 are on sale for $45 here: https://www.merlincycles.com/en-us/v...0c-177989.html
#2397
Ellensburg, WA
Bikes: See my signature
Quoted: 313 Post(s)
Liked 457 Times
Sprinters are my go to tubular. I'm running Sprinter Gatorskins because of all the fresh chip seal roads around me. They are pretty rough this year. Might have to move to a few more sets of them. I usually buy on sale also for $98 for two. Still running mostly 22 mm tires because those are the ones that are typically on sale. I have one set of 25's of the Sprinters but haven't been able to use them yet.
1984 Gitane Tour de France; 1968 Peugeot PL8; 1982 Nishiki Marina 12; 1984 Peugeot PSV; 1993 Trek 950 mtb; 1983 Vitus 979; Colnago Super, mid-80's Bianchi Veloce, 1984 or 85 Vitus 979
#2398
Liked 2,214 Times
@Regulatori - tubular tire sewup tire Servizio Corse $19.95 tubular tires at Yellow Jersey; possibly the Best Value Tubular In America for 2022!
#2399
Old fart
Quoted: 3583 Post(s)
Liked 3,396 Times
Yes, the YJ Servizio Corse tires are a good value, even if the price has gone up (I bought them at 3/$50 some years ago). My only complaints are the somewhat narrow width (21.5mm) and non-removable valve cores, though that apparently has changed.
#2400
Quoted: 2432 Post(s)
Liked 638 Times
Likes For Lazyass:
