The Cult of CAAD...
The Cult of CAAD...
Old 12-04-17, 06:51 PM
  #10101
bottles
Originally Posted by decisivemoment
Just give me a Cannondale with a threaded bottom bracket . . . I'll grudgingly take pushfit but I really don't like the idea of BB30 and I do like Shimano cranks.
This is why I still can't move on from my CAAD9.
#makebottombracketsthreadedagain
bottles is offline
Old 12-04-17, 07:17 PM
  #10102
bottles
That being said I've finally met the quota to post an image
bottles is offline
Likes For bottles:
Old 12-05-17, 07:42 AM
  #10103
Wspsux
Bikes: Waterford, Salsa, Rivendell
Quoted: 218 Post(s)
Liked 26 Times in 14 Posts
Dope purple!
Wspsux is offline
Old 12-05-17, 04:02 PM
  #10104
J.Owen
Quoted: 16 Post(s)
Liked 25 Times in 8 Posts
raad.
J.Owen is offline
Old 12-24-17, 04:38 PM
  #10105
jontg428
Quoted: 15 Post(s)
Love that color! I guess that the CAAD 9 was the last CAAD model built in the USA then I take it? Really like the "Hand Made in the USA" call out on the rear triangle, looks dope!
jontg428 is offline
Old 12-25-17, 09:53 AM
  #10106
Banzai
Jet Jockey
Banzai's Avatar
Bikes: Cannondale CAAD9, Ritchey Breakaway Cross, Nashbar X-frame bike, Bike Friday Haul-a-Day, Surly Pugsley.
Quoted: 382 Post(s)
Liked 29 Times in 25 Posts
Sadly, my CAAD9 is BB30. But the next time it gives me problems, a threaded sleeve adapter is going in. The problem with the new Cannondales is that they're BB30A, which is a 73mm shell...that means you can't even put a converter/adapter in it.
I'm convinced that Cannondale invented BB30A so people would quit converting their frames from BB30 to English threaded.
Good night...and good luck
Banzai is offline
Old 12-25-17, 10:09 AM
  #10107
Metieval
Metieval's Avatar
Quoted: 1218 Post(s)
Liked 298 Times in 214 Posts
I had one issue with my alloy synapse BB30, when they shoved it in, there were AL. shavings peeled up and touching bearings. Took it apart, broke those shavings off, lubbed my spindle put it back together and never had a creak again until I put bike away wet. the spindle had corrosion it, wiped it off relubbed and was perfect! any bb and and bike will creak with dirty water dried leaving residue behind though. as in no different than dirty water down the seat tube and drying between your seatpost and seat tube.
I want a CAAD9 bb30 road frame for the purpose of using Beer components eccentric BB and I want a CAAD road SS with vertical drop outs. without all the seatpost tube FD bolt on ugly.
Then again I moved to hi-mod supersix DI2 disc brake for a road bike. A light weight AL framed SS road bike just seems redundant. So maybe I want a caad9 cyclocross singlespeed. as an additional bike < better choice super light TRP carbon cantilever, and not limited on tire choice.
Edit CAAD9 X SS like this
https://www.pedalroom.com/bike/2008-...aad-9-cx-24098
Metieval is offline
Old 12-26-17, 09:44 AM
  #10108
bottles
Yep. CAAD9 was the last US made CAAD. This one in particular was the very last year of the CAAD9.
I'm always on the lookout for another CAAD with a threaded BB to replace this one if it should ever die.
bottles is offline
Old 12-26-17, 12:15 PM
  #10109
Triplecrank92
Bikes: '93 Cannondale R500; '88 Centurion Ironman Expert, '97 Cannondale R900, '95 Serotta CSI, '83 Trek 700, '97 Lemond Zurich, '89 Bianchi Giro, '87 Schwinn Prologue, '83 Fuji TSIV + one perturbed wife
Quoted: 71 Post(s)
Liked 154 Times in 58 Posts
Can an old timer play? A 1997 CAD3 R900
File Type: jpg
Triplecrank92 is offline
Old 01-05-18, 05:33 PM
  #10110
SirHustlerEsq
Quoted: 52 Post(s)
I'm back with a CAAD12:
https://imgur.com/a/QSba9
Coming from a 2015 Evo to this, I'm super impressed. I think it does everything better than that bike, great bike, would buy again. Looking forward to denting the top tube in the near future.
SirHustlerEsq is offline
Old 01-07-18, 08:19 PM
  #10111
jontg428
Quoted: 15 Post(s)
Was thinking of getting a Super 6 Evo in the future, is that bike an upgrade or do you like your CCAD12 better?
jontg428 is offline
Old 01-07-18, 08:49 PM
  #10112
duckit
duckit's Avatar
Bikes: Building
bb30 hollowgram SL crank + 104 or 109mm spindle
good day all
im building my 2015 caad 10 bb30 / 68mm shell width
would like to share my case and see if you guys has any input
i had purchased a bb from c-bear product code pf42-30-r to act like a " pressfit " bottom bracket with internal cups to prevent the irritating creaks. its something i want to explore and so C-bear claimed it will aid to prevent creak.
i had purchased an used hollowgram Si spidering crankset with 175mm crank-arm taken off a bb30a bike and it came with a 109mm spindle.
as the 175mm crank arm will seems too long for my inseam, i also purchased a 172.5mm hollowgram SL crank arm that came with 104mm shoulder spindle.
i guess theres probably two ways to do it
method A - use the 109mm spindle + 172.5mm SL crank arm with 7.5mm spacer on the NDS ( apart from the 2.5mm on the DS + 1-3 x 0.5mm shims + wavy spacer on the NDS )
method B - use the 104mm spindle + 172.5mm SL crank arm with no additional spacer ( usual 1-3 x 0.5mm shims + wavy spacer on the DS )
so my questions would be
1) which model crankset / crank arm actually had the geometry changed on the NDS crank arm ( assuming Si and sisl2 onwards ? )
2) with method A - i probably will get a decent chain line but not on the Q factor
3) with method B - i probably will get a decent chain line and Q factor ? since the SL crank arms is meant for the 104mm spindle and 68mm bb shell width ?
Thanks for looking !
duckit is offline
Old 01-07-18, 09:14 PM
  #10113
Metieval
Metieval's Avatar
You both might find this interesting
https://cyclingtips.com/2017/01/cann...arison-review/
Metieval is offline
Old 01-08-18, 06:57 AM
  #10114
SirHustlerEsq
Quoted: 52 Post(s)
Yeah, but that's a comparison to the Hi-Mod Evo and the CAAD12, not the pleb-Evo. My girlfriend rides a current model Evo with 105 and these two frames are pretty different.
Old 01-08-18, 08:51 AM
  #10115
Metieval
Metieval's Avatar
key word being "interesting" with the focus being on too identical bikes from same manufacture, with the differences being in comparing CAAD to carbon.
Metieval is offline
Old 01-08-18, 09:47 AM
  #10116
memebag
Bikes: 2017 Cannondale CAAD12 105, 2014 Giant Escape City
Quoted: 820 Post(s)
Liked 6 Times in 6 Posts
That reviewer preferred the CAAD12 to the Hi-Mod Evo, so they would most likely prefer it to the normal Evo.
memebag is offline
Old 01-08-18, 01:21 PM
  #10117
Metieval
Metieval's Avatar
I will assume that he didn't actually read the review.
Metieval is offline
Old 01-08-18, 03:55 PM
  #10118
SirHustlerEsq
Quoted: 52 Post(s)
My point exactly.
Old 01-09-18, 05:35 PM
  #10119
drock79
Bikes: 1980 Trek 412, 1985 Fuso FR1, 1986 Lotus Legend, 1990 Vicini, 1998 Klein Quantum Race, 1998 Gary Fisher Wahoo, 2007 Bianchi 928 Lugged, 2020 Trek Emonda SLR Project One, 2022 Wilier Jaroon
Quoted: 16 Post(s)
Liked 39 Times in 10 Posts
Originally Posted by cabac
2016 CAAD12 Sram Red22
NICE CAAD12!! How deep are your Boyd's? LOVE my 34mm deep Boyd Tubulars.
drock79 is offline
Old 01-11-18, 01:04 PM
  #10120
SirHustlerEsq
Quoted: 52 Post(s)
So, I forgot to ask if anyone else recieved a headset compression plug that does not fit into the steerer? I tried the one from my previous Evo and it didn't fit either. I ended-up getting another from a friend at Cannondale which is a departure from the old design, but I miss that old design and would like to keep it, might provide some protection in a crash. I've broken 9-bones in just four years so that's important to me, lol.
Old 01-11-18, 02:04 PM
  #10121
Hapsmo911
Hapsmo911's Avatar
Quoted: 88 Post(s)
Liked 34 Times in 18 Posts
Not sure what your personal problem has been. I got a new 2018 Caad12 frame set. I went to install the plug and the cap didnt fit, it was too big (ribbed version). Neither did the older style cap (non ribbed version). I ended up sanding the newer cap down to make it work.
Hapsmo911 is offline
Old 01-11-18, 02:09 PM
  #10122
SirHustlerEsq
Quoted: 52 Post(s)
Would floss.
Old 01-11-18, 05:33 PM
  #10123
SirHustlerEsq
Quoted: 52 Post(s)
Gum walls came in today:
Old 01-14-18, 07:24 PM
  #10124
cabac
[QUOTE=drock79;20100473]NICE CAAD12!! How deep are your Boyd's? LOVE my 34mm deep Boyd Tubulars.
My wheels are 44mm. A good all-round set for general racing. Thanks
cabac is offline
Old 02-04-18, 03:22 PM
  #10125
Bumnah
Quoted: 11 Post(s)
Got 'em mounted up and out of the way:
Bumnah is offline
Likes For Bumnah:
