Your favorite road tubeless tires
#176
Quoted: 736 Post(s)
Liked 412 Times
I have not had good luck with the Schwalbe tyres. I've tried many flavours of them, and none of the tyres have a long life expectancy. So far my longest life tyre has been the Giant Gavia AC0. Thank you DrIsotope wherever you are. After that, the Veloflex Tubeless tyres have been my go-to. That said, I am giving the Michelin tubeless tyre a try right now just to mix it up a little.
#177
Quoted: 1691 Post(s)
Liked 1,812 Times
Likes For PeteHski:
#178
Bikes: Speedvagen Steel
Quoted: 408 Post(s)
Liked 204 Times
WhyFi cant seem to find those Michelin’s you mentioned and think I need to order something to have at the ready, current tires are starting to square off.
What’s your pref (or anyone else’s) between the Pirelli P Zero Race SL or the Schwalbe Pro One Addix? I was thinking of trying 28mm but Pirelli would be 26mm
ive done the old Pro One’s circa a few years ago but not the Addix variety
#179
Quoted: 20028 Post(s)
Liked 8,632 Times
Likes For WhyFi:
#180
V8s all day
Bikes: Lynskey Helix
Quoted: 97 Post(s)
Liked 149 Times
robbyville , I just broke 4K miles on the Helix and the Addix 30c are just about ready to be swapped out. I set them up tubeless from day 1 and they've held up quite well. I never flatted and as a long time user of Schwalbe tires, these didn't disappoint. My only takeaway is for the last 800+ miles or so, I've had to air them up more than a couple times than I was used to. But considering what I've gotten out of them, I'm still going with another pair but downsizing to a 28c or maybe even a 25c.
"I may think I have inalienable rights to be alive and happy but I don't - life is a blessing." -Terrence McNally
#181
Quoted: 408 Post(s)
Liked 204 Times
#182
Quoted: 408 Post(s)
Liked 204 Times
Well to follow up, by the time I was done with shipping and what was "actually" in stock I decided to go with a pair of the Specialized Turbo Rapidaire's to try. Seem widely well liked, top 10 in rolling resistance (off by one watt or so over best race tire), and reviews well from a puncture resistance stand point. Hope to get them in the next week or so.
We shall see!
We shall see!
#183
well I can tell you my least favourite tubeless tires…. Pirelli P Zero Race TLR…
to be fair, this is a sample of 1. I got these to replace my tube setup but they only retain about 40psi after 24 hours.
i sort of expected that tubeless would either work, or not work. instead these things pump up to whatever you want… 60, 80, whatever… no hiss no fuss… next day? down to 45. a week later? still 45. I don’t get it.
#184
Liked 8,632 Times
#185
The Pirelli tires are not the problem. Mine work great with orange seal endurance. Very little air loss.
#186
Liked 8,632 Times
#187
Shawn of the Dead
Quoted: 274 Post(s)
Liked 438 Times
I love the GP5Ks I put on my Domane. Great ride and seem pretty fast. Now that I know the technique I can get them mounted with very little fuss. The front I put on recently required no tools and no lube on the bead. I had to use a touch of soapy water on the rear bead and upped my hand strength to silverback gorilla levels. Still no tools.
#188
Quoted: 736 Post(s)
Liked 412 Times
Well after just over 9,000km on my front Veloflex tubeless tyre, I had to put two plugs in it on the weekend. The tyre, with plugs, will air and I rode another ~200km with the plugs in the tyre. But I was feeling skitterish about having plugs in a 9,000km tyre and decided to replace the tyre with the Michelin Power Road TLR.
Upon taking off the Veloflex, there is still treads showing on parts of the tyre. And no cords coming through. Make me wonder if I couldn't have continued to ride on the tyre, were it not for my fear of the tyre failing. But really the tyre showed no signs of potential failure.
So now I have Michelin's on the front and back. Comments based on my first ride with a matching set of boots? Nice. Bike rolls well and the tyres seem to hold air better/longer than the Veloflex. These might become my new tyre of choice, although I have some Veloflex tyres in stock at home here I need to work through first.
Likes For NoWhammies:
#189
Quoted: 849 Post(s)
Liked 340 Times
We shall see!
We shall see!
My only complaints are that it's a bit stiff and the tread isn't wide enough for wide rims at low pressures if you're really tipping it over. But that seems to be par for the course for modern tires that are more concerned with drum RR than real-world riding.
What are your thoughts so far?
#190
Quoted: 5 Post(s)
I used the Bontrager hard case lite 25mm on my aluminum wheels for about 1k miles and no issues thus far, it's my backup setup. I've got cf wheels with schwalbe pro one addix 25mm and after about a month I had to plug the rear one. Two weeks later another cut that would not seal so I got replacement one in 28mm hoping more rubber would help. It didn't, after 2 weeks I got a cut that would not seal and plugged it just to get another one after 2 more rides. That was it with schwalbe pro ones for me. Now I got pirelli race tlr 28mm but not enough time on them to judge yet. All I can say the schwabe pro ones felt better riding but if these pirellis are more puncture resistant I'd have to settle.
#192
Quoted: 1964 Post(s)
Liked 223 Times
I just set up some american classic 30mm and they were a breeze, inflated and seated without sealant to start. They have a coating to prevent seeping through the sidewalls and come in tan(brown) versions. Only have a few rides on them but they feel grippy and fast compared to the vittoria rubino pros I had on prior.
Likes For redlude97:
#193
Liked 8,632 Times
I've been eagerly anticipating this - next gen Vittoria Corsa tubeless that are up to ETRTO spec and hookless compatible (28mm - 34mm sizes) -
https://bikerumor.com/review-vittori...n-performance/
I still have a new Pirelli waiting on a shelf, to be mounted on my rear wheel whenever the first finally gives up the ghost, so I probably won't get to these Corsa until next year, but I'm looking forward to it (assuming that I can find them at a decent price).
#194
I definitely roll faster than anyone else in my riding group who are all on clinchers. Maybe because I’m fatter than they are? I choose to think it’s the tires! One of the other guys also has a Madone with Ultegra and he’s going tubeless shortly so if he’s rockin’ a different brand I’ll let y’all know if I’m still out rolling everyone!
Also, I just got my first tubeless puncture!
Performed as advertised for all those still in the tubeless denial camp. Went Pssst like a grade school kid passing note, spat out sealant for about an eighth of a revolution and that was it! Started the ride with just over 80psi and was still 80 when I got home!
Likes For Overdraft:
#197
Quoted: 99 Post(s)
Liked 50 Times
Yes. When I mount my tubeless, I do a dunk test to see if air is leaking from the seat and also from the spoke joints and valves. I've found imperfect valves and valve cores also contribute to slow leaks.
One thing users may not be aware of is that some specialty wheels have max pressures for different tire sizes. My Hunt 50s have a max pressure of 70psi with 30-32mm tires. When I put the 34mm on, it's recommended max pressure is 50psi.
