Cheapman Finds a $25 Bike!
I'm a notoriously frugal individual. I ignored all advice on here and bought the cheapest working bike I could find. A 7 speed Ozone Westcliff 700 for $25. My guess is the guy bought two bikes, ride them once or twice with his s.o. and out them in his garage for 3-4 years. After cleaning off about an inch of dust and dirt, they look basically new. Brakes needed adjusting and the wheels look like they were never put on right as they were rubbing hard against the fork and frame, respectively.
Brakes squeal like a ***** pig despite my cleaning them with soap, water and alcohol...any suggestions?
Other than that it's a very SIMPLE bike. No quick release anything. Surprisingly light and nimble!
Derailleur is, I'm sure the cheapest Shimano makes but it works smoothly.
I'll try to update if it falls apart and what fails first. There certainly are some things that look pretty cheap...plastic pedals, plastic brake adjusters on top. Some spokes seem looser than others but the wheels seem pretty straight and true so I don't want to mess with them.
Likes For LifeNovice1:
I'm thinking this was bought at Academy sports, don't know if that's as bad as Walmart or not.
One question though....there look to be holes near the drop outs for a rack, but there are no braze ons near the seat post. Does anyone make a rear rack for this kind of bike or do I have to get a seat post rack. Those look kind of rickety.
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 565 Times
Depending on which type of brakes it has ... assuming it's basic V brakes, consider the appropriate Kool Stop pads for it. I've used them on several different brakes and they have worked exceptionally well. Smooth, low risk of squealing (when adjusted properly).
Quoted: 5888 Post(s)
Liked 3,471 Times
A lot depends on what kind of brakes the bike has.
Liked 3,471 Times
P clamps will work for the rack.
You could try taking a file to the brake shoes. Also can the shoes be angled or toed in? That helps with squealing.
Pennylane Splitter
Bikes: Yes
Quoted: 1796 Post(s)
Liked 1,439 Times
Take the brake pads off and try using a file/sandpaper on the contact surface to roughen it up a little as that surface might be hardened with age, or the pads are so new they still have the 'sheen' on them rom being molded. Last resort is new pads.
Koolstop pads - I tried those once, never could get them to stop squealing like a terrified pig and I didn't think they stopped the bicycle any better than generic pads. I replaced them with generic black rubber pads that work fine and don't make noise. YMMV
Thanks for the suggestions! There is very little room to "toe out" the brakes but I did try as best as I could. Unfortunately my file is in storage. Worse comes to worse I'll replace the pads. Or I'll just live with it....I'm 51 years old so looking/sounding dorky doesn't really bother me.
Quoted: 1062 Post(s)
Liked 665 Times
I just replaced a set of kool stop salmon pads because they were squealing, even after "doing everything right." My guess is they will work perfectly on the next bike, so they went back into my bin, and the bike now has some generic black rubber pads. Given the popularity of the KS pads, I can't believe there is actually anything wrong with them. Nobody knows the precise cause of squealing, so the best approach is to first try "doing everything right," and then start changing things.
Also, the age of the pads is kind of on the edge of where they could be hardened by natural aging of the rubber material.
Quoted: 18410 Post(s)
Liked 15,530 Times
Quoted: 6963 Post(s)
Liked 10,961 Times
In 15 years, the bike had over 40,000 miles on it, and definitely qualified as frugal.
No way would you get that kind of value from a cheap bike.
Likes For Koyote:
Quoted: 2700 Post(s)
Liked 486 Times
I love squeaky brakes, lets people know you are there! I have an older bike with a front brake so loud that I use it instead of my bell and hardly drop speed. Ride the bike into the ground
N
I'm sure it's a great bike but for $1000 I can buy 40 cheap bikes. I can get a new one every year and still be way ahead by year 15. I'm a casual, around town rider/commuter so I doubt I'll ever use a 1000 dollar ( now 3000 in today's dollars?) to anything close to it's full capabilities.
Liked 10,961 Times
By the way, $1,000 in 2003 had the same purchasing power as $1,451 has today.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Not sure how you know my bike is cheap or nasty. It rides great. Thanks for the well wishes.
Also thanks for correcting my off-the -cuff estimate with the exact inflationary data. You must be a really fun guy at parties. God bless.
I'm wondering if the Ozone Westcliff is the same bike as the Mongoose Hotshot, which is a big-box bestseller of sorts. They look very similar. The Hotshot is a simple, decent bike for getting around town (I rode one while visiting Gallup once), with the same brake pad issues.
(Issues that are, of course, fairly common among caliper-brake big-box bikes.)
Likes For Dchiefransom:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
You get what you pay for and there is no need paying for more than you need I guess. Bikes make people happy and if you can do it for 25 bucks more power to you.
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,986 Times
I love a properly working bike that isn't poorly set up and in need of service but maybe that is just me and well just about everyone else here. If you don't "drop speed" when using your front brake that is BAD and you could not stop at all and potentially get very badly hurt or die, Troll or not people shouldn't die over not maintaining their bike because they are cheap (not frugal this is not frugality) or think it is a great feature. A Chris King or I9 hub is a better option if you want to make extra noise.
Expired Member
Quoted: 3665 Post(s)
Liked 5,417 Times
Yet another BSO thread. Are they somehow linked to cicadas?
Likes For shelbyfv:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Like saying why buy a $25,000 touring sedan (think, Honda Accord) when I can buy 50 cars for $500 each, and simply discard them as they stop running. The diving experience? Um, not so great.
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
Depending where you live, it's impossible to sell a good old bike. I just gave away a 1981 Raleigh, in perfectly good condition after no bites at $100 listing on Craig's list. I'd have loved to have a bike like that when I was in college.
Quoted: 1819 Post(s)
Liked 1,693 Times
Just trying to wrap my head around the amount of work (and money) needed to make 40 $25 bikes rideable. Would rather have a bike that I can ride as much as possible
