Old Brooks salvagable?
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
I was just given an old '70's Turin Chicago 10 speed in about as bad of a shape as a bike gets.
Rusted , but ridable, $50 bike that needs $150 worth of parts and at least a day. Moving parts ok if needing a deep cleanse and rotted rubber replaced.
It has an old Brooks that is hard as a rock.
I was thinking of maybe giving it a neatsfoot soak, but was wondering if anyone had tips for giving it anything resembling what it once was.
Sad because it once was a nice bike.
Thanks
PS sounds like the neatsfoot is a BAD idea. This thing is not deformed but is Cardboard/plastic hard.
? "Boiling"/ wetting? or is that just for new leather to shape?
It looks to be in decent shape, is not deformed and works as a rigid saddle.
Old horse saddle care with Obenauf's seems like a decent move from the
"How to save a Brooks Saddle? Worth Saving?" thread. It seems most of the ones they talked about were deformed (wings spread)
Thanks
From what I've gleamed on different BF threads on the subject, soaking a saddle in anything is a last resort for saddles that are on their last legs. Its supposed to be hard so if thats your only problem then you're probably fine. Leather saddles get their comfort from their ability to conform and fit your sit bones like a mold and not so much from being squishy or soft. If the surface is looking rough and dried out a good coat of Proofide or mink oil or some other leather conditioner would definitely help. Are there any deep gouges or cuts? Hows the adjustment screw at the nose? If its all the way extended that could also be an issue, as the leather can be stretched too far. A pic or two would help.
Likes For degan:
Quoted: 1372 Post(s)
Liked 1,751 Times
Get some Proofhide and lather/rub into top and under sides. Put the saddle in a plastic bar, dark color preferred, and place it in the sun. The sun will warm the whole works up, allowing the leather's pores to expand in size, making it easier for the Proofhide to soak in. After a day or so, repeat a time or two. Polish the saddle with a soft dry cloth afterwards and hope for the best. However, is the leather is all cracked up, nothing much will help.
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
Pics are needed.
Likes For clubman:
Quoted: 172 Post(s)
Liked 95 Times
Thanks , guys. Pics are fragmented, but light was bad. It gets the idea across, and I can get more if needed
Rust extensive, but seems superficial. Leather smooth , not cracked or dusty,but is hard
Bike garaged, doesn't appear to have direct water damage, but as dirty as any garaged bike I have seen.
Other than the rubber parts it works.
I feel like Magic Max from Princess Bride, "I seen worse."
It seems like a gentle humidification and light coatings of mild oils/ beeswax, like the bag suggestion, may give it something of a chance.
Don't think it will ever be Brooks like again, but looks usable
. The equestrian saddle guys see this kind of stuff a lot, apparently, and hate to work with it, but they get stuff that gets stressed, like reins that can't fail
Likes For bikebikebike:
Phyllo-buster
Liked 2,054 Times
I don't think that looks too bad at all, it still has it's shape. Wipe it clean and put some proofide on it and buff that puppy. Then you'll know if it needs something more dramatic.
Likes For clubman:
Quoted: 339 Post(s)
Liked 632 Times
I have accumulated a number of old saddles doing resto for the Bike Exchange. A while ago I read a post from someone who soaked and reshaped an old Brooks and decided it was worth a try. The one I chose was not rideable, it's side having flared out so it was almost flat. I filled the bathroom sink with warm water and submerged the saddle in it. almost immediately she leather became completely limp and pliable. I removed it from the water, patted it dry (ish) and took it out to the shop. Then I took some heavy string and wrapped it around the saddle pulling the sides back down and restoring it to it's original shape. I left it there in the garage for a while till it had dried out thoroughly, then removed the string. The saddle retained the new shape. The only problem was that the string had left marks in the leather where it was cinched down tight. At this point the shape was good but the surface of the leather was uneven, with some surface cracking. With nothing to loose, I got out the vibrating sander, put some 400 grit paper on it, and sanded the surface of the saddle. The result was a uniform Swede like surface to the leather. I then changed to 1000 grit and sanded again , resulting in a smooth but not quite shiny surface. Good enough. finally I Got out the Proof ride and coated the saddle top and bottom and then buffed the topsides. In the end the saddle looked almost new.
This should work if the leather on the saddle is not too cracked. If the nose area has substantial cracks doing this may cause it to tear off completely which will end the experiment. Also, if the saddle has deep cracks in the center the soaking may expose fatal weakening. If you have an old leather saddle that is unridable as it is why not give the soaking a try
P.S. I just did the above on another old saddle . this time instead of string I used 3m blue masking tape to wrap the saddle to avoid the string cutting into the leather. Works much better.
PPS. even if the surface is covered with cracks , try anyway. The saddle I just worked on has a terrible looking surface . After drying and sanding , most of that was gone. as long as it doesn't weaken the leather a good sanding will do wonders.
Quoted: 1856 Post(s)
Liked 664 Times
My view is, +1 on Randy's black bag approach to re-oiling the saddle - Use of Proofide rather than all of the other stuff that's out there, and +1 on gently warming the saddle. However here southern Michigan November has brought us almost freezing temperatures, though we have some sun, y'all!
But before that, I also agree with cleaning. First saddle soap with warmish water and a soft sponge to get off the loose stuff. If at that point you can see mildew, try repeating with a dilute bleach solution to kill the fungus. There are Internet articles about mildew treatment of leather - it can grow back.
Look for cracks, crazing, pulling at the rivets, and rust on the steel frame underneath. You could ust replace teh leather. List member rmayr is an expert at doing that.
The saddle looks like it might be an early Team Professional, due to the big rivets. I remember seeing those Turin bikes in the store but with cheaper parts, at least the ones that were plain steel tubing. Based on the parts and non-Reynolds frames, I equated them with Peugeot UO-8s, which only would come with Brooks Pro for a store upgrade. If you restore it to pretty good condition, it would be a very worthwhile saddle for any level of bike. If it is a Professional, it would say "professional" on teh side skirts.
Is everyone here afraid of saddle soap... Clean it (top and bottom), let it dry, condition it (top and bottom), polish/buff it.
Clean it because it is, well, filthy. Saddle soap is fine with a soft brush. It loosens the fibers, gets the dirt out, allows you to check its condition. Wipe it dry (microfiber towel), then let it it dry naturally.
Condition it. Proofide is probably best, it needs to penetrate the fibers but not soak through everything, The leather fibers are brittle and dry, you are trying to moisten them to allow them to flex and not break. IMHO, I would NOT use neats foot oil. It may take more that a couple of applications maybe a little heat to help it penetrate the fibers better. But don't leave it on forever thinking it needs to be soft and moist, it doesn't. Condition it, set it, polish and buff it out, check for pliabilty. if the leather is cracking (hear it), condition it some more. If you could still get the copper rivets I would be sorely tempted to drill and pull the leather off the frame so the leather under the frame could get a good treatment also, but you should be able to bring it back with some heat.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
When leather Brooks saddles were very popular many years ago in the states it was routine to drill out the factory rivets, treat the leather to soften it, and then remount it to the frame with new copper rivets. The "new" saddle was as comfortable as one that had been broken in with ones butt for a year. I still use the Brooks saddle that a friend processed 50 years ago on an equally old custom road bike.
The one I chose was not rideable, it's side having flared out so it was almost flat. I filled the bathroom sink with warm water and submerged the saddle in it. almost immediately she leather became completely limp and pliable. I removed it from the water, patted it dry (ish) and took it out to the shop. Then I took some heavy string and wrapped it around the saddle pulling the sides back down and restoring it to it's original shape. I left it there in the garage for a while till it had dried out thoroughly, then removed the string. The saddle retained the new shape. The only problem was that the string had left marks in the leather where it was cinched down tight. At this point the shape was good but the surface of the leather was uneven, with some surface cracking. With nothing to loose, I got out the vibrating sander, put some 400 grit paper on it, and sanded the surface of the saddle. .....
[after soaking] "If the side skirts are spread too wide, gently containing them as the leather dries is required. No force is needed, an old toe strap is traditional."
there would be no sanding required.
see the thread at https://www.bikeforums.net/classic-v...reshaping.html
But that is not required for the saddle for this thread.
A good brush down, then clean with saddle soap, then Proofide treatment should be all that is needed.
Liked 664 Times
Now if you had followed the instructions of
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
I agree with a gentle cleaning, followed by drying and then giving a few days for some Proofhide to permeate the leather, in a warm location.
What I've always done for a too-hard top ridge is to place a damp sponge atop the saddle some minutes before each ride, which simulates an hour of sweating on the bike.
Keep the sponge well away from the rivets and especially from the edges of the metal undercarriage, or else the rivet holes will stretch and the sharp edges of the undercarriage will be mirrored to the top side of the saddle. Both are very bad outcomes.
The moisture also serves to give a slippery saddle some real grip, allowing the rider to better keep their body positioned away from edges and pressure points. This makes the break-in period a whole lot more tolerable, while the moisture also accelerates the often-slower break-in period of the ridge area of the saddle.
As a last-resort, on saddles with still too "peaked" of a ridge, I've used a wood dowel to gently roll some flexibility into the top crest of the nose area, but again (as with the damp sponge), this working should be kept well away from the edges of the metal nose hardware underneath!
That saddle looks very good to me, I would definitely not mess with the riveting that is for sure.
Likes For smontanaro:
Quoted: 358 Post(s)
Liked 136 Times
I like your bike! It could turn into a nice Beater bike or something to ride around the bad parts of town. (No one would steal it.) As far as the seat, I agree what everyone has said. Soap and some Proofide and you'll be ready for the open road.
Quoted: 172 Post(s)
Liked 95 Times
My only concern is sorting out the pre-ISO bearing world.
I have the SheldonBrown break downs, but am still working out a way to identify parts for maintaining.
I have several bikes of similar vintage and the French Italian and British stuff has such an assortment of seat posts and bearings as to make keeping them in the game a challenge.
The seat is in its Proofhide balm spa treatment, and the cleanse and lube progresses as tools for the BB and stem disassembly are acquired
Quoted: 753 Post(s)
Liked 737 Times
I brought home a Brooks that is still soft but it is warped. I think the frame it was on was leaned up on some thing or upside down a storage unit for years. I reshaped it with my thumbs and it looks a lot better. I got to thinking though.. I had just about to throw out a trashed saddle out that the plastic and foam had delaminated from the plastic structure. The hard plastic is a very close match to a Brooks and I think that if I cut off the rails and split it in half I think I can get it under the Brooks leather with a bit of trimming. I'm a little hesitant to soak the saddle in water, but know that you can use alcohol to soften shoe leather temporarily in in more of a localized treatment, IE makeing room for little toes that were broken a few to many times...
two wheels is just right
I've seen videos of beatup vintage leather shoes being restored. I wonder if the same techniques could be used on a leather saddle.
I tried to save a rock hard Brooks Pro. First I tried Proofide, but it didn't really soften it . Finally I rluctantly tried neatsfoot oil, and did manage to make the saddle comfortable. and for a couple of months it was very comfortable, then it ripped near a rivet. So' maybe it might not be worth the time and effort.
I bought a Turin from the Denver store, and I still ride the B-17 it came with. I always kept it properly tensioned and used Proofide or Nikwax.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
The OP's bike has spent a period of it's life fully (or fooly) submerged! ARRGH!
I grew up in the heart of the Rust Bowl. I HATE RUST!!! I can smell it, taste it I even worked in a steel mill for a while...That said,
As far as the Brooks saddle goes, it doesn't look as bad as the rest of the bike... there's always hope...
Consider this saddle, someone was actually riding it! HaHaHa
snarky verktyg
snarky verktyg
Chas. ;-)
Chas. ;-)
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
It is really hard to judge the condition of old leather. I have an old Gretch archtop guitar, a lower end model from the 30’s, that I've had since 1982. It came to me with a thin leather strap that may have been original to the guitar. It's like 3/4” wide, not one if those phat straps that came into fashion in the 70’s. This strap was old when i got it and... well, almost 40 years later, I'm still using that strap with that guitar, and it seems fine. Apparently leather holds up damned well if stored in the right conditions.
As to OP's saddle, I agree that it doesn't need much, but what do i know. I am doubtful whether anything will actually soften it, but carry on, and let us know what happens!
verktyg
Liked 1,238 Times
Brroks Pro Follow On
That's a Brooks Pro Select from around 1979. They only made that model for a few years.
They were HARD as a rock and rarely got as soft as a standard Brooks Pro. Perhaps the initial hardness may have protected the leather?
verktyg not snarky
verktyg not snarky
Chas. ;-)
Chas. ;-)
Likes For verktyg:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 910 Times
Yes, quite salvagable. First, clean it well and let it dry. Then apply oil (I used Red Wing Boot Oil) while in the sun until it won't soak any more up. Then throw it in a tub of water for a few days. Then take it out and mount it, and as it slowly dries, take either a baseball bat (or a rolling pin if you're squeamish) to it several times over the course of its drying. Now you can break it in with 1000 miles instead of 10,000 miles. That method worked well for me.
IMO a saddle should have a slight saddle shape, not a level top. You probably have a whole inch of bolt left if you need to tighten it one day. Sitting on rock-hard saddles is for hard-asses.
Liked 664 Times
Thanks
Thanks
But I'm mainly interested in how the saddle effort came out!
