Bike Racks
Bike Racks
Old 06-03-22, 09:49 AM
parkbrav
Quoted: 220 Post(s)
Liked 114 Times in 97 Posts
Bike Racks
Hi, I'm an experienced winter cyclist and I am active on the winter thread.
I'm just wondering, how easy would it be to remove a rear tire (to install winter/summer tires) once a bike rack is installed on the rear?
Question is related to: if this would be an increased hassle, then I might also get a new bicycle designated just for summer and then install the rack on the bike designated for winter.
I asked this question the other day and no one had a clear answer so I thought I'd ask it here instead.
Thanks guys!
parkbrav is offline
Old 06-03-22, 10:25 AM
flangehead
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 390 Post(s)
Liked 572 Times in 332 Posts
I have 7 and 10 speed derailleurs and fenders on my 2 commuter bikes, both with rear racks.
They have zero effect on my ability to fix a flat.
I know this from a deep experience base.
flangehead is online now
Old 06-03-22, 10:31 AM
ratell
ratell's Avatar
Quoted: 18 Post(s)
Liked 37 Times in 27 Posts
The only way it would make any difference is if you had one of those racks for carbon bikes that use the thru-axle instead of rackmounts on the frame. In that case it would add some annoyance to remove the wheel, but given how annoying a flat is they would be the least of your worries. If your frame has rack mounts then the rack has no impact on changing a tire.
ratell is offline
Likes For ratell:
Old 06-03-22, 10:32 AM
Steve B.
Quoted: 3238 Post(s)
Liked 2,084 Times in 1,180 Posts
The rear rack on my tourer (Axiom) does not interfere with the QR on the rear axle. I can get the wheel off when needed. The fenders make it more of an issue pulling the wheel back on, if anything,
Steve B. is offline
Old 06-03-22, 10:48 AM
parkbrav
Quoted: 220 Post(s)
Perfect, thanks guys. You all just helped me avoid making a costly mistake.
parkbrav is offline
Old 06-03-22, 12:20 PM
pdlamb
Quoted: 2604 Post(s)
Liked 1,928 Times in 1,210 Posts
Ditto, especially the last part. Alas.
pdlamb is offline
Old 06-04-22, 07:34 AM
locolobo13
locolobo13's Avatar
Bikes: Trek Mtn Bike
Quoted: 282 Post(s)
Liked 2,641 Times in 948 Posts
My experience is a little different. Bought a rear rack, installed from the LBS. No probs, like it.. When the rear wheel is off the rack pulls or pushes, I forget which, the frame open/closed a little. To replace the wheel I have to push or pull to get the wheel back in. It's not much. Maybe 2 mm.
It's not really a problem when you know what's going on.
locolobo13 is offline
Old 06-06-22, 06:57 AM
pdlamb
Do you have a rear suspension?
pdlamb is offline
Old 06-06-22, 07:20 AM
locolobo13
locolobo13's Avatar
Quoted: 282 Post(s)
No. I think the rack is acting like a spring on the frame pushing it in. The wheel comes out easy enough.
Old 06-06-22, 09:18 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,581 Times in 2,342 Posts
awww shucks, you shud still get a new bicycle designated just for summer
rumrunn6 is offline
