Coasting vs applying power
Hey everyone
I just recently completed my 1st century on gravel. I did the 100 Mile course of Unbound. While examining my power data, I notice that I coasted about 30% of the time. No power. This has to have affected my completion time. How fo I break the habit of coasting?
It's not unusual if you're coasting on descents.
Breaking the habit of coasting is easily done with indoor training with resistance trainers or finding a route with very long continuous climb without any flat nor descending sections.
Using resistance trainer from 30 minutes to 1 hour continuously without reducing resistance to 0 would be good enough.
Likes For wolfchild:
just another gosling
Quoted: 3378 Post(s)
Liked 1,337 Times
I haven't ridden much gravel but my guess is that you really don't want to pedal until you spin out on gravel. Is 40 a little scary? If that's the issue and this is in hilly terrain, maybe you're doing it right? If not, then simply focus on shifting and turning the cranks. On pavement, even on descents, I like to see at least 50w on the meter, indicates that I'm at least making some effort at a good finishing time. And as in post 2, a trainer or rollers are nice for getting used to continuously turning the cranks. On many roller rides, I set my resistance so that I'm just below VT1 - where breathing rate increases - and just sit there and pedal at that resistance for an hour or two.
Results matter
Results matter
MotuekaCascadeChinook
Quoted: 4498 Post(s)
Liked 3,011 Times
Partly it's just a commitment you have to make with yourself to keep your legs moving. Also you might be pushing so very hard on climbs and cruising that you simply need to give your legs a rest.
I don't like coasting either. Unless I've gotten to a speed where I'm spinning a uncomfortable high cadence, I like to keep my legs moving. But when I am dead tired on a ride you will see me coasting more.
That said, I've found myself coasting more this year. So hopefully age isn't making me weaker.
Quoted: 17631 Post(s)
Liked 9,542 Times
Hey everyone
If you're coasting because you're uncomfortable, like your butt or hands, then fix that issue. If you're not comfortable at the speed, address that with practice or better tires or even bike geo. If you're tired and using coasting to recover, back off the pace so you can put out more consistent power. If it's terrain maybe it's ok.
Personally I prefer to soft pedal rather than coast on long easy descents, more to keep limber than for speed.
Quoted: 1604 Post(s)
Liked 1,321 Times
Nobody can say, we don't have enough info
Personally, I coast on long rides once I hit around 30 mph. I get down on the TT bars and rest, maybe eat or drink or scratch or open my jersey to cool down if it is hot. If you are coasting when going slow, I wonder if you are not comfortable?
Bikes: 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 3479 Post(s)
Liked 2,432 Times
As GhostRider62 said, we don't have enough info.
But coasting for 30% of the time on gravel sounds extreme. Except for descents, you can't coast for extended periods of time on gravel b/c the rough surface eats all of your momentum and forces you to add more juice.
You can clarify some of what might be going on by giving us some more information. Is your general technique something like pedal-pedal-pedal-coast-pedal-pedal-coast? If that's the case, you need to work on your technique. Apart from hills, turns, and momentary bike handling maneuvers, you basically never want to stop pedaling.
Doing the Unbound 100 is a heck of a way to begin with gravel centuries.
I can also bring less food and water but I'll have to slow my pace down, take it easy to make sure I get back home in good shape. If I didn't want to worry about pacing, then I'll bring as much food and water that I can. Pacing and adequate fueling can make the big different in long rides and may even improve your average speed despite bringing more load in food and water or simply taking the ride easy, no hard efforts unless absolutely necessary.
Liked 2,432 Times
On a mile century, I would have brought two 6L pannier bags. One bag full of ice cold water bottles and the other bag with one bottle of water and the remaining space with rice cakes. Over 20 lbs of weight in water and food I think. Typical in over 90F riding temperatures.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1535 Post(s)
Liked 1,482 Times
It's a combo of aerobic fitness, bike handling skills, and gearing.
If you don't have the gearing to do it, none of it matters. If you don't have the bike handling skills, having the gearing to do so will simply get you in trouble. If you've got the gearing and bike handling skills but not the aerobic fitness or pacing strategy ........you might over do it.
I have a 36 and 10-33 on my cross bike and ride gravel with that fine. I'll pedal until over 100rpm in the 36/10 combo then tuck.
Some gravel routes for events with lots of elevation very well may have significant portions where you coast down at no real time penalty.
In events like that, it would benefit you to work on how many sets of 20ish minute or so sweetspot intervals you can do in a ride. Zwift has the "steady state" short medium and long workouts. The "long" is 30min, rest, 30min, rest, 40min. Pretty much simulating riding at a high aerobic level repeatedly for long amounts of time.
That's how I would improve a time where coasting down is inevitable.
I did the "fake" Rouvy simulation of Mt Mitchell just under 2 hours, 2 hours of non-stop sweetspot power at a hair over 90% of ftp. In real life, that would be a LOT of time coasting back down from the top. Only way to optimize that time is the "up" portion.
Likes For burnthesheep:
On the subject of stopping for supplies. I prefer doing non-stop rides. I enjoy the challenge! And I have racks and panniers, might as well use it.
Liked 1,337 Times
Have you been diagnosed with hyperhyrosis? I've done a good bit of organized long distance riding. Even the heavy sweaters with whom I've ridden don't carry more water than do I: one bottle and a 70 oz. Camelback or only 2 bottles, even in hot weather. One has to stop about every 50 miles to pee anyway, so there's no reason to carry more water than 50 mile's worth. The hottest pass climbs I've done were 105° at the bottom.
Results matter
Results matter
I don't think I have hyperhidrosis. I only sweat slightly above average on a hot summer day if I'm only doing day-to-day activities, no exercise. Same thing if I'm doing recovery rides. The moment I hit zone 3 or zone 4 that's when I begin to sweat like rain. I think it's a good thing for me, at least I don't have to wet my shirt with water on a hot day. I happen to hate hot climates so the extra sweating helps.
My ancestors lived ~4000' above sea level in the mountains. We've visited our ancestral place and it never gets hot there even in the summer (temperatures can still drop to 50F even in June / July). One of our national tour champions lived in the same region. In fact, it feels like the climate is perfect for me. I suppose that would explain why several in the family sweats a lot in exercise like I do and also hates the heat.
Liked 1,337 Times
That's interesting. I never felt the need to pee on long rides. My bladder just never fills whenever I'm doing hard exercise. I'm probably "sweating" my pee already through my skin! That's why I don't stop if I can help it and mostly, it would be due to mechanical problems.
Results matter
Results matter
Likes For Carbonfiberboy:
Well, get out and ride in the hottest part of the day for an hour or two whenever you can. Riding in the heat helps more than anything else. Be sure you take electrolytes with your water, I use Endurolytes because they have a spectrum of electrolytes, not just salt. Like 100mg of sodium/hour something like that, maybe even more. I keep a coin purse of Endurolytes shoved up my shorts leg. Hammer also makes an extra-strength version to cut down on the number of capsules. Or you could move to the PNW and enjoy 60° like I had for my birthday ride yesterday.
Likes For koala logs:
Quoted: 1691 Post(s)
Liked 1,812 Times
