Where can I buy a Alero MO-BO ?
LR÷P=HR
Quoted: 866 Post(s)
Liked 1,204 Times
I want to mount a water bottle behind the saddle of my Cervelo R5.
All of the mounts I've found will not work on a Carbon framed saddle.
Oh it gets better, and my seatpost is not round.
The bike shipped with one of these below .... It replaces the rear saddle clamp and has a GoPro type knuckle for a camera or light.
Ideal solution is to hang the Alero MO-BO (see below) off the rear. But I can't find them for sale anywhere??
Anybody know where I can get one or it's equivalent??
Thanks
Barry
Thanks
Barry
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,986 Times
It gave me a warning to get to that website. I haven't seen anything that mounts oddly like that what saddle do you have? You might consider if possible getting a metal railed version of it, the weight is not an issue because you are adding a heavy mount with a bottle cage which is going to weigh a least a pound so a little saddle weight so you can mount normal triathlon bottle cage mounts would make more sense.
LR÷P=HR
Quoted: 866 Post(s)
Liked 1,204 Times
Security Cert on that site is expired... weird.
Carbon railed saddle is by Astute and sadly discontinued. I find it extremely comfy and purchased several of these while cheap on clearance.
Want one now... ebay & $500+ so I'm not changing any time soon.
The "odd mount" is not a function of the saddle, but an accessory mount that came as part of the seat post saddle clamp.
The mount is a standard GoPro mount and also used for some tail lights.
I believe this addition will add ~3oz to the bike (including the carbon bottle cage) and removal/replacement in under 20 seconds.
So my proposed setup makes a lot of sense to me.
I really wanted the MO-BO but I have found what I hope is a second best option.
If it turns out to be compatible I'll follow up soon.
Barry
Barry
LR÷P=HR
Quoted: 866 Post(s)
Liked 1,204 Times
So after careful consideration I decided not to go in the original direction.
The Cervelo supplied Saddle clamp accessory mount pictured above place the retaining bolt directly inline with the saddle rails.
I was unable to install, remove or tighten the bolt without moving the saddle fully rearward.
Given that this additional (third) water bottle cage is only required from time to time I mounted it a totally different way.
Better yet, the TOTAL WEIGHT added to the bike 37grams, yes... 1.3oz.
That is a 25gram carbon bottle cage, plastic hardware & 3 zipties.... done.
Barry
Barry
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I was sure the end result would be Velcro, probably a trouser cuff strap. I guess zip ties are pretty close. I’ve heard them called “millennial duct tape”
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
LR÷P=HR
Quoted: 866 Post(s)
Liked 1,204 Times
I get some credit....I avoided Duct tape !!!
Though, I did use Self fusing silicon tape to stop it creaking!
That tape is awesome, Sticks like _ _ _ _ to a blanket, but only to itself, and comes away clean.
It's my go to stuff for bar tape finishing.
Barry
