Denver??
Quoted: 455 Post(s)
Liked 112 Times
Denver??
We will be driving a rental vehicle to Denver to start our tour. Will be heading north to Cheyenne.
Anyone have some suggestions to ride out of the city?
Not sure where we will stay in Denver.
Thanks!
Thanks!
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
I don't know how to ride north out of Denver, but if a real tourist were dropping off a vehicle to start a tour, I don't see why one wouldn't get on their bike and ride somewhere and sleep in the tent. (isn't that why you bring a tent ?)
Hooked on Touring
Tom -
All I can say is, "Yikes!"
Not sure if you are heading east, north, or south from Cheyenne.
Ot whether Cheyenne, itself, is a must.
As Mich Jagger would say, "Tought, tough, tough, tough."
Buena suerte!
Buena suerte!
bicycle tourist
Are you wanting to spend time in Denver or mostly depart from there? Are you wanting to ride from airport or your end destination?
There are multiple possibilities, but here is roughly what I would do mostly based on familiarity of places I've been:
1. Take RTD from the airport with bikes. For example, taking the RTD bus to the Wagon Road Park-n-Ride location (https://goo.gl/maps/FC8jKDZiZTo9QjzY7) which also has some basic hotels across the way. https://www.rtd-denver.com/app/route/104L/schedule
2. At this point, you are already fairly far north (so not best place if you want to visit Denver itself), but roughly the arterial streets are OK for riding. For example, Huron north and slightly west will bring you to more residential areas where there is a sequence of paths to Erie.
3. From end of those paths via Niwot and then north on 73rd/75th via Hygene, and then via roads to stay on west side of Loveland and into Fort Collins.
Between the Colorado border and Cheyene, there are limited paved options nearby. Essentially:
A. I-25 after exit 293 (Carr). Before then, paved roads that go via Rawhide Power plant. From Carr to the Wyoming border and first exits into Cheyenne. The con is that you are on shoulder of interstate with 80mph traffic. The pro is you have a wide shoulder and relatively few exits. Before embarking on this however, I would double check there isn't some road construction in either WY or CO that has closed shoulder of the interstate since that definitely changes the equation.
B. US 85. A much smaller shoulder with 65 mph speed limits and also fast traffic.
Neither is ideal and depends a bit on preference, though in my time in Fort Collins I typically preferred I-25.
Quoted: 455 Post(s)
Liked 112 Times
Jon we will be heading into Nebraska.
Whey yikes??
Whey yikes??
Quoted: 18397 Post(s)
Liked 15,492 Times
Maybe now your vision is a bit better.
Hooked on Touring
There are just not any good options.
Metro Denver stretches north along the Front Range for 75 miles - past Fort Collins.
County roads are quickly overwhelmed with new developments.
I'd take the Platte River Trail at first -
Then county roads - via Johnstown and Windsor
Connecting to Ault on US 85 which has shoulder all the way up to Wyo.
US 85 south of Ault is 4-lane, high speed, with shoulders.
Doable, but I'd avoid.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
Here’s Denver to Cheyenne through Greeley. It avoids riding on US 85 as much as possible.
Here’s Denver to Cheyenne through Fort Collins. This route is more populated with somewhat heavier traffic. The last part follows I-25 which is loud but you ride on the frontage road. Most of the traffic will be on the interstate.
Either one will work. Both have warts.
Stuart Black
Stuart Black
I have to wonder... Assuming you aren't crazy about the routes offered, why choose to tour on a route based on rather arbitrary start and end points even if the resulting route is way less than ideal? Why not just choose a great route and ride there instead. I assume that maybe you need to get from Denver to Cheyenne and are using it as a reason to do a tour. I'd suggest that just maybe it would make more sense to forget that approach and pick a great route and go there, especially since you are driving to the route any way. Barring that you could stick with the end point and possibly look at different start points. Perhaps you could find a route that you liked better that way.
Not sure how long your tour is and how it would impact logistics, but how about just starting in Ft Collins or somewhere else.
Maybe I am making incorrect assumptions here. If so please ignore. I have a feeling I might actually enjoy the I 25 frontage road, but without more checking out I can't say for sure.
I can see a desire to use the bike as utilitarian transportation much like commuting, but you are already getting there by rental car and I figure tours are not generally in that utilitarian category and probably shouldn't be. I figure it is better to tour somewhere because you want to see a place, or just because you want to ride from point A to B, not because you need to get from point A to B.
The more I think about it the more I think I'd look into starting in Ft Collins and riding the I 25 frontage road. I kind of like access roads in general though. You may or may not. Even at that I wouldn't want to do it day after day for too long, but I wouldn't mind a section like that. Some people would hate it.
BTW, I don't think I am one of Balto Charlie's "most knowledgeable western cyclists", but the two guys who posted above me are.
bicycle tourist
As far as the "Yikes" goes, I'll offer a counter point...
I grew up in Northern Colorado and was back last year for five weeks including several weekends cycling. I was in Boulder but cycled mostly east of there in region of Longmont/Erie/Lyons and made brief foray up to Fort Collins.
It does depend what you compare it to, and I think overall roads in northern Colorado are better for cycling than roads I have here around Austin. Strava heat maps will show you quite a few folks riding in the area as well as common routes. There is mostly a grid pattern of roads some paved and more unpaved. The population in CO and in the area has grown a low percent a year (growing up Longmont had ~25,000 people; it has had over 100,000 more recently). There has also been a proliferation of subdivisions/developments including through Weld County/Boulder County and along the general corridor. Some places the roads haven't always kept up, but it is a bit of hit/miss because other places they've put shoulders in. Erie is an illustrative case study. On one hand, former "county line road" had become busy and they haven't updated the shoulders (yet, there is a project in planning - https://www.coloradohometownweekly.c...nty-line-road/). Similarly, growing up there wasn't as good an alternative going between Denver and Boulder but for at least a decade there has been a pretty good Denver/Boulder bikeway. I don't always go for there sorts of bikeways touring, but now in that area these are becoming better alternatives.
However, at same time, there is an interconnected network of trails going up through Erie. The trick is finding and linking some of these combinations. In general, it seems Colorado roads are more likely to acquire shoulders than Texas roads as development happens.
With all that said, depending on where you are going in Nebraska, you don't necessarily need to go via Cheyenne. You can also follow the Platte River valley out through eastern Colorado or head first to Fort Collins and then east out CO 14 towards Sterling.
Bikes: Co-Motion Americano Pinion P18; Co-Motion Americano Rohloff; Thorn Nomad MkII, Robert Beckman Skakkit (FOR SALE), Santana Tandem, ICE Adventure FS
Quoted: 169 Post(s)
Liked 64 Times
Tom,
Here are some routes I did about 5 years ago. I re-created the routes on RWGPS based on my notes. Take them for what it is worth. Where specifically are you going in Nebraska? Do you want/need to go to Cheyenne or what?
This route was not the most memorable trip for me (it was part of a longer trip and was more of a connector type route) and I don't recommend it as a "enjoyable" trip, i.e. miles not smiles type.
A couple of notes on the routes. As I said, these are 5-6 years old. The traffic & services then may not be what it is now. Then they were fine. I am pretty sure a few extra miles of bike paths are available now (which I included on the RWGPS) compared to what I had. I was coming from southeast of Denver so never got to Denver. If you can start from the airport, it is easy to get to the route by heading south from the airport on Jackson Gap Rd. then east on 60th Ave. to Imboden Rd. where you would join the HCWC route, which does have about 1-2 miles of gravel. To get to the airport from downtown Denver, take the light rail, bikes are allowed. Anyway, there was a campground in Hudson. I got a hotel in Fort Collins. I did have to ride on the actual interstate for about 15+ miles but it was OK. It was the wind that was a pain at times. I didn't have direct headwinds but even the angled headwinds were quite strong. Sorry for the multiple routes. I just piece together various routes (I have thousands) to create one. While there is a frontage road most of the way, it is gravel for those 15 miles I rode on the interstate. Here are the routes, hope it helps:
https://ridewithgps.com/routes/36142062
https://ridewithgps.com/routes/36141838
https://ridewithgps.com/routes/36141940
https://ridewithgps.com/routes/36142211
https://ridewithgps.com/routes/36142349
Tailwinds, John
Tailwinds, John
