Kinetic Road Machine vs Control?
I have a Kinetic Road Machine that I generally use in the winter or in bad weather. It is not always the most inspiring. Thinking ahead to the winter months I am considering using Zwift or one of the other online training programs. I am debating whether it would be worthwhile to upgrade the trainer with the Control unit.
I am not sure if the Control unit making it "interactive" is necessary or much of a plus. If people have found it to be a really significant difference or improvement I might consider the expense. Any thoughts or comments about this?
Quoted: 313 Post(s)
Liked 680 Times
Necessary? Probably not. You could get away with just using a speed sensor on the rear wheel.
A plus? It depends. I think that the Control Unit simply broadcasts a power number, so it won't give a fully interactive experience. Your on-screen speed in Zwift or whatever will change depending on your power (pedal harder = go faster) but you won't get automatic and interactive resistance changes.
You'd probably be best using your current setup, seeing how much you "enjoy" indoor cycling, then possibly buying a proper smart trainer.
Yes, good point. Although upgrading it by adding the control unit would give me a way to bridge that gap for a lot less cash.
Quoted: 1027 Post(s)
Liked 325 Times
The control unit adjusts the resistance right? IMO, that's a big plus for Zwift.
Whether it's worth the money or not likely depends on how much you use Zwift and the trainer in general. However, if it is going to be pretty regular, then going with a direct drive smart trainer is a worthwhile investment IMO. I'm certainly happy I got one.
Yes, from what I understand it will control resistance. I am hoping it might be a motivation to use it a bit more often. I like the idea of the direct drive trainers, but don't think I can spend that kind of money right now. I have seen some write ups that suggest it is a workable alternative for a bit less money.
I have an older Kinetic Road machine paired with Kinetic InRide.
https://www.kurtkinetic.com/inride
Mine is the older blue tooth only. Works pretty good for Zift, but if i had the spare cash i would want a smart trainer. Still I use Zwift 4 or 5 days during the week before work and on the weekends if there is bad weather. Makes indoor riding much more enjoyable.
Likes For Bolo Grubb:
Liked 325 Times
Likes For OBoile:
InRide is just a fancy sensor replacement for the standard speed/cadence sensors used to calculate your virtual power. Nothing interactive about it (in reference to "smart" trainer).
OP, are you referring to Kinetic Control Power Unit? Haven't heard anything good about it except that it can be use with the Rock and Roll frame. I love my RM but would not buy one of their control power unit. KK really need to up their game.
Quoted: 2952 Post(s)
Liked 3,106 Times
This is my thinking as well. I bought a Kinetic Road Machine a few years ago, thinking I would mostly use it for warming up for races. The InRide sensor was just a nice bonus and a quick and easy way to get on Zwift. If I had known I was going to spend so much time on the trainer doing Zwift and/or TrainerRoad, I would have bought a direct drive smart trainer, which is probably what I'll do this fall. I wouldn't bother with the Control unit. I'll keep the Kinetic for race warmups, but I'll likely just dedicate an old bike to the new smart trainer set up.
Likes For caloso:
Liked 325 Times
Likes For OBoile:
Quoted: 313 Post(s)
Liked 680 Times
Also there's no wearing out tyres or having to check tyre pressures or setting roller resistance or even the need to calibrate the trainer (depending on model). Once you go direct-drive, you never go back!
