Tire clearance for Giant Contend 3 2018 model
Am wanting to get wider tires for my bike (Giant Contend 3 2018 model). Giant website and user manual don't give any specification for tire clearance. Also called LBS, but they said they can't give me that information. Anyone here know or have experience? Would like to order 28c or wider, just want to make sure if will fit first. Would love to hear your suggestions, many thanks.
Quoted: 20791 Post(s)
Liked 9,436 Times
What do you have in there now?
In general, you want about 4mm of space/tire clearance, to the to the sides and the top. A quick way to estimate what you can get away with is to grab your 4mm Allen wrench and use it as a feeler gauge around the tires - check the sides at the chain and seat stays, the top at the seat tube and brake caliper, etc. That should give you a good visual on how much more you can fit in there while still maintaining enough clearance for debris and whatnot.
Edited to add: also keep in mind that some tires will measure different than others - a nominal 25mm from some brands might measure out to 28mm in real life, so the above method is best when you're staying within a certain manufacturer/model.
Quoted: 6100 Post(s)
Liked 4,732 Times
Find where the tightest clearance is on your current tires and measure that. Might be the center of the tread with the brake calipers if rim brakes, or perhaps seat tube or top of fork. Or the sidewalls and fork or stays. If you determine that at your smallest clearance point you have six mm of space, then if you leave the suggested 4mm clearance for saftey, then you can get a tire that is four mm larger. 6 - 4 = 2, but you are working with a radius so you can double it for figuring out what tire size you can get. You can assume tires will grow equally in height and width. However height is the full height of the wheel and tire, not the section of tire from rim to tread. (I think I'm pretty certain of that.... chance I might be wrong) But if they have an aggressive tread, then more cause to be conservative in what you get in a particular brand and model until you know from actual experience.
But, there are some tires that for various reasons aren't true to the size they specify for width. Some run smaller because the mfr was trying to say theirs is the lighter of all the other tires that size. Some run bigger, probably .... I think... because most are specifying the width of the casing when on a rim of a specified width, and that doesn't include extra tire material on the outside of the casing.
Bikes: Giant Contend SL 1 Disc
Quoted: 155 Post(s)
Liked 77 Times
JAG
Likes For sirjag:
