Why 3 x 7 to 1 x 7/8/9/etc? Why not 3 x 7 to 3 x 1?
In mountain biking, the 1 x 8/9/etc is becoming more popular. I am wondering why I haven't heard of anyone going to 3 x 1 (3 speed in front, one in rear). Can this be done? When I go biking with my kids, I usually don't touch the rear gear, I just change the front one. This avoids me having to keep on shifting.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
When you shift the front, the rear derailleur moves to take up the slack (or to provide it).
In general, rear shifting works better, so it is preferred. Also, you can get much smaller increments of change, which leads to smoother shifting. Fewer chainrings generally means fewer chain drops when shifting, and fewer stabbings when you aren't in the largest chainring. Also, SRAM doesn't know how to make front derailleurs.
Likes For Cyclist0108:
Expired Member
Quoted: 3672 Post(s)
Liked 5,425 Times
Three gear choices vs 21? If you don't want many gears an IGH or single speed would be cool.
Likes For shelbyfv:
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,990 Times
Paul Price of Paul Components fame did a 3x1 bike at the shop to test out his Melvin Chain Tensioner you could ask him but it was probably just a silly shop project he thought up at Sierra Nevada over a couple of their brewskis.
I wouldn't want a 3x1 personally I do most of my shifting at the rear like probably 99% of the bike riding population that has gears. The front does quite a big shift and is not really what I want often enough and when I do it is usually preceded by some rear shifts.
Likes For veganbikes:
Thread Killer
Quoted: 3137 Post(s)
Liked 1,704 Times
It takes a Pinion gearbox in order to make doing away with the rear derailleur make sense:
https://pinion.eu/en/
Likes For chaadster:
Sunshine
Quoted: 10960 Post(s)
Liked 7,488 Times
2- a 1x10 system gives you 10 options to match the cadence you want for the terrain you happen to be riding at the moment(up hill, down hill, etc). A 3x1 system would give you only 3 options to match the cadence you want to the terrain you happen to be riding.
3- why do you only change the front derailleur when riding?...the rear allows for smaller changes. I can't remember the last time I was in 50-18 and thought to myself that I need to be in 34-18 immediately.
Likes For mstateglfr:
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
Because shifting the rear is so much easier to trim or shift.
Bikes: 1978 Raleigh Competition-1974 Raleigh Folder-1983 Austro Daimler-198? Fuji Monterey-Surly LHT-Surly Karate Monkey-Surly Cross Check
Quoted: 43 Post(s)
Liked 97 Times
As mentioned above, I think that a SRAM i-Motion 3 speed IGH would accomplish almost the same thing but maintain the chain line throughout all the gears.
Quoted: 43 Post(s)
Liked 97 Times
You could also go the other direction as per the late, great Sheldon Brown. https://www.sheldonbrown.com/org/otb.html
Likes For fettsvenska:
Quoted: 4256 Post(s)
Liked 1,354 Times
You also need some sort of thing to take up chain slack. Which means you'd have something "springy" in the rear even if there was no rear shifting.
The "best" practice is to minimize front shifts. And to shift the front with large changes in speed.
You should be able to pick a front chain ring and just use the rear.
Pennylane Splitter
Bikes: Yes
Quoted: 1798 Post(s)
Liked 1,439 Times
I've got an old Schwinn LeTour set up as a 2x1. The rear wheel is a single speed and the RD acts as a tensioner. I've got a few small hills on my way to work and the drop from 52T to 34T makes it easy. Also nice to go down to the 34T for just cruising along.
But I'm usually the oddball in any group. YMMV
