Cable Guides
Quoted: 809 Post(s)
Liked 1,018 Times
Cable Guides
I am looking to add cable guides to an existing vintage frame. I have done this in the past with brass tubing, however, brass tubing that is sold in hobby stores is thin walled, so I want something more substantial. I was thinking of steel brake line tubing, at least for the derailleur cable. Has anyone tried using some sort of locally bought tubing? If so, what did you use? I would also think that it does not actually need a tube. A piece of sheet metal can be bent into a "U" shape to act as cable guide or a piece of wire could be wound as a cable guide as well.
Or should I just spend $4 on parts and $8 on shipping and get something that I don't have to cut and shape?
Quoted: 321 Post(s)
Liked 263 Times
Car brake pipes should work pretty well. They are the right size. I nearly used some but my local garage only has copper ones so I just got some premade guides from Ceeway with my next order.
Quoted: 4195 Post(s)
Liked 3,837 Times
K&S also offers stainless steel tubes that are far stronger then the brass is. Whatever you do use leave some windage between the cable/casing and the braze on"s ID. Andy
AndrewRStewart
AndrewRStewart
Quoted: 809 Post(s)
Liked 1,018 Times
Thanks guy153 and Andrew R Stewart . Good point about leaving some room on the inside diameter of the guide. That is one of my concerns with brake line (pipe) . The 3/16" brake line is .188" inside diameter and the derailleur cable housing is .167" . That might not leave enough room for paint and wiggle room installing the cable housing. And if I change the cable housing in the future, it may be a little or a lot bigger.
I make this sample guide from solid copper wire and while it might work, It looks like it would be more difficult than a tube to silver solder on. And I don't really like the look that much.
I might try an art and hobby store and see if they have stainless steel tube. That seems like it would be prefect if they have it. I have mostly seen brass, but perhaps I wasn't looking for stainless in the past so I didn't see it.
Randomhead
Liked 3,687 Times
I got thinwall stainless from McMaster. Their shipping has doubled since then though, the brake line might be a better idea
Quoted: 809 Post(s)
Liked 1,018 Times
PM sent to pwyg . I am also looking at McMaster since the company that I work for buys from them regularly, perhaps I can piggy back onto an order.
Quoted: 809 Post(s)
Liked 1,018 Times
I received the stainless tube from McMaster Carr. It is 1/4" outside diameter, with a .028" wall thickness for a 4.9mm inside diameter. Part number: 89495K775. I plan on cutting the pieces 10mm long.
Last edited by Velo Mule; 11-10-21 at 05:18 PM. Reason: My picture seemed to go away
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 411 Post(s)
Liked 900 Times
Are old-style derailleur cable guides that are brazed onto the top of the bottom bracket considered inferior these days? Just curious why you wouldn't use them on a vintage frame...
Liked 3,837 Times
For the factory (or builder) drilling a hole in the bottom of the BB shell to fit an outsourced cable guide is vastly faster, thus cheaper, then brazing on a pair of above guides. There's nothing wrong with above guides if they are well placed. If poorly located the cables can rub on the tubing surfaces though.
If the frame is used and already has the above shell guides then by all means use them and be happy. IIRC the last time I brazed on a set of above guides was in the mid 1980s. Andy (Who has a few pairs in his stash slowly rusting away)
AndrewRStewart
AndrewRStewart
Quoted: 809 Post(s)
Liked 1,018 Times
The good thing is the old AW is working just fine. There may be no reason to spend more money on a hub, spoke and a rim. The AW is 40 holes, so a new rim would be needed.
Thank you all for commenting. This has been helpful. Hopefully, I'll make up my mind and just get the guides on the frame. I could always take them off if I go with a new hub.
Liked 3,837 Times
Be aware of cable friction when running an AW hub. The spring that the clutch and cable are moved by is not very strong one. Before lined casings became the norm AW cables that had the casing stop on the chain stay suffered more friction issues than those that the stop was on the DT and a pulley served the BB routing angle. I might suggest looking at having the inner cable running through a liner sleeve if you must use a top of shell Campy like guide. Andy
AndrewRStewart
AndrewRStewart
Quoted: 809 Post(s)
Liked 1,018 Times
Good points @Andrew R Stewart , I am using lined cable and having no problems. It is new cable housing and low friction, lined housing. My thought was to line up the cable guides so that the cable would be a straight shot along the top tube and seat stay with the only bends being the transitions. When I was installing the shifter cable it moved easily through the housing. But over time... I will keep that in mind.
