I got a tax refund - which wheelset is the best bang for the buck?
Thread Killer
Quoted: 3133 Post(s)
Liked 1,700 Times
chaadster I don't care about aero or weight insomuch as I'm not a racer. Am I building up a frame I've been searching for for 2+ years and do I want it to be a kick ass, quick, hot bike? Yes.
SoSmellyAir I'd love to run 28s but I just don't think its possible. That was something I was just bringing up because someone above had mentioned getting 19mm wheels, etc. 15 or 17 should be fine, or whichever you think would be best with a 700x25 tire. And yes, that post you found in the other thread is the bike.
Likes For chaadster:
Thread Killer
Liked 1,700 Times
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1941 Post(s)
Liked 1,464 Times
the sci guy said that "the bolt bubble on the rear brake bridge is low and rubs on any tires with a higher volume than 25/26mm." I understood his use of the word "low" to mean that the top of the tire rubs. As you can see from your graphic above, when the same tire is mounted on a rim with a slightly larger internal width (e.g., going from lighter blue to brighter red) with a lower tire pressure (to compensate for the greater tire volume), most of the increase in tire volume is accounted for by the increase in tire width, with only a slight increase in tire height.
Likes For SoSmellyAir:
Liked 1,464 Times
Thread Killer
Liked 1,700 Times
Mavic uses ETRTO size: 622 x 17C to designate an internal width of 17 mm (Aksium | Mavic). So either you are wrong or Mavic is wrong.
I was thinking that internal widths on vintage ‘00/‘01 rims was not 15mm, but apparently I was in error.
Thanks for the correction.
Sunshine
Quoted: 10954 Post(s)
Liked 7,482 Times
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
basically, i want a ~$400 set of wheels that will fit a 700x25/26 tire at the smallest possible volume because of the confined space due to the brake bridge.
Here's I found a video I took of my buddy's bike (same exact frame model just a size 58 instead of the 52 I have). This was putting 700x28 on new Mavic CXP Elites I got at the bike shop
https://www.flickr.com/photos/rattle.../in/datetaken/
I wonder if the rims I got him were a wider IW and I just didn't realize it? And that's causing the issue? I need to have him check.
Here are the wheels that came on my frame, and they had 700x23 tires on them.
So from what I've read so far, if I get a wheelset that's 17mm width, and try to use a 25/26 tires, it will actually have a greater volume & greater height than if I had the same tire on a rim with 15mm width? (which would maybe be bad - as I'm not sure exactly how much clearance I have). I will try to get my buddy to take a pic of the clearance on his bike.
Quoted: 1743 Post(s)
Liked 1,281 Times
I just bought a (new) rear wheel from The Pro's Closet. I was surprised they had them.
Liked 1,464 Times
Liked 1,464 Times
So the question is, how much clearance is there between the rear brake bridge and a 25 mm tire mounted on a 622 x 15C wheel? If there is a lot of space, then you can probably go to a 622 x 17C wheel while keeping the same 25 mm tire. (Please also note that some 25 mm tires are larger than other 25 mm tires.)
Liked 1,464 Times
Bikes: Tcr advanced sl & Protos
Quoted: 116 Post(s)
Liked 60 Times
OP has budget of $400 and his frame cannot even fit a 28 mm wide tire mounted on a 622 x 15C wheel. Bora WTO wheels have an internal width of 19 mm (Bike Wheel Bora WTO 45 | Campagnolo) which most likely would not work.
My bad. I admit to skimming the post.
For 400$ get some Zonda or Ultegra.
I have 25mm on my WTO. For
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
No need. You got it right. The label on the Mavic Open Pro wheel shown in your photo said 622 x 15, which designates an internal width of 15 mm. See also: Open Pro Clincher | Mavic.
If you want the smallest possible volume, then you should get a 622 x 15C wheel.
No, Mavic CXP Elites are also 622 x 15C. See CXP Elite | Mavic. So if a 28 mm tire on that wheel does not fit in a bigger frame of the same model, then there is no point to try this on your frame.
Yes, on a 622 x 17C wheel (having an internal width of 17mm), the same 25 mm tire will be noticeably wider and slightly taller (than if mounted on a 622 x 15C wheel), resulting in a greater tire volume.
I texted my buddy but he's a pilot and isn't in town currently. When he's back I'll have him get me some pics showing the currently clearance he has - measure if possible. Currently he's got 700x25 panaracer pasaleas on those mavic cxp elites.
I love pasaleas, but i'm up for a different tire if a 700x26 will edge me just that much closer to a 700x28 as possible.
I'll hold off on a wheel purchase for a few more days at least.
I have Zondas on my Cannondale. Very little riding on that bike so far, but they spin up quickly, are reasonably light, and look cool. The nearly silent freehub is a pleasant surprise, though I always think that something’s weird my first few minutes on the bike (it’s my backup to other, louder bikes). PBK usually has them for just under $400, sometimes a little better, occasionally worse. I like them enough that I’ll likely get another set when my other rim brake bike needs new wheels.
Liked 1,464 Times
the sci guy As first predicted by jamesdak above (in post #9), Campagnolo Zondas are now on sale for $390: Campagnolo Zonda C17 Clincher Wheelset - Black | ProBikeKit.com Be sure to select the Shimano/SRAM version.
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
Liked 1,464 Times
Shimano Ultegra WH-RS500 Road Wheelset - Tubeless | Competitive Cyclist
A 17C wheel would likely work with the right (i.e., newer and smaller) 25 mm tire. [1] As stated above, the same tire on a 15C wheel would only be slightly taller if mounted on a 17C wheel. [2] Some more recent tire models are smaller than their predecessors at the same stated width, because the newer tire is designed for a 17C wheel, while the older tire was designed for a 15C wheel. One of the more famous examples is the Continental GP4K vs. GP5K. On a 17C wheel, a 25 mm GP4K measures at around 28 mm, while a 25 mm GP5K measures barely at 25 mm.
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
It is increasingly hard to find a decent 15C wheelset nowadays. This might be the only one:
Liked 1,464 Times
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
not sure yet. My go to is Pasaleas, may still try those 25s. Might try to find something in a 26? I really only want to spend about $70-80 total on a pair.
Liked 1,464 Times
You may be in luck. According to this other BF thread, the 32 mm version of a Pasela Protite folding tire "measure[s] very close to" 32 mm on a CR-18 rim (Bike Forums - View Single Post - Panaracer Pasela PT folding - actual width), which has an internal width of 18 mm (Sun Ringle CR-18 700c Polished Road Rim | Tree Fort Bikes). So it seems safe to guess that other models this tire would not run wide on a 17C rim.
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
You may be in luck. According to this other BF thread, the 32 mm version of a Pasela Protite folding tire "measure very close to" 32 mm on a CR-18 rim (Bike Forums - View Single Post - Panaracer Pasela PT folding - actual width), which has an internal width of 18 mm (Sun Ringle CR-18 700c Polished Road Rim | Tree Fort Bikes). So it seems safe to guess that other models this tire would not run wide on a 17C rim.
finally got my buddy take a pic of the clearance on his frame.
these are 700x25 on Mavic cxp elite, which should have a 15mm IW, correct?
seeing this made me nervous for the 17mm Zondas I just got…
Liked 1,464 Times
That does look pretty tight. What 25 mm tire is he running?
