Best Tail light
Biking Viking.
Best Tail light
Here's what I want in a tail light:
1. Built in reflectivity. This seems like an obvious element that a surprising number of lights don't have.
2. Bright, but doesn't need to be so bright it blinds airplanes.
3. At least 180 degrees of visibility. I want to be seen from the side too.
4. A mounting bracket that screws down with a clamp. Elastic band straps always break or slide down on me.
5. $20 - $40 price range
I started researching but found it annoying how hard it is to get all these elements in a light. Anybody have a light with all/most of these features that they'd recommend? The Cateye Reflex LD560 seems good...anybody use that light?
One Man Fast Brick
Bikes: Specialized Langster, Bianchi San Jose, early 90s GT Karakoram, Yuba Mundo, Mercier Nano (mini velo), Nashbar Steel Commuter, KHS Tandemania Sport
I own 4 or 5 Superflashes and I'm pretty sure they do not have a reflector.
The Radbot does have a reflector. I have a couple of them and generally like it better than the Superflash except that you need to change out the batteries more frequently than the 1/2 watt Superflash.
One Man Fast Brick
I bought a few of these from DealExtreme. I have used one for a couple months and it has not fallen off yet or died from being exposed to downpours. I think it is about as bright as a 1/2 watt Superflash, but not as bright as the 1 watt Radbot. It is hard to beat it considering how cheap it is and I am comfortable with it as a secondary blinky light. It uses the same mounting bracket that the Superflashes and Radbots use.
https://www.dealextreme.com/p/3-led-3...ht-2-aaa-35036
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Yes, I've been using that light (Cateye Reflex LD560) for a couple of months. It has a bright center LED plus several smaller ones, large reflective area, and multiple eye-catching patterns, most of which are very noticeable from many angles. I really like having a reflector built into the tail light. Uses the current standard Cateye rear light mounts.
I *love* my SuperFlash from Planet Bike. It's the best I've ever seen. I've personally been driving down the road, seen a blinking red light, and only about 1/2mi later caught up to it and realized - yep, that's a PB SuperFlash. Amazing.
If you really want to dazzle them, you can grab one of these bad boys:
https://www.aervoe.com/paints_coating...re-single.html
See it in action:
https://www.youtube.com/watch?v=nxbg9xyeXA4
I saw one of these at a conference and I've wanted to get one ever since. I was thinking of strapping it down to my rack on the back of my bike. Unbelievable visibility - these things are painfully bright, 360º visibility, multiple flash modes, multiple charging options, and durable as all heck! They promise you can run them over with a car and have it still work fine. Not to mention fully waterproof. Surprisingly, only $35 each!
Only thing it really lacks is built-in reflectivity. Although the rubber cover is pretty bright, it doesn't do you much good in the dark unless its turned on.
See it in action:
Bikes: 86 Nishiki Olympic Sport, 87 KHS Montana Team, 06 Dahon Mariner
Quoted: 17 Post(s)
Liked 5 Times
Radbot 1000. If you're concerned about battery life, then the Radbot 500 is half as bright.
Papaya King
Bikes: 2009 Felt X City D, 1985 (?) Trek 400, 1995 (?) Specialized Rockhopper, 1995 Trek 850
Acts 2:38
Bikes: '10 Marin Lucas Valley, '13 Scott Speedster 20
Acts 2:38
Papaya King
I like the PBSF too, but those of you recommending it are ignoring the OP's first requirement. I really wish it had that, but it does not.
Papaya King
Bikes: Bianchi Via Nirone 7, Jamis Sputnik
I don't see why you'd need a reflector if the light is turned on.. as long as it's a good light that's giving off a decent amount of light.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Some people let their batteries die out. Some lights stop working unexpectedly.
Light or reflector required in Indiana.
Liked 5 Times
Also, another good taillight in the OPs price range is the Cateye TL-LD1100. Not as bright as the PBSF from directly behind, but it has a much wider "beam pattern", if taillights can be said to have a "beam pattern". Also, it uses AA batteries instead of AAAs, so it also has a really good battery life.
Papaya King
With good lights, the reflector is practically if not legally redundant. IME lights that are also reflectors are nowhere near as bright as the Radbot 1000 or the PBSF. So, run one of the good lights, and ALSO run one of the reflector lights so you comply with the letter of the law, too.
I don't know if this is current, but it's what I found of Ohio bicycle law via google:
"§ 4511.56. Bicycle signal devices.
(A) Every bicycle when in use at the times specified in section 4513.03 of the Revised Code, shall be equipped with the following:
(1) A lamp mounted on the front of either the bicycle or the operator that shall emit a white light visible from a distance of at least five hundred feet to the front and three hundred feet to the sides. A generator-powered lamp that emits light only when the bicycle is moving may be used to meet this requirement.
(2) A red reflector on the rear that shall be visible from all distances from one hundred feet to six hundred feet to the rear when directly in front of lawful lower beams of head lamps on a motor vehicle;
(3) A lamp emitting either flashing or steady red light visible from a distance of five hundred feet to the rear shall be used in addition to the red reflector. If the red lamp performs as a reflector in that it is visible as specified in division (A)(2) of this section, the red lamp may serve as the reflector and a separate reflector is not required."
Honestly, I just don't get why people continue to recommend things that clearly don't meet the OP's first stated criteria. I use some of them too, but that isn't what OP asked.
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
I'm going to following this thread, as the Zefal combo pack appears to be having issues...
Community guidelines
Bikes: A few ;)
https://cgi.ebay.com/Portland-Design-...#ht_863wt_1141
That's where I got my Radbot 1000 from. The batteries were basically dead out of the box, but rechargeables are highly recommended for this light anyways. It's cheap and arrived quick, it's worth a shot. My 2 PBSF lights will get helmet mounted now.
