Affordable way to replace old worn MTB carnk rings.
I have been riding on this old Sugino cranket forever (24-34-42T) and the rings are getting worn. I love the combination. What is the most affordable way to replace it? Looking for just rings I can't seem to even find 4-hole (65mm diameter) rings to match these cranks. Should I just replace the whole crankset? Any suggestions on the most affordable way to keep me going on this 80's/90's steel tube hard rock beast that I hope to keep riding forever?
Bikes: lots
Quoted: 1954 Post(s)
Liked 2,925 Times
Oh, I don't know...maybe talk to a bike shop?
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1210 Post(s)
Liked 796 Times
"Sheldon Brown's Bicycle Crank/Chainring Bolt Circle Diameter Crib Sheet"
Here are some links to 64 mm BCD chain rings:
24T: Truvativ/SRAM 24Tx64mm Chainring | Jenson USA
Others: 64 Bicycle Chainrings - Modern Bike
Likes For cruiserandmax:
Quoted: 3791 Post(s)
Liked 2,941 Times
Sometimes a new crankset is cheaper than 3 rings are. Sometimes a new crankset will need a different length BB. Sometimes the old BB is an OK size for the new crankset but is already worn (and might want replacement soon too). It's an availability and a math problem.
BTW the era of triple chainrings seems to be passing. If you really like this type of gearing (and I most certainly do too) I suggest getting a second, back up, set while you can. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 1973 Post(s)
Liked 984 Times
I have FC-5703 (105) triple cranks on two bikes and FC-4603 (Tiagra) triples on two others. Seeing the way things were going, a couple of years ago I found two NOS FC-5703 cranks for sale at attractive prices at couple of on-line shops I bought them both. They are sitting on my parts shelf waiting for they day they are needed.
Bikes: nothing to brag about
Quoted: 118 Post(s)
Liked 191 Times
Looks like a whole new crank w/rings is pretty cheap
https://www.universalcycles.com/shop...hp?category=64
Likes For mdarnton:
Quoted: 1595 Post(s)
Liked 1,332 Times
Likes For alcjphil:
Liked 2,941 Times
And for us small framed road riders mountain triples tend to be rather wide, "Q" factor and all. It's sad for some of us that a method that has worked for millions over the last many decades is no longer considered financially workable. Can you say cart before the horse? Andy
AndrewRStewart
AndrewRStewart
Bikes: lots
Liked 2,925 Times
Something must be wrong w/ that derailleur, the gap at the tail is enormous.
Bikes: Cannondale - Gary Fisher - Litespeed - Schwinn Paramount - Schwinn (lugged steel) - Trek OCLV
Quoted: 668 Post(s)
Liked 624 Times
+1 SRAM never offered a triple crank and Shimano and Campy have discontinued all of their road triples. They seems to be doing the same with MTB/Trekking cranks and have never offered a Gravel triple. In fact the current fad is for 1X so even doubles are endangered.
little surprised - especially with availability of 10 cogs / 11t small cog and compact cranksets
50/34 crank and 11-28 cassette ... ? ... 11-30 .. ? ... 11-32 ... ? ... 11-34 ... ? ... 12-30 ? ... should provide the gearing for the climbs and descents
Liked 1,332 Times
Not the gap between the tail end of the derailleur and chain stay. Look very carefully at the gap between the chain stay and the tail of the derailleur. In the big ring the gap is not that big. When shifted down to the small ring the gap is tiny. That front derailleur is as low as it can go. It is a mountain bike derailleur on a touring bike with a relaxed seat tube angle. of course it will not be optimally positioned. However, I take your point, I will look into whether I can move that front derailleur a bit lower
Likes For alcjphil:
Liked 1,332 Times
Liked 2,941 Times
The increase of "Q" is driven by a few factors. Frame design being #1. The, questionable, goal of massive stiffness and or suspension (note the ironic here) along with material considerations has seen the clearance between cranks/rings and stays become challenging. Add in really wide tires and the resulting cog set shift further from the centerline and more "Q" is had.
I admit that I am bound to a fit and riding style that is not the current fashion. I am ok with the fact that how I want to set up a bike is being left behind by the industry. Not happy but accept it. Just like the triple crank (or even double) are being dropped by many brands and the lack of making the older replacement rings and such.
So write off my poor previous post to ranting, like this one. Andy
AndrewRStewart
AndrewRStewart
Quoted: 17228 Post(s)
Liked 3,966 Times
Your chain is looking mighty stretched.
You might try a new chain and keep riding.
Your rear cassette or freewheel could be TOAST!!!
Clark W. Griswold
Quoted: 3550 Post(s)
Liked 2,873 Times
So firstly clean your drivetrain more often, all of that dirt and gritty greasy grime is wearing things out faster. Secondly replace your chain and cassette or freewheel with regularity ideally before it is totally worn out so you will save other components from extra wear. Thirdly make sure to properly lubricate those components which includes that first part.
In your case with the chainrings and being cheaper, a new crank is the way to go to save on initial costs. Certainly new chainrings of highest quality could have the potential to last longer with the proper care listed above but they will be more expensive initially. A new crank though will probably make the most sense and with that I would do a new bottom bracket new length or style needed or not, I would also pull apart the rest of the bike and clean it all and re-grease it and re-install it. If you really love the bike of course. If not then do something different.
Bikes: lots
Liked 2,925 Times
Quoted: 130 Post(s)
Liked 237 Times
https://www.sram.com/en/sram/models/fc-s600-a1
Sram s600. May need the appropriate length bottom bracket too, and probably new chain and cassette as well.
