Is a 90s Trek compatible with a new drivetrain from today?
Old 11-24-22, 08:32 PM
BikeGuy2
BikeGuy2's Avatar
Bikes: 1. Trek fuel ex 8 GX 2022 ML. | 2. 1995 Green Trek Mountain Track 850. | 3. Avanti Pisca pro-Track bike. | 4. Some 10 year old upgraded BMX
Quoted: 10 Post(s)
I have a old 1995 trek Mountain track 850 that has a completely worn out drivetrain beyond repair. I want to upgrade the whole drivetrain to a 36t SHIMANO ALTUS M2000 2x9 speed groupset.
Link- https://www.aliexpress.com/item/1005...74637964%21rec
Will this work? Is there a better way?
BikeGuy2 is offline
Old 11-24-22, 10:28 PM
lasauge
Pedalin' Erry Day
lasauge's Avatar
Quoted: 689 Post(s)
Liked 286 Times in 151 Posts
Yep, that will work as long as you have a freehub body that's not 7 speed only. Also, the listing is vague on what shell width the BB they're including is, but it's a safe bet it will be 73mm and match your old frame, just know that you may need to source a different one if that doesn't match.
That said, considering this is really cheap on Aliexpress, there's a good chance that what you'll actually get in the box is cheap copies or falsely badged copies of the Shimano original parts. But frankly, at this price/quality point does that even matter? Up to you to decide. The alternative that would be safer if you care would be to purchase parts through your local bike shop.
Reach me faster by email.
lasauge is offline
Old 11-25-22, 12:24 AM
BikeGuy2
BikeGuy2's Avatar
Quoted: 10 Post(s)
I have no way of going to a bike shop to buy the parts or for help because i live out bush. I do not have any verniers to get any measurements unfortunately. Do you know anywhere else online i can get the same groupset? I agree that buying of aliexpress is sketchy but it was the only website i could find that offered this groupset or anything similar.
BikeGuy2 is offline
Old 11-25-22, 04:42 AM
romperrr
Pedal to the medal
Bikes: 1991 Team Miyata Track, 1992 Lemond Alpe d'Huez, 19?? Schwinn High Serra, 1982 Trek 614, 198X Raleigh Alyeska
Quoted: 242 Post(s)
Liked 111 Times in 74 Posts
I see you're in Australia. I don't know if any US bike shop with a good online presence like Tree Fort Bikes ship out there and even then cost might be prohibitive. Perhaps try calling the popular bike shop in the nearest major city and get their advice?
romperrr is offline
Likes For romperrr:
Old 11-25-22, 05:13 AM
Hondo6
Bikes: Yes
Quoted: 366 Post(s)
Liked 405 Times in 283 Posts
Good point.
OP: if your current drivetrain is Shimano 7-speed rear, you want to check this. Quickest way to confirm is to pull the rear cassette and see if there's a spacer(s) of about 4 mm or so behind it. Or you could measure the freehub body length - if it's about 31mm it's 7-speed only, while if it's around 35mm it's 8/9/10 speed (11-speed is longer, but didn't exist in 1995).
Hondo6 is offline
Likes For Hondo6:
Old 11-25-22, 07:29 AM
CO_Hoya
Señor Member
Quoted: 252 Post(s)
Liked 204 Times in 114 Posts
If the OPs bike matches the 1995 Trek catalog, it will be a equipped with a 3x7 drivetrain (Shimano Alivio/STX) as OEM. As per Hondo6 above, it would be a good idea to confirm the size of the freehub before making a purchase.
If the OP can post some pictures of the bike, especially the rear hub and cassette with spacing and any part numbers visible, I'm sure someone here will be able to assist with sorting out what's compatible.
That's a nice enough frameset that putting some money into a new drivetrain can be worthwhile. Shimano's Altus line looks like it has 7-sp offerings as well if you do have the smaller freehub.
While I have no personal experience, I hear that Microshift components are of good quality and it looks like they have a 7-sp MTB group ("Mezzo") that may be worth tracking down for comparison shopping.
CO_Hoya is offline
Old 11-25-22, 09:11 AM
Hondo6
Bikes: Yes
Quoted: 366 Post(s)
Did some further checking.
The Trek doc above says the hubs are "Shimano Acera X Parallex". The only "Acera X Parallex" rear hub I could find reference to was the FH-M290. All versions of that rear hub seem to be 7-speed HG hubs only.
OP: can you find a model number on your existing rear hub? For that model, I think the model number was on a sticker on the hub barrel.
Hondo6 is offline
Likes For Hondo6:
Old 11-25-22, 01:18 PM
Nwvlvtnr
Bikes: I have a few
Quoted: 30 Post(s)
Liked 103 Times in 51 Posts
You can remove one cog and spacer from the cassette giving you 8 speeds with 9 speed spacing, this will fit a 7 speed freehub body. If you remove a cog from the center range there may be a down shift that isn’t as quick or smooth as the others but it will work. Shimano cassettes are usually held together with riveted pins, grinding off the heads from the back of the large cog will allow you to disassemble the unit.
See Sheldon Brown article:
https://www.sheldonbrown.com/k7.html#bodycompat
Nwvlvtnr is online now
Likes For Nwvlvtnr:
Old 11-25-22, 03:28 PM
wrk101
Thrifty Bill
wrk101's Avatar
Quoted: 1202 Post(s)
Liked 862 Times in 575 Posts
Cheap digital calipers can be had on Amazon or other sources. The more you need to do stuff yourself, the more you need basic and accurate measurement. devices and tools.
Here in the USA, Amazon has a set of digital calipers for $8.19. I would expect the price to be higher in Australia but my guess they will have something similar.
Not having them is understandable. Not getting them is not a sustainable plan.
wrk101 is offline
Likes For wrk101:
Old 11-30-22, 10:58 AM
ser_gio
ser_gio's Avatar
Quoted: 9 Post(s)
Liked 3 Times in 3 Posts
Very nice photo and great bike to maintain! Good luck with your work.
ser_gio is offline
Old 11-30-22, 12:06 PM
Nwvlvtnr
Bikes: I have a few
Quoted: 30 Post(s)
From what I can see it will work. My concerns are:
There is no specified clamp diameter for the front deraileur, you may need a spacer shim. The pictures appear to show a dual pull unit but I am not certain of this, the description provides no answer.
The bottom bracket is listed as 68 and 73mm shell compatible but does not mention a spacer, if your shell is a 68 you’ll need a 2.5 or 3mm spacer for the drive side.
You most certainly have a 7 speed freehub body but can make the 9 speed cassette work as stated in my earlier post.
Have fun and be sure to post pictures.
Old 12-01-22, 05:44 PM
Hondo6
Bikes: Yes
Quoted: 366 Post(s)
Not my bike; it's the OPs. But I agree that it's a very nice bike.
I'm pretty sure the OP agrees too.
Hondo6 is offline
