Frame Identification
Old 11-25-22, 05:12 AM
Aardwolf
Old Git
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 124 Post(s)
Liked 267 Times in 139 Posts
Hiya Folks,
spotted an old frame on Ebay and I've got no idea what it is but it looks quite interesting.
https://www.ebay.co.uk/itm/374367117...Bk9SR7aF--aVYQ
It's frame number "0265" (on forks and BB) with "BR" under that on BB.
In my (limited) experience I've never seen a head tube like it:
And here's the BB
Anybody have an idea what it is ?
Aardwolf is offline
Likes For Aardwolf:
Old 11-25-22, 06:45 AM
Kabuki12
Quoted: 645 Post(s)
Liked 1,480 Times in 865 Posts
I’m not too sure but it looks very similar to some Hetchins bikes I’ve seen. Someone with more knowledge should be able to help out. That is a very ornate looking frame.
Kabuki12 is offline
Old 11-25-22, 07:47 AM
Aardwolf
Old Git
Quoted: 124 Post(s)
Looking a Google images Hetchins lugs are even more ornate.
Another thing I spotted is the cable fittings at the top of the down tube.
Seems to be too high for a DT shifter, maybe it's for an internal gear rear hub with handlebar mounted changer ?
Aardwolf is offline
Old 11-25-22, 08:22 AM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
Quoted: 2001 Post(s)
Liked 3,289 Times in 1,381 Posts
Looks like the frame was built for bar end shifters. They were popular in late fifties and early sixties.
I'd be looking for a former (British?) pro with the initials BR, who liked bar end shifters and was active in the 1965 season.
Perhaps.
non-fixie is offline
Likes For non-fixie:
Old 11-25-22, 09:04 AM
juvela
juvela's Avatar
Quoted: 3176 Post(s)
Liked 2,027 Times in 1,421 Posts
certainly appears British from somewhere between the mid nineteensixties and very early nineteen seventies
one house which did bespokes such as this was Condor
juvela is offline
Old 11-25-22, 09:56 AM
Aardwolf
Old Git
Quoted: 124 Post(s)
It's not a 'standard' Condor I think, could be bespoke though.
I almost bought a 1960 Condor No 1 on Wednesday (outbid in last 10 secs)
https://www.ebay.co.uk/itm/Vintage-C...p2047675.l2557
Aardwolf is offline
Old 11-25-22, 10:48 AM
juvela
juvela's Avatar
the only reason mentioned Condor was that they did do bespoke
BICYCLING! magazine did a feature on them BITD and they showed one done for a rock musician decorated with musical notes and instruments
they showed another done for a history professor which had a Battle of Hastings 1066 theme
no wish to assert an identity...mentioned only as a possibility
lug manufacturers offered blanks so that framebuilders could design and cut their own patterns
in the case of a hand-cut pattern it is possible it might be a "one-off" with no other like it in existence...or it could be a design used by a framebuilder to produce a number of frames...
juvela is offline
Likes For juvela:
Old 11-25-22, 12:45 PM
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 1175 Post(s)
Liked 715 Times in 556 Posts
headlugs bear some similarity to Gillott "Fleur de Lis" model but also differences, and you'd expect the forkcrown to be equally "fancy" and not this bog-plain Davis or Haden "Cinelli style".
So likely made as an homage to the Fleur de Lis by a custom (bespoke) builder.
If "BR" are owner's initials then that's going to be a real scavenger hunt, but if they are the builder's then might be a little easier...but maybe not.
Here's one pretty bad clue: "...named after Gillott worker Ron Brown"
unworthy1 is offline
Old 11-25-22, 03:24 PM
roadcrankr
roadcrankr's Avatar
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 138 Post(s)
Liked 178 Times in 98 Posts
This build would make a fun project. Go for it!
That "hit" to the drive-side bottom bracket shell looks troublesome to me.
Especially since the seller did not provide a proper photo.
One must wonder why it got sand or bead blasted, only to let the surface rust return.
At least take a few minutes to hit it with some rattle can primer!
So it will require another bead blast. (It probably got sand-blasted, judging by some metal removal.)
roadcrankr is offline
Old 11-25-22, 03:30 PM
repechage
Quoted: 2685 Post(s)
Liked 1,728 Times in 1,269 Posts
This is a find that one shares AFTER it is bought and in hand.
repechage is offline
Likes For repechage:
Old 11-25-22, 03:31 PM
merziac
merziac's Avatar
Quoted: 3766 Post(s)
Liked 4,411 Times in 2,636 Posts
Nah, smooth out the ding as best you can, chase the threads loctite the cup down and you're good to go.
Can't imagine that being life threatening in any way.
merziac is online now
Old 11-25-22, 04:59 PM
Lattz
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 307 Post(s)
Liked 650 Times in 505 Posts
Bill Hurlow (who built for Condor) comes to my mind, but no 100% match... worth googling more
Hurlow Main
- Lattz
Lattz is offline
Old 11-26-22, 01:20 PM
unworthy1
unworthy1's Avatar
Bill Hurlow popped to mind for me, too, but I decided there was not enough in the OP's example to make it a good match. Hurlow certainly did use a plain full-sloping crown along with very ornate lugs, and some had no headbadge holes (used head decals instead) but...the extremely high quality he generally exhibited is not present in these lugs, IMO.
Of course he built for so many others as contractor, (Holdsworth Shop, Freddie Grubb, Claud Butler, Mal Rees, and Condor) I'm sure he made plenty that were not the gleaming jewels he built under his own brand.
But I wonder if "RB" could have been an apprentice to him, in one of those contact shop deals?
