Benotto? I'm not sure
Bikes: All-City Space Horse
Hello all,
Simply wondering if anyone can shed some light on this bike for me. There are a few Benotto decals on it, but I'm not convinced that's what it actually is. Any information that can be provided is most welcome.
Basically all I know now is that the frame is steel and there are 3 Benotto decals on it -- there's no other markings (at least that I know of) other than "2135" stamped on the underside of the BB.
Many thanks in advance!
Z
Z
Quoted: 3807 Post(s)
Liked 3,331 Times
suggest to check fork ends to see what name marked with
possible they may read Tange rather than Campag
drive side seat stay appears bowed - could be just a photographic effect...
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
If a parts bin build. So many parts not original. Fork is suspect, does it have Campy drop outs? If not, it is a replacement. Forks don't get lost, they get damaged. So if the fork is a replacement, then I would check the main frame. Read up on a string test.
Wheels, stem, brake levers, rear derailleur, shift levers, all likely not original. No original has little to no effect on ride ability!
Quoted: 790 Post(s)
Liked 1,760 Times
I would agree that it is Mexican model from the late 70's. As said most of the parts are none original but fine ride wise. Also the frame has been drilled likely by hand for the bottle cage, this and the suspect fork and mixed components would lead me to say pass on this one. As for value if the frame and fork check out as good and everything works nice I would say $150 it is a real Bennotto just not high end and it has some potential issues.
