The Infamous Dork Disc
Likes For CrimsonEclipse:
#53
Quoted: 1106 Post(s)
Liked 1,326 Times
Yes, actually - though it appears to be an integral part of the largest rear sprocket and was IMO probably formed when said largest sprocket was stamped out of 2mm steel sheet vice machined. Shimano made some 5-speed Uniglide versions that were Schwinn Approved.
[ pic snipped ]
The largest rear sprocket is effectively a 28T - the four support arms for the integral "dork disk" replace 4 teeth, so it only has 24 actual teeth.
Edited to add: this is the only example I've ever seen; dunno if Shimano ever made a 6- or 7-speed version.. It's now awaiting a future build (which will be 6-speed; it takes standard Uniglide sprockets and spacers), which likely won't occur for several years in the future. The source purportedly had 2 of these, but the second turned out to be an actual Schwinn Approved 6-speed UG cassette w/o built in spoke protector on the last sprocket. I didn't really mind, as my NOS UG hub set is 6-speed.
Clever design, but likely added too much weight (2mm steel plate is fairly heavy) to catch on industry-wide. Plus, I'm also guessing either Shimano or Schwinn patented the design.
[ pic snipped ]
#55
This was the original question (emphasis added):
Wasn't aware of that one. But it appears to be a freewheel, not a cassette, so it doesn't exactly address @Sy Reene 's question above.
That may indeed be a second example, provided it came from a Maillard cassette vice a freewheel. (I believe some of their cassettes did use a 3-spline pattern, but my Maillard freewheel/cassette knowledge is rather scant.) But if so I think the Shimano example I posted may predate it, since it dates to the 5-speed Uniglide era (introduced 1979/1980).
Likes For sweeks:
#57
Advocatus Diaboli
Quoted: 4731 Post(s)
Liked 1,531 Times
I've got one of the Prestacycle Uniblock cassettes. Something like this tech to add on an elegant dork ring might have some appeal (at least for the MTB crowd)
#58
I guess these are examples, but don't see either A) why the 'dork' portion is so much larger than the largest cog, or B) why it required using some of the area that teeth would have been.
Whether they'd sell or not, dunno. Adding one would add weight (carbon steel's density is approx 7.84g/cm^3), as well as additional cost in terms of materials and programming/machining time.
My guess is that most buyers would perceive that the extra weight and cost isn't worth it and that it wouldn't sell well enough to be viable. But I could well be wrong.
#59
Over the hill
Quoted: 996 Post(s)
Liked 1,204 Times
Edit: It looks like some manufacturers have made them, but abandoned them.
https://www.wmsracing.com/instructio...ct_install.pdf
It's like riding a bicycle
#60
I am potato.
Quoted: 1788 Post(s)
Liked 1,627 Times
I'd certainly think that would be possible, especially given today's CNC machining capabilities.
11-32 10 speed,
a few 11-32 & 11-28 11 speeds to put on 10-speed freehub bodies that aren't 11
& 2 of the new 11-42 cassettes with the last 2 cogs cnc'd 7075 aluminum.
Their weight is plus/minus a couple of grams of SRAM RED/Dura-Ace and that's nice-n-all, but critically they wear longer than SRAM's Titanium & avoid Shimano's poor design of of individual cogs biting on aluminum freehub bodies.
That the 11-42 saves ~200grams over the same XT cassette doesn't hurt either.
Car dependency is a tax.
#61
Shimano used steel and titanium in their freehub bodies - and went back to it after their short-lived foray into alloy with taller-splined Dura Ace freehubs - for a good reason: it was more durable, and didn't get marred by steel cogs which most everybody was using at the time. If other manufacturers chose to use a less durable material when building a Shimano-compatible freehub in order to save a bit of weight, then that was the other manufacturers' choice - not Shimano's.
I don't find it reasonable to blame Shimano for another manufacturer's decision to make a clone of Shimano's original design out of less durable materials when problems with those less durable materials surface during use.
#62
I am potato.
Liked 1,627 Times
Fair.
#63
Advocatus Diaboli
Liked 1,531 Times
aerobie referenced shape :-)
#64
Might be interesting. The spoke protecting disc of course could be thinner gauged and doesn't need a lot of structural strength, (ie. as need to handle the chain torque). eg. machined outer aerobie type disc, coming off the largest cog. Maybe relatively little weight added?
(image omitted)
(image omitted)
The problem I'd see would be the actual fabrication if done as part of a monoblock cassette like the Presta/Edco/SRAM monoblock variants. These are machined out of a single piece of steel (some with larger rear cogs may have one or two alloy cogs attached in lieu of the largest 1 or 2 cogs being part of the steel monoblock to save weight). In the case of the Presta, that is CroMo steel.
Therein lies the problem IMO. Unless you wanted to machine it separately and attach it, it would require a larger billet. And that larger billet would require more time to program and machine. It would also generate more wear and tear on the CNC machinery, particularly the cutting heads, and would generate more waste steel millings.
Significant? Perhaps - or perhaps not. But a manufacturer would have to take that into account and price the cassette with protector disk accordingly higher. (Well, they would if they wanted to stay in business over the long term. Otherwise, maybe not. )
My guess is that an add-on - maybe one added via rivets to the largest cog - would turn out to be far more practical to manufacture. Dunno if it would sell or not.
Related, but different subject: ran across this. It seems to be a niche product aimed at the downhill biking community. It apparently replaces the largest 3 sprockets on a10-speed cassette that normally uses a spider to hold the three largest sprockets.
Not my style, but it does have a certain . . . different look. And while it appears pretty thick, since it's alloy it's not all that heavy (<50g).
Link: https://www.ebay.com/itm/25285625378
No endorsement of product intended; no experience with the vendor. Link provided for info only.
Last edited by Hondo6; 01-17-23 at 07:56 AM. Reason: Wording changes, add link, correct typo.
Likes For Hondo6:
#65
Quoted: 99 Post(s)
The disc could indeed be thinner than a rear sprocket - though you'd still want it to be thick enough to do its job. 10- and 11-speed rear sprockets are already down to 1.6mm thick. Would 0.5mm be enough? 0.75mm? Dunno.
#66
Quoted: 513 Post(s)
Liked 447 Times
Personally, the spoke protector is the second thing I remove from my own new bike, after reflectors, especially the ones in the spokes. But if you elect to keep yours, fair enough. But if it does start to spin around the hub and make a racket, please remove or replace it.
Likes For oldbobcat:
#67
Quoted: 980 Post(s)
Liked 582 Times
22 years without a spoke protector
23 years without a spoke protector
47 years without a spoke protector!
#68
Quoted: 1607 Post(s)
Liked 2,580 Times
I've found that if the rear derailleur is properly adjusted, there's little risk of the chain shifting into the spokes. As for reflectors, many tires have reflective sidewalls, providing a safety factor without the thing stuck in the spokes.
Likes For curbtender:
#69
Quoted: 980 Post(s)
Liked 582 Times
That's a 'poke protector!
Speaking of protectors, check out the home-brew crud guard for the front derailleur made from a plastic bottle and spray painted aluminum.
Likes For sweeks:
#70
Quoted: 137 Post(s)
Liked 81 Times
I have put a midrive motor on my bike along with a derailleur hanger extension for the big cassette. With all the off road riding, sticks and flex at the derailleur I’ve gone through two derailleurs and hangers with the latest mishap mangling the spokes much worse than that. I’m putting spoke protecters on these wheels from now on.
