Wobbly Rear Wheel :(
Old 09-20-10, 05:25 PM
DrMcNasty420
Bikes: Cannondale R3000
So I am fairly new to road cycling and have an issue with my rear wheel. I had just replaced the tube in the rear tire and popped it back on the bike only to find that the back tire wobbles. The wobble occurs when you grab a hold of the rear tire and move it from side to side. There have been no adjustments made to the rear tire/rim. It does have a quick release, but I made sure that it was nice and snug a few times. What could the wobble be caused by? How much would it cost to get fixed? thanks for the help, I just want to ride!
DrMcNasty420 is offline
Old 09-20-10, 05:39 PM
CACycling
Bikes: 2009 Fuji Roubaix RC; 2011 Fuji Cross 2.0; '92 Diamond Back Ascent EX
Liked 15 Times in 12 Posts
SOunds like the cones are loose. Easy adjustment that shouldn't cost much. Depending on the age of the wheelset, may want to get the hub serviced instead of just adjusted.
CACycling is offline
Old 09-20-10, 05:51 PM
DrMcNasty420
The wheel sets came with the bike when I bought it (Bontrager Select Aeros) the bike is a Cannondale R3000. Thanks for the reply!
Old 09-20-10, 06:56 PM
Al1943
Liked 5 Times in 4 Posts
Be sure the axle is fully seated in the dropouts. The skewer should be closed with the bike standing on the wheels.
Al1943 is offline
Old 09-20-10, 07:01 PM
DrMcNasty420
I've taken the wheel off and put it back on a couple of times and made sure it is fully seated in the dropouts.
Old 09-20-10, 07:31 PM
Al1943
I agree with CACycling, it sounds as if the bearing cones need adjusting.
Al1943 is offline
Old 09-20-10, 09:21 PM
Randallissimo
Wilma!!
Randallissimo's Avatar
Spark up some 420 and it won't matter.
Randallissimo is offline
Old 09-21-10, 01:35 AM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 1496 Post(s)
Liked 702 Times in 497 Posts
If you're lucky, the locknuts won't be completely loose and you can fix it without buying a cone wrench (which I'd advise anyway).
Just get a couple of shifters or whatever, and tighten the locknuts until the spindle has only a tiny rattle. This will disappear when the QR is tightened.
The above technique won't work though if your spindle is the type with a groove or flat along it and keyed washers. If you have this type you can actually do without a cone wrench altogether; just substitute painstaking fiddliness.
Kimmo is offline
Crashola
Bicycle Mechanics
25
05-11-18 08:10 AM
Eric0053
General Cycling Discussion
39
07-11-17 07:35 AM
vol
Bicycle Mechanics
14
12-01-15 07:44 PM
melvinator
61
02-02-13 06:09 PM
ben4345
Commuting
9
11-06-12 12:45 AM
