Cannot fit rear wheel into dropouts after tire/tube change
Old 02-11-12, 07:01 PM
Goriot
Bikes: CAAD 9 Tiagra, DaVinci Madrid, DaVinci Oslo, CAAD 10 (one day)
Hey guys,
Long time since I've been on here-
Recently had a bad rear flat on my trek 7.3fx, over glass. Both the tire and tube were gone. I found the stock bontrager tire that came with the bike and put it on the wheel with a new tube easily.
Now, I can't for the life of me get the wheel back into the dropouts. Its about 1cm away from the perfect fit, but just won't go the extra last bit.
fyi I removed the wheel in the wrong gear, and corrected this only afterwards. Brakes are open. I'm not sure what to do next.
So two questions:
1. How do you get the rear wheel to fit snug in the dropouts?
2. Is it alright to use two different tires, both are 700x32.
Thanks
Goriot is offline
Old 02-11-12, 07:45 PM
gmt13
Half way there
gmt13's Avatar
Bikes: 69 Hercules, 73 Raleigh Sports, 74 Raliegh Competition, 78 Nishiki Professional, 79 Nishiki International, 83 Colnago Super, 83 Viner Junior
Are you saying that you can't get it into the dropouts? Some bikes need to have the tire deflated when installing. You inflate it once it's on. I know, not great, but that's the way it is.
If not the above: If you have gotten it into the dropout, are you saying that it's not lining up right or something? A better explanation or a picture may help.
-G
gmt13 is offline
Old 02-11-12, 08:21 PM
Goriot
No matter how I play with the derailleur I can't move it in. The tire is fully inflated, I will try to deflate.
Thanks.
File Type: jpg
File Type: jpg
Goriot is offline
Old 02-11-12, 08:32 PM
FBinNY
Quoted: 4903 Post(s)
Liked 973 Times in 574 Posts
First thing, shift the lever to high gear and put the chain onto the smallest sprocket. This eliminates any chance that the RD position and sprocket don't match. It also improves clearance past the hanger on some bikes.
Then, I prefer to work right side up with the wheel on the floor. I pull the wheel back, jiggle it and push the frame down onto the axle. The other issue might (but shouldn't) be that the frame is a bit narrower than the axle and needs to be spread slightly when you put the wheel in.
Try the above and come back with results.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 02-11-12, 08:59 PM
AlphaDogg
I let the dogs out
AlphaDogg's Avatar
Bikes: 2011 Fuji Roubaix 1.0, 2003 Ti Merlin Solis, & 1994 Raleigh MT200
Maybe try opening up the skewer?
AlphaDogg is offline
Old 02-11-12, 10:10 PM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 646 Post(s)
Liked 332 Times in 217 Posts
He's doing this without the skewer in place.
Wonder if the frame is a bit narrow, as suggested by FBinNY.
JanMM is offline
Old 02-11-12, 10:20 PM
cyclist2000
cyclist2000's Avatar
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, and looking for a Brompton M6R or T-line
Quoted: 301 Post(s)
Liked 1,977 Times in 585 Posts
It could be a bit narrow some bikes are 132.5 mm so you can fit a 130mm hub or a 135mm hub.
So spread the dropouts apart when installing.
cyclist2000 is offline
Old 02-11-12, 10:42 PM
JTGraphics
JTGraphics's Avatar
Just place the non drive side into the chain stay put your thumb on the cassatte and fingers on the inside of the drive side stay and push the stay will move out slihtly and drop in.
The frame seems to be slightly narrower than the wheel for some reason not a big deal.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
JTGraphics is offline
Old 02-12-12, 12:16 PM
Goriot
The wheel is in; I did it with the bike upright, little bit of pull on the wheel and spreading the dropouts. Weird because I've never had this problem before. This rear change was tough...
Just took it out for a quick spin, seems to be in nice, frictionless spinning- however with all the stress I put on the DR during the repair, I'm noticing that its now lagging when I switch gears by one/two revolutions... suggestions?
Also, I imagine its no big deal to have two separate tires on?
Thanks for the help.
Goriot is offline
Old 02-12-12, 12:18 PM
AlphaDogg
I let the dogs out
AlphaDogg's Avatar
Not a big deal to have two different tires on, as long as they're relatively the same width. Did you bend your derailleur cage or hanger?
Old 02-12-12, 12:32 PM
FBinNY
No issue with unmatched tires, that only counts when tires on the same axle of a car don't match. Front/rear non-matches are common in all kinds of vehicles, bikes, cars, trucks, etc.
Odds are the RD is a bit out of trim. First make sure it's all the way forward to the stop, then fine tune the shifting/trim with the cable adjuster.
BTW- I don't know if it made a difference or not, but if you get in the habit of always shifting to high to remove or install wheels it'll be a bit easier, and you'll never have to guess which sprocket to put the chain on.
FB
Chain-L site
FBinNY is offline
Old 02-12-12, 05:00 PM
Al1943
Liked 5 Times in 4 Posts
Since you have vertical dropouts, like most modern bikes, always mount the bike to the wheel with the wheel on the ground and the bike right-side-up. The wheel axle needs to be fully seated in the dropouts.
Al1943 is offline
Old 02-12-12, 07:26 PM
Goriot
Thanks for all the suggestions. I did a little more tuning, and took it out for a good 30km hill ride, it did the trick. I then went to LBS, and obviously DR has some problems, wheels out of true, chain worn out etc, so now its getting early spring tune up anyways =)
Now to focus attention on the road bike.
Goriot is offline
Old 02-12-12, 08:30 PM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 1496 Post(s)
Liked 702 Times in 497 Posts
Hey guys,
Despite the fact most folks don't realise it, it makes perfect sense to use a size smaller on the front.
There's less weight on it.
Kimmo is offline
Old 10-01-12, 12:05 AM
IntoTheSunset
Last night I, too, was unable to fit my rear wheel back into its drop-outs. It turned out that when I had removed the wheel and had completely unscrewed the drive-side nut, dropping the spring coil to the floor, I had replaced the coil backwards. The wide end of the coil was facing toward the cassette, and blocked the wheel from fitting into the drop-out. I'm new at this. Someone pointed out the reversal, put the coil in the right way (narrow end inward), and voila! Back on the road.
IntoTheSunset is offline
Old 10-01-12, 12:16 AM
Kimmo
bike whisperer
Kimmo's Avatar
OMG DON'T DO IT!!!
Actually, front/rear specific makes a lot of sense. Skinnier on the front for the road, fatter/more aggressive tread on the front offroad.
Kimmo is offline
Old 10-01-12, 05:05 AM
tomacropod
ot.net slave
Bikes: Salsa mtb * 3, Intense mtb * 1, Abeni SS rd * 1, Salsa road/touring * 2, Trek Damn one * 1, Vintage/projects * many
This problem is sometimes seen when narrow pannier racks are installed. Had a rack fitted since the last time the wheel came out?
- Joel
tomacropod is offline
blump
Bicycle Mechanics
10
11-22-22 03:10 PM
Oneder
Bicycle Mechanics
5
04-07-18 05:59 PM
eronc
Bicycle Mechanics
13
07-23-16 01:56 PM
Tuftyclub
Bicycle Mechanics
5
10-04-14 04:23 PM
melvinator
61
02-02-13 06:09 PM
