Old 10-03-22, 03:38 PM
  #5401
RCMoeur
Cantilever believer
RCMoeur's Avatar
Quoted: 520 Post(s)
Liked 1,785 Times in 811 Posts
Bike-fixing season is in, well, high gear in our area, and I now have 28 donated bikes in various degrees of disarray in the back yard and garage, not counting our own family's bikes. Many of these are going to the Recycle Your Bicycle program for foster kids in the Phoenix area, and some are going to a local church's bike giveaway program. Five nicer bikes went to the Rusty Spoke bike cooperative downtown yesterday morning.
Most of the fixer-upper bikes are from the 1980s to late 1990s - name brands, 6-8 cogs on the freewheel or cassette, etc. Many of the bikes have Rapidfire shifters that have "gummed up" over the years and will no longer shift. I've found that puling the shifter and dunking it in an ultrasonic cleaner for about 30-40 minutes (periodically working the pawls to loosen them up) gets the old Shimano grease out so they can shift again. Short-term fixes like Clean Streak will get them shifting for a short period, but they inevitably freeze up again as the solvent evaporates and the old grease re-solidifies.
As for my own bikes, I took my 1972 Raleigh Pro Mk 4 (that I've owned since 1982) on a steep ride last month, and the bar-end shifter worked loose.
So I looked at the shifter, and the cable was also frayed.
So I pulled the cable, and realized I wanted to swap the handlebars (put the current Scott AT-2s on another bike & install narrower Nitto pusruit bars).
So I try to pull the stem, and discovered it was seized in the Reynolds 531 steerer tube.
And once I pulled the stem (aided by penetrant and copious inappropriate language) I discovered the OMAS headset was shot.
(I think you all know how that goes...)
Progress: I did install a NOS Tange Levin headset on the Pro yesterday, so at least I've made progress on one of my own bikes. Hoping to have it reassembled some time while the weather is nice.
RCMoeur is online now
Old 10-03-22, 05:12 PM
  #5402
Chombi1
Chombi1's Avatar
Quoted: 1635 Post(s)
Liked 823 Times in 532 Posts
Finally got to overhaul my pair of Campy Superleggeri pedals with Ti axles. I had been planning to do so for more than a year.
Had a hell of a time chasing after the teeny tiny 1/8" bearings as the light Phil Wood grease I was using won't keep them on their races when I was putting the axles back in.
Worse yet I found out later that I put the wrong axles on the wrong pedals when I could not screw them on to my bike's crank arms so I had to do them all over again......
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
Chombi1 is offline
Likes For Chombi1:
Old 10-03-22, 05:15 PM
  #5403
52telecaster
ambulatory senior
52telecaster's Avatar
Quoted: 1954 Post(s)
Liked 3,657 Times in 1,677 Posts
Originally Posted by ascherer
I decided that I’d reached the point of diminishing returns (and temperatures) and decided to prime the Falcon frame. I attacked a few more bits, masked the stays, wiped it down and hit it with spray.bike primer out in shed #3 which is a former standby generator shed. I’d rate my coverage 90%, and as expected it revealed a few spots that rub my OCD-ness just right. So I’ll tend to them next weekend and see if I can get the color on it. Decals from Greg Softley are clearing customs, some may go down before the 2K gloss coat, specifically the Reynolds ones and maybe the “Ernie Clements” ones, but I’m thinking of putting the foil Falcon ones on top. Can’t say why. Change my mind?
​​​​​​Looks terrific to me.... And I'm glad I don't have your ocd.
52telecaster is offline
Likes For 52telecaster:
Old 10-03-22, 05:24 PM
  #5404
merziac
merziac's Avatar
Quoted: 4501 Post(s)
Liked 6,367 Times in 3,663 Posts
Originally Posted by dpmoo
I've found Bleche Wite Tire Cleaner to do a bang up job on old dirty hoods.
I would proceed with caution, that stuff is oldschool, can have some very robust results.
merziac is offline
Old 10-03-22, 05:32 PM
  #5405
Chombi1
Chombi1's Avatar
I agree..... I thought Bleche White died off already with white sidewall tires on cars, many years ago. I would go with something more modern and maybe less harsh..... A lot of these hoods are quite delicate and getting to be unobtainium these days.
Chombi1 is offline
Likes For Chombi1:
Old 10-03-22, 05:38 PM
  #5406
merziac
merziac's Avatar
Originally Posted by Chombi1
I agree..... I thought Bleche White died off already with white sidewall tires on cars, many years ago. I would go with something more modern and maybe less harsh..... A lot of these hoods are quite delicate and getting to be unobtainable these days.
I think it has probably been dumbed down by now, no way something strong enough to take black rash off whitewalls will be tolerated now days, especially in CA.
merziac is offline
Old 10-03-22, 06:44 PM
  #5407
Kabuki12
Quoted: 870 Post(s)
Liked 2,264 Times in 1,268 Posts
I feel your pain. I did my third set of Ti Superleggeri pedals just before Eroica and those stinking little balls got to me. I could’ve done two sets of steel spindle in the same amount of time.
Kabuki12 is offline
Old 10-03-22, 07:32 PM
  #5408
ascherer
ascherer's Avatar
Quoted: 938 Post(s)
Liked 2,915 Times in 974 Posts
Originally Posted by 52telecaster;[url=tel:22667704
22667704[/url]]​​​​​​Looks terrific to me.... And I'm glad I don't have your ocd.
Thanks, man. At least I’m not ordering finishing files on Amazon!
ascherer is offline
Likes For ascherer:
Old 10-03-22, 08:58 PM
  #5409
merziac
merziac's Avatar
What are you waiting for?
Looks great, glad its you and not me.
merziac is offline
Likes For merziac:
Old 10-04-22, 06:57 AM
  #5410
stardognine
Partially Sane.
stardognine's Avatar
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times in 468 Posts
I finally changed my bottom bracket yesterday, on my Soma Saga. It has an Ultegra 6603 crank, and I put on a Deore MTB BB, using the old inner sleeve. 😎
I also changed the 30t small chainring, for a 28t, which definitely helps on hills. 👍 I might even go smaller, if I can find a proper chainring. 🤔
stardognine is offline
Likes For stardognine:
Old 10-04-22, 09:59 AM
  #5411
DQRider
Old Boy
DQRider's Avatar
Quoted: 984 Post(s)
Liked 1,715 Times in 611 Posts
SOMA Saga? Ooh... pics please?
USMC 1981-1991 Semper Fi!
DQRider is offline
Old 10-04-22, 10:06 AM
  #5412
repechage
Quoted: 3463 Post(s)
Liked 2,826 Times in 1,994 Posts
I recently did a set of those. The small bearings and the shallow cone and race shape makes them a buggar to assemble.
the inboard side is easier but the outboard end is a definite challenge.
my solution was a bored hole into a scrap of thick hardwood big enough for the spindle to be freestanding but no more with an upright to hold the pedal body vertical.
that stabilized the parts and loading the bearings was relatively easy after.
tweezers at hand.
I only have one set of Super Record pedals purchased by accident with a bike so fitted.
upon taking them apart noted that one pedal was short 2 bearings. Must have frustrated a mechanic prior.
this set up speeds any Campagnolo pedal assembly but the regular pedals are so much easier.
the bike so fitted, provisional assembly.
repechage is offline
Likes For repechage:
Old 10-04-22, 03:15 PM
  #5413
dpmoo
Liked 4 Times in 4 Posts
I'm in PA, ordered the bleche wite on eBay, never been to California, but I've had nothing but success, and no negative side effects, with bleche wite on 1980's white dia compe and Shimano hoods. I spray some in a plastic container, water it down, soak and toothbrush scrub. It cleans my car tires really well too, they're black.
dpmoo is offline
Likes For dpmoo:
Old 10-04-22, 04:05 PM
  #5414
merziac
merziac's Avatar
tweezers at hand.
Pic of the tool, it work for regular too?
merziac is offline
Likes For merziac:
Old 10-04-22, 04:12 PM
  #5415
merziac
merziac's Avatar
Guess I should have assumed you were diluting it.
And yes it is for all tires but as the "wite" in the name denotes, it was originally the go to for white walls that were really a thing for a long time.
Glad you get the good results you are getting, its always great to find a good process for things that are a PITA.
merziac is offline
Old 10-04-22, 04:14 PM
  #5416
repechage
Not a tool, but an assembly fixture I would call it, will get to it.
here is a quick schematic
thin rectangle nests in the pedal frame.
toe strap holds the pedal.
spindle thread indexes with bore.
Old 10-04-22, 05:03 PM
  #5417
dpmoo
I think not assuming is appropriate conventional wisdom. Please, keep it up. And thank you for helping me get to my first 10 posts.
dpmoo is offline
Likes For dpmoo:
Old 10-05-22, 07:26 AM
  #5418
Kabuki12
Quoted: 870 Post(s)
tweezers at hand.
Thanks for the tip!! I have 3 sets , as I said , and a few sets of the steel spindle pedals. It has been a while since I did a couple of the sets so I need to at least check them. I did the set in the pic just before Eroica for my Colnago as I had just bought them and they didn't feel very smooth even though I could see grease on the outboard side. The other two sets are butter smooth and taking the dust cap off shows nice grease but I dunno , I didn't do them so..... I will make a fixture as you did.The first set of them came to me as a gift from a guy who needed his '73 Paramount assembled and HATES traps and straps so he took the Sweet Campy pedals (still in bubble wrap) and handed them to me. I had no idea that they were Ti until a few months later when I decided to put them on one of my bikes and removed the Japanese copy cat pedals and unwrapped the Campy one and....Holy Cow these things are light! The magnet solved the mystery . Joe
Kabuki12 is offline
Old 10-06-22, 08:35 AM
  #5419
Sierra
Uff Da!
Quoted: 68 Post(s)
Liked 180 Times in 90 Posts
Early seventies Gitane Super Corsa
Just finished building this up.
Bought the frame set years ago and it's just been hanging in the garage since.
Used as much Campagnolo as I could, but with "geezer gearing" for my geezer legs and the southern Wisconsin topography.
Had most of the parts in my stash, but had to pay an arm & leg for the French threaded BB cups for the triple crank set.
I think it looks pretty good from about 10'. Closer than that you can begin to see the wear & tear.
Sierra is offline
Likes For Sierra:
Old 10-06-22, 10:15 AM
  #5420
dpmoo
Cables and Stops
I'm restoring a 1982 Puch Luzern and an '86 Centurion Ironman (aka Loretta); they're my first build and restoration projects, got the Puch as a test case because Loretta's special to me. Are there any particular shift and brake cables and housings that you would recommend for these? Both are running Shimano 600 (6208) groupsets.
Also, the Puch has limited braze ons (I'm going to have down tube posts brazed on and I have to replace one on Loretta). I came across the following front derailleur cable stop on eBay (though the seller won't budge on a ridiculous price for the derailleur and cable stop set). This cable stop is made to fit into the groove on the FD-6207 front derailleur, which I think is pretty awesome (never knew about the stop till I saw it on the eBay listing). Does anyone know where I may be able to get my hands on one of these cable stops?? (I've exhausted all negotiations with the eBay seller, who initially asked for $38 and came down to $29 until finally raising the price $54, I apparently convinced him of the rarity of the item in his possession).
Alternatively, I'm thinking I'd drill and file a slot into the same groove location on the front derailleur to fit the following, more readily accessible cable stop. I'd really appreciate any suggestions or cautions on why this alternative would not work (I think I'm relying on the brake cable housing from the front derailleur cable stop to the clamp-on down tube cable guide to hold the FD cable stop in place within the slot).
Thanks so much for all the input that's bound to come!
dpmoo is offline
Old 10-06-22, 10:16 AM
  #5421
dpmoo
Did those photos come through?
dpmoo is offline
Old 10-06-22, 11:51 AM
  #5422
dpmoo
Cables and Stop
dpmoo is offline
Old 10-07-22, 11:47 AM
  #5423
ascherer
ascherer's Avatar
Quoted: 938 Post(s)
Pretty pleased with the spray.bike experience! Everything others have said about using it is true, it was really pretty easy for me. The color is perhaps a bit darker than Falcon used but it's close enough for me. I tacked the headbadge on for reference. I think the blue is a bit lighter than in the photos and given spray.bike's semi-gloss, semi-matte finish it may appear differently once it's got the 2K top coat(s). I sanded and resprayed the divots on the head tube and lug, and now I wait for the transfers to arrive so I can place them and hit it with gloss.
ascherer is offline
Old 10-07-22, 02:02 PM
  #5424
52telecaster
ambulatory senior
Falcon Head badge is the coolest!
Old 10-07-22, 06:28 PM
  #5425
2wheeljonz
Bikes: Eddy Merckx Titanium, AX, '74 Raleigh International, Velo Orange Randonneur, Trek 7600, Fuji Touring Series V, DeRosa, Miami Vice Ironman, Eddy Merckx 10th Anniversary
Quoted: 47 Post(s)
Liked 69 Times in 22 Posts
I posted about this bike in 2019, not really knowing what I had bought except there were Cinelli pantographs on it (See original post here: https://www.bikeforums.net/classic-v...y-cinelli.html ). I finally got around to overhauling and cleaning it and thought I would post it up.
The original paint was in great shape and polished up nicely. I used some acetone and got rid of the shakey lug lining that a previous owner had put on it. The chrome all polished up nicely. The clear coat on the chrome had yellowed so I removed it. Since there were no decals on it when I purchased it I got some new ones from Velocals which I applied. The Shimano RSX levers that were on it when I got it were replaced with Universal levers to match the Universal brakes. I still don’t know what rims are on it as there is no branding that I was able to find. They were true and in good shape so I just went with them. I believe all other parts are original.
I also listed it in the “What is it Worth” thread so if you have thoughts as to it’s worth, please post there.
Thanks.
Mel
2wheeljonz is offline
Likes For 2wheeljonz:
