Problems with Dura Ace Shifters
Old 06-27-22, 10:42 AM
richas
Bikes: Giant Defy Disc 1
Quoted: 26 Post(s)
Dura Ace 9000 Series -
I am having trouble getting the small lever shifters (Shift to a higher gear) to engage. I know they won't engage if you have inadvertently pressed in the large lever, but they are doing it (not engaging) all the time. I can usually get the to engage by pressing them sloooowly. The problem is that I don't always want to shift slooooowly. I have meticulously cleaned and lubed them, no help.
Is there something that wears to cause this, a spring loosing tension etc?
Thank you
Rich
richas is offline
Old 06-27-22, 10:47 AM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 693 Post(s)
Liked 1,011 Times in 593 Posts
Sounds like a cable issue somewhere along the line. Other than that, I am not jumping into this one.
delbiker1 is offline
Old 06-27-22, 10:50 AM
richas
Quoted: 26 Post(s)
Not a cable issue, the lever is not engaging in the shifter...
I am going to try to lube it again, maybe I am not getting lube where it needs to be.
Rich
richas is offline
Old 06-27-22, 11:43 AM
jp911
Bikes: Trek Madone 5.2 Dura Ace, Niner RLT9 aluminum, Santa Cruz 5010 CC, Niner Air 9 rigid 29er
Quoted: 67 Post(s)
Liked 34 Times in 31 Posts
I've found that fresh cables makes a big difference in the performance of the DA 9000 groupset on my road bike. I try to replace them once a year. The housing I leave alone, but have refreshed the whole setup recently and it's shifting like new.
jp911 is offline
Old 06-27-22, 12:34 PM
headwind15
Bikeable
headwind15's Avatar
Quoted: 164 Post(s)
Liked 101 Times in 70 Posts
From your description its hard to tell what is going on. If the shifter is "ghost" shifting; ie.., you swing the shifter and there are no clicks, you have a shifter with thick coagulated grease inside the shifter that is impairing the ratchet mechanism from engaging. I have found that if you take a cardboard coffee cup and cut it down to three inches tall. fill it with two inches of karosine (I have had success with motor oil) with the cables removed, you need to submerge the shifting part for 20 minutes. (no downside to doing it longer) I did this to a shifter in 2010, and it still shifts fine.
headwind15 is offline
Old 06-27-22, 12:39 PM
Iride01
Plz hurry Dec 22!
Iride01's Avatar
Quoted: 4855 Post(s)
Liked 3,382 Times in 2,344 Posts
Have you pulled the cable out to make certain it's not frayed inside the shifter?
When I hear that going to the high ratio gears is an issue and shifting to the low ratio gears is okay, then frayed cables is my first suspicion.
Iride01 is offline
Likes For Iride01:
Old 06-27-22, 12:42 PM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 3665 Post(s)
Liked 2,068 Times in 1,117 Posts
Rich
Don't think LUBE, think FLUSH. You're trying to get the crud out of the little nooks.
DiabloScott is offline
Likes For DiabloScott:
Old 06-27-22, 12:46 PM
richas
Quoted: 26 Post(s)
Thanks all, I'll go at again to try to get it clean.
Rich
richas is offline
Old 06-27-22, 12:52 PM
base2
Doesn't brain good.
base2's Avatar
Bikes: 5 good ones, and the occasional project.
Quoted: 1238 Post(s)
Liked 905 Times in 529 Posts
Usually the advice is to flush & relube. This is not always the solution.
I've had them work perfectly fine in the hand, but as soon as you put cable tension on them, the ratcheting mechanism does not engage as it should. If this is the case, the shifter has worn too much. Whatever bearing/bushing/bit holds the pawl square & true to the ratchet wheel is no more.
New shifter time?
Car dependency is a tax.
base2 is offline
Old 06-27-22, 01:14 PM
richas
Quoted: 26 Post(s)
New shifter time?
it could be new shifter time. I just inspected them and the internals are very clean but very dry. I lubed with tri-flow and they are working ok. They still miss once in awhile but they are much better.
I keep this bike very clean. It looks like I have removed all the lube.
thanks for all the help, letís see if I can some more life out of these.
rich
richas is offline
Old 06-27-22, 01:20 PM
masi61
masi61's Avatar
Quoted: 981 Post(s)
Liked 319 Times in 226 Posts
What product did you use to clean before you re-lubed?
Also what cable housing and style of cable are you using - bare stainless or the polymer coated type.
masi61 is offline
Old 06-27-22, 05:01 PM
t2p
Bikes: Cannondale - Gary Fisher - Litespeed - Schwinn Paramount - Schwinn (lugged steel) - Trek OCLV
Quoted: 356 Post(s)
Liked 350 Times in 232 Posts
rich
how much use has this bike / shifters seen ?
was the bike sitting (unisex) for a length of time ?
this problem - or similar - is fairly common for Shimano shifters that sat (unused) for a while ; the factory lube / grease thickens and in some cases hardens
t2p is offline
Likes For t2p:
Old 06-27-22, 11:09 PM
MudPie
MudPie's Avatar
Quoted: 98 Post(s)
Liked 98 Times in 76 Posts
rich
Check out the attached video. I've used the method to flush, clean and lube, with great success on a few sets of shifters. They recommend using White Lightning Clean Streak to flush. I like to use WD40 as the primary solvent to degrease and flush out the old grease, then use the Clean Streak as a final "rinse" to remove the WD40 since the Clean Streak dries cleanly. (It's also cheaper this way since WD40 is much cheaper than Clean Streak). The recommended Boeshield is a great light lubricant and protectant. However, I don't dab the grease onto the internals as shown, since it just seems like a dirt magnet. As maintenance, I do spray a shot of Boeshield into the internals once a year.
MudPie is offline
Old 06-28-22, 01:58 PM
Camilo
Quoted: 696 Post(s)
Liked 586 Times in 379 Posts
Rich
Flood the begeebers out of the shifter moving mechanism with WD40, I mean really spray it , let it drip profusely That has helped me in the past.
[edit] Just saw the posted video above - a good one.
Camilo is offline
