Freehub Removal troubles
Quoted: 556 Post(s)
Liked 641 Times
Freehub removal troubles
I an trying to remove a freehub from a 20" wheel.
It's from a 2015-7 Dahon Mariner so it's a 7 speed.
I purchased a 11mm and 12mm alen keys and neither fit perfectly.
But the big problem is it won't break loose.
Yes I'm turning counter clockwise...
But I'm using so much torque that I've already bent 2 cheater bars.
The hex portion of the free hub is about 3/4-to an inch deep instead of at the surface.
I see no other grip or tool type to remove this freehub
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Did you ever think it might be a good idea to include photos?
Likes For cxwrench:
Likes For CrimsonEclipse:
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
Ill be more direct, that was an apparently overly subtle way of saying Most of us dont know what the inside of your less than common part looks like. Why dont you upload a nice clear picture for us? Often when people do that we very quickly spot the problem, and are able to suggest a solution.
Quoted: 556 Post(s)
Liked 641 Times
I’ll be more direct, that was an apparently overly subtle way of saying “Most of us don’t know what the inside of your less than common part looks like. Why don’t you upload a nice clear picture for us? Often when people do that we very quickly spot the problem, and are able to suggest a solution.”
A bit of an oversight on my part.
Edit: the 12mm will fit, now i need a way to apply massive amounts of torque
Quoted: 127 Post(s)
Liked 133 Times
The focal plane isnt exactly in the right spot, but it certainly looks like a hex. When you say the 12 mm doesnt fit perfectly, is it loose, or does it not go in?
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
First I would make extra sure that 12mm is the right size. Then try securing the correct allen wrench in a bench vise and lowering the freehub onto it. Grab the wheel in both hands and "drive the bus," turning the wheel counterclockwise. This works well with 700c wheels; hopefully the 20" wheel will give you enough leverage.
Likes For Rolla:
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,992 Times
Not posting information is never helpful, if you need pictures you should post pictures if you need to tell us what you have tell us what you have. We see this too often with new members but with old members it just doesn't make sense. Sure sometimes cxwrench might seem a little brash but it is a forum on the internet you gotta have enough skin to handle people being honest even if it feels more on the negative side text really doesn't have emotion.
Likes For veganbikes:
Quoted: 8 Post(s)
Liked 17 Times
If the hub isnt on a wheel, get hold of a trashed rim and a half dozen spokes. Lace the hub onto the junk rim and proceed as above.
Quoted: 556 Post(s)
Liked 641 Times
Yeah, my photography skills aren't exactly great.
Well, at least I know that I have the right idea, I just need more gorilla torque on this thing.
Thanks folks.
Guest
Liked 3,270 Times
Likes For Rolla:
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,174 Times
I cleaned up the thread. Let’s stop with the personal attacks.
Likes For StanSeven:
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
I finally did get a 12mm to fit.
That's the delay right now. I do not have access to a vice. I may have a friend hold the wheel while I get a large breaker bar.
Thanks folks.
Thanks folks.
Bikes: lots
Liked 2,932 Times
In lieu of a vice you can put the wheel against a wall, standing, and use the wrench/pipe in the direction that would roll the wheel into the wall. I do this all the time if someone is using the vice and I need to undo a lockring.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
If you bought a cheap bench vise and mounted it to a long board, you could sit on one end of the board to twist off the freehub body...
Likes For sweeks:
Quoted: 7348 Post(s)
Liked 2,465 Times
Americans spell it "vise," while in other countries, it's "vice." I have no idea why.
When man invented the bicycle he reached the peak of his attainments. Elizabeth West, US author
Likes For noglider:
Quoted: 556 Post(s)
Liked 641 Times
Alright, an update.
I took the damn thing to a bike shop, put a 12mm into a vice, and tried to turn the wheel.
First horizontally, then vertically, with two fully grown men , one of them (me) channeling my extended annoyance, at the same time while the 12mm allen key was flexing the better part of 45 degrees.
Any more pressure and the allen key might have failed spectacularly and dangerously.
So, as much as I would like to give up, I'm not.
One of my friends likely has a 12mm socket and an impact wrench.
After that, I'm thinking blowtorch.
After that, thermite.
Maybe a tactical nuclear strike.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Likes For JoeTBM:
Quoted: 114 Post(s)
Liked 119 Times
Alright, an update.
Assuming you get it off, be sure to apply anti-seize or grease to the threads. The freehub fixing bolt need not be installed with gorilla strength.
Likes For MudPie:
Likes For sweeks:
