Leather saddle bag, DIY, what thickness?
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
I'd like to make a black saddle bag to clip behind my Brooks B67. Medium to small in size, not much wider than the saddle. I can punch holes, hand stitch, and figure out the attachments and closure. I will probably either create a template by looking at google images, or find find a pattern online.
Question is, what thickness should the leather be for this project?
I envision the shape being self-supporting, without stiff end caps or sides.
Trying to keep it simple, to match my leather-working experience!
Thanks in advance for any advice, or pics of your favorites.
Quoted: 981 Post(s)
Liked 1,844 Times
Use about 3-4 oz. leather and if you plan to have it made in a cylindrical shape or one where you want the sides or bottom to provide structural support, go up to 9-12 oz. for those parts (essentially saddle skirting). The circle side pieces on this design are thick and the rest of thin leather.
-Gregory
-Gregory
Likes For Kilroy1988:
Quoted: 3464 Post(s)
Liked 2,827 Times
I would go with much thinner leather, machine stitch it and sew in a bone as a shape control.
Likes For repechage:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
I remember someone using an old leather purse for donor material. Easily found at a thrift store.
Likes For gugie:
Quoted: 2337 Post(s)
Liked 2,812 Times
that has a Corporal Klinger feel to it
Likes For squirtdad:
Quoted: 209 Post(s)
Liked 175 Times
Using Kilroy's suggestion of thicker end plugs, I might be able to construct this.
I'd use magnet closures, like these may be. Typical buckles take way too long to open and close.
Some designs use wood as end plugs...I may consider black walnut with black leather.
Quoted: 209 Post(s)
Liked 175 Times
This shape seems doable, also.
A better attachment system, and different closures, would be desired upgrades.
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,047 Times
Old hasps like this ~40's Lycett at the bottom are brilliant. A quick flip or twist and you're in.
The upper shot is a modern Roots bag. Both of these are likely fussy to install but they're proven to last.
Likes For clubman:
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,186 Times
Here's the one I made a couple of weeks ago while home with Covid. The leather is goatskin and is between 1.5-2.5mm. However, I needed to sew in a thin dense foam stiffing panel. It offers a different design to consider.
Bob
Bob
Likes For pastorbobnlnh:
Freewheel Medic
Liked 2,186 Times
Bob
Bob
Liked 5,790 Times
Guilty as charged. https://www.bikeforums.net/classic-v...l#post20924487
Likes For gugie:
For a barrel shaped bag, make sure the top flap overlaps the bottom well. My cheap nylon Banjo Bros nylon bag fails at this, stuff can rattle out. So using thin leather, think about something to reinforce it a little, especially if a single lockstrap
Quoted: 565 Post(s)
Liked 1,045 Times
If a purse is unacceptable as donor material you could butch it up using a leather jacket and a belt or two.
Quoted: 209 Post(s)
Liked 175 Times
Great thoughts and pics, everybody, thanks for sharing!
I don't mind buying the leather. That way I'll get the thickness I want, and in black.
I'll also overlap well, and have a good clasp...maybe like the twist one on the Roots bag above.
Likes For 67tony:
Quoted: 209 Post(s)
Liked 175 Times
Wow, the green and brown handmade leather bags, from the link Pastor Bob posted, using repurposed purses, are VERY cool.
Likes For 67tony:
Liked 2,812 Times
super detail with the matching thread color
