Seating tires with air compressor. Adapter?
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 523 Times
I've recently gone to tubeless and need to find an adapter for my air compressor for seating tires. My air compressor has a Schrader attachment, but the tube has to have that nub in the center for it to release air into the tube. Those adapters you can screw onto the Schrader valve don't have anything to open up the valve on the Schrader compressor adapter. What is the adapter I need called and where do I find one? Thanks!
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
When you use a presta/schraeder adapter, the knurled screw on the top of the presta valve acts as the nub on a schrader:
Likes For Rolla:
You're using presta valves, correct? Take the core out of the tube. Just use a standard air compressor nozzle gun that has a pointed end. Once the beads set, cover the tip of the valve until you screw the core back in. Then let the tire deflate, and keeping the bead sealed, add sealant, add valve core, and re-inflate.
Quoted: 5779 Post(s)
Liked 2,576 Times
From the description it seems that you have a ball chuck of the compressor. As you note, they depend on the valve's stem to depress the pin and start air flow.
Your problem is that your current PV/SV adapter is either too long and/or has too thin a wall, so there's nothing at the right height to engage the chuck's pin. Easiest solution is a shorter adapter, so the PV nut is just slightly sub-flush. Otherwise you can improvise something to make up the gap, ie. a 1/8" ball bearing.
FB
Chain-L site
FB
Chain-L site
Quoted: 418 Post(s)
Liked 523 Times
Quoted: 496 Post(s)
Liked 431 Times
The hose I use for seating tyres has a screw-on fitting for a Schrader valve and a quick coupling to attach it to the compressor. There's no valve in it so it's always open. An eBay search for "screw-on Schrader hose" found several that would do, just add the coupling to suit your system.
Quoted: 2026 Post(s)
Liked 1,096 Times
A company called "Prestacycle" sells a presta valve inflator that has a lever operated valve so it can be attached to an air hose with a quick connect and allows controlled airflow. It works well for "blast" seating tubeless tires with the presta valve core in place or removed.
They are available either as a plain inflator of with a digital or analog pressure gauge. Here is the lowest cost version: https://www.prestacycle.com/product/...tire-inflator/. I have one of these and it works very well.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
I just cut the Schrader chuck off and put a Silca presta chuck on instead:
Quoted: 418 Post(s)
Liked 523 Times
