Pinnacle of bicycle frameset design - opinion(ated?) thread
#51
Quoted: 1639 Post(s)
Liked 829 Times
Actually, I think lugless construction felt like a step backwards when more and more bike manufacturers started featuring such in the framesets (I suspect, to mainly keep costs down), in lieu of lugged construction in the later 80's, especially after being conditioned for many years that "quality" frames are supposed to have lugs......
#52
#53
Sunshine
Quoted: 10954 Post(s)
Liked 7,483 Times
Also, the most popular topic (or a close second) iin this forum s restomods using modern components. Double aught frames are built for that, not 80s bikes. You can easily get under UCI weight limit with modern steel, if you are a weight weenie. Not so easy with an 80s frame. And if you buy into stiffer is better, oversized XCR and 953 are the way to go.
As for easily getting under 15# on a modern steel road bike if you are a weight weenie...not sure how easy that is. I guess it's perspective on cost whether something is or isn't easy. If you have a steel frame you likely aren't a weight weenie to begin with though.
Under 15# can obviously be accomplished, but it's hardly common even for those trying to cut grams so not sure how easy it is in practice.
#54
Sunshine
Liked 7,483 Times
In c&v land, the pinnacle is a road geometry frame with quality tubing and room to fit 32s. Perfect.
Likes For mstateglfr:
#55
Quoted: 2323 Post(s)
Liked 4,984 Times
Steel is real...and comfy.
#56
Quoted: 586 Post(s)
Liked 612 Times
Props to Wildwood for starting this thread! It has been a great read. And some of the examples are absolutely stunning. Thanks also to those who took the time to show their beauties.
#57
Quoted: 3241 Post(s)
Liked 2,512 Times
Those 15lbs and under bikes could have rider weight limits as well. Low spoke count wheelsets might not be for everyone either. I'm a lot closer to Chris Hoy than Chris Froome. I don't want something that could break if ridden hard.
#58
Quoted: 3504 Post(s)
Liked 2,923 Times
Likes For smd4:
#59
Disraeli Gears
#60
Liked 829 Times
While I much prefer lugged bike frames myself, as an art form, lugless frames (welded or fillet-brazed) are clearly in evidence since the '50s, by many reputable constructors, maybe even throughout triangle frame history. Whether because of component shortages, or just maker or buyer preference, or to save a little coin, it isn't some latter-day phenomenon, or limited to some geographic pocket either. An artisanal constructor like R.O. Harrison, who fabricated his own lugs (usually uniquely profiled) out of sheet metal, built quite a few lugless bikes too.
Sure, filet brazed construction was impressive when artisans did it with thoughtful care to the build up of very smooth radiuses at the joints, but most of lugless construction available to the cycling public was the slam- bang weld it together and sell it quick variety.
Likes For Chombi1:
#61
Sunshine
Liked 7,483 Times
#62
Disraeli Gears
Thing that bugged me though was, lugless construction pretty much took over the industry and relegated frame lugs on steel bikes to history. Unless you buy asome sort of "retro special" so now you are paying extra for something that was pretty much standard to bikes from the cheapest to the best one you can get, before the 90's....
Sure, filet brazed construction was impressive when artisans did it with thoughtful care to the build up of very smooth radishes at the joints, but most of lugless construction available to the cycling public was the slam- bang weld it together and sell it quick variety.
#63
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 703 Times
IMO: Lugged construction was the boon and bane of bicycle frame construction into the '80's. It made for cheap, light frames, but restricted frame design to relatively fixed geometry. For instance, large-scale production of larger frame sizes was compromised by the lack of lugs with the proper angles to accommodate the necessary long top tubes. You'd see 62cm seat tube frames with 58cm top tubes...and tall guys riding in weird positions.
When mountain bikes gained popularity in the '80's, frame designs evolved quickly. A year-to-year frame design change is easy to deal with if your frames are welded, much harder to do if they are lugged.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
#64
Quoted: 2337 Post(s)
Liked 2,821 Times
Miyata team
Likes For squirtdad:
#65
Bikes: a few that I can't recall
Quoted: 342 Post(s)
Liked 300 Times
All of the road bike stuff, or even MTB stuff for that matter is very derivative of something before it. Lugged bikes even moreso.
This was a revolution in bicycling, whether we like it or not.
The geometry has been copied so many times, as well as the revolutionary design of the assemblies, and method of assembly, the 1975 Redline can be considered the pinnacle of bicycle frame design.
Likes For Reynolds 531:
#66
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1225 Post(s)
Liked 3,543 Times
Yes, unicrown forks are ugly. I'll take my chrome Cinelli sloping crown any day of the week. Compared to a unicrown, it looks positively bichin.
Threadless headsets are probably easier to adjust for people who don't know how to adjust a proper headset. The stems for threadless headsets--ugly, too.
Sloping top tubes? Ugly. Straight bladed forks, made out of any material? Ugly.
The impressionist painter Renoir said there were enough ugly things in the world without creating more. It's too bad bikes have gone down this path.
Disagree. I think many unicrown forks are smooth, have nice flowing lines, and are a great example of form following function, of which there is an inherent simplistic beauty in. They are probably stronger than most lugged forks as well.
Some of the old quill stems looks good, some are hideous. Most are pretty heavy. Threadless stems are a superior design. Can't remember the last time I had to loosen a frozen threadless stem, or worry about the bottom part of a threadless stem breaking off and losing control of the bike. Can't remember any posts warning against having too little amount of a threadless stem inserted on the steerer.
All of this is probably just a confession. I'm the guy that took a Centurion ironman and put a longer fork on it specifically so I could use a threadless headset and stem on it lol. AND the fork is a unicrown.
Likes For AdventureManCO:
#67
There are also aluminium unicrown/aero'ish forks which resemble carbon forks, they look alright in my opinion.
#68
Liked 4,984 Times
I've got to admit that as beautiful as all the lugwork is on my Kirk Terraplane I'd consider the fork the least appealing part of the bike.
The fork matches the bike for sure but is boring compared to the rest of the lugwork
You know this may be a "pinnacle" bike too with those quite effective terraplane seat stays.
Likes For jamesdak:
#69
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 159 Post(s)
Liked 375 Times
The only exception to the ugly uni-crown fork is the Aero fork on a 3rensho. There is probably a proper name for the style? A beautiful thing!
#70
Fat Guy on a Little Bike
Bikes: Two wheeled ones
Quoted: 1254 Post(s)
Liked 345 Times
#71
Liked 2,512 Times
#72
Quoted: 342 Post(s)
Liked 300 Times
Why? It's all about contrast. The least appealing area of that bike(to me) is where the seatpost comes out of the seat lug. The reason for that is there's no chrome break at that junction. If you look at the stem/head tube/headset, there's a small area at each end that breaks up the chrome.(even if it's just a shadow) Beautiful bike though. Smoking hot color.
#73
Quoted: 981 Post(s)
Liked 1,844 Times
My dark passion has been for French randonneuse bicycles for several years, while all the time I've been collecting, restoring and riding mostly vintage English steel... Based on everything I've read and all of the hundreds upon hundreds of bicycles I've admired in photographs and caught rare glimpses of in person, quite some time ago I came to the conclusion that as far as steel frame designs and accompanying components are concerned, a classic randonneuring frame is probably the best bicycle for the kind of middle-to-long distance amateur countryside riding that I enjoy most. The purposeful nature and thoughtful integration of components such as brake calipers, racks, fenders and lighting systems make them incomparable to any "standard" frame style.
I'll finally be able to test my theory soon enough... For now, some other fine examples!
Likes For Kilroy1988:
#74
The Huffmeister
Liked 3,543 Times
Beautiful!
#75
Dedicated Detritus Dodger
Bikes: Some mighty fine ones at that!
Quoted: 191 Post(s)
Liked 603 Times
My favorite rides have 1 1/2 to 3" of daylight between the rear tire and the back of the the seat tube.
