General advice on bike repair?
Hello, everyone! I just purchased an 86 Bianchi Special in purple and want to convert it to single-speed/fixed-gear. Eventually, I'd like to update all, if not most, of the components. First question, is there anything I should know (as far as general maintenance goes) prior to repairing this bike by myself?
Second, do you all recommend any websites for purchasing good parts? Right now, I'm considering purchasing a wheelset, but am unsure where to buy it from.
Anyway, super stoked to be a part of this forum!
mechanically sound
If sheldon brown’s website is still around, it has almost everything you need to know.
Likes For frankenmike:
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
First be sure the seat post and handle bar stem move. If they do, grease them up now.
If it has 27" wheels now and you want to change it to 700C, verify the brake shoes have at least 4 mm of free movement in the caliper toward the axle.
Likes For andrewclaus:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
That's not a bike I'd choose to convert, but good luck to you. If it's the same frame as the photo, be prepared to experiment with gear ratios, as the dropouts give you very little room to tension the chain. You'll likely need compromise your desired gear combo to make it work.
Likes For Rolla:
Quoted: 5779 Post(s)
Liked 2,576 Times
That will solve the problem if he's riding single speed free wheel. But if he's planning to use fixed gear there will be issues with the backlash when he tries to brake. The degree of problem really depends on the amount of slack in the lower loop.
FWIW the OP doesn't even have to spend money for that idler arm he can simply keep the derailleur locked in directly under his one sprocket.
FB
Chain-L site
FB
Chain-L site
Quoted: 676 Post(s)
Liked 741 Times
If you don't match the existing dropout spacing, you should change the spacing. See this article: https://www.sheldonbrown.com/frame-spacing.html
I've cold set several older frames for updated hubs, but I've had access to shop tools and help. If there's a bike co-op in your area, that'll be a great resource.
Guest
Liked 3,270 Times
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Likes For JohnDThompson:
Quoted: 1609 Post(s)
Liked 2,590 Times
You should browse here... https://www.bikeforums.net/singlespeed-fixed-gear/
Whatever you do, don't start hacking off parts. That would get you branded as a 'drew.
Professional amateur
Bikes: Does a Big Wheel count ?
Quoted: 302 Post(s)
Liked 136 Times
Though their selection can be limited and kind of off-the-wall, a good site to check for random bike parts is....well....um.....Random Bike Parts !
Ive snagged a couple good parts and a nice frame from them. And, they do free shipping.
