GP5000 28mm pressures you run?
Should Be More Popular
Quoted: 22571 Post(s)
Liked 8,918 Times
Likes For datlas:
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,849 Times
Quoted: 2693 Post(s)
Liked 485 Times
The rider weight is important.. most of the tests are done with smaller riders. Also there is the financial aspect, the UCI has been compromised for decades and Big Gravel isn't much better. it's not like it will fail putting 40 extra psi of pressure in the tire... you could run 23s at 200 probably? The hard tire gives a harsher ride that feels faster even if it isn't which some people enjoy. A bike shop owner told me they overinflate tires for test rides for this reason, makes the bike feel fast.
Liked 11,849 Times
So, they aren't any faster, but they FEEL faster?
It's not just the harsher ride. They also handle worse. Instead of absorbing lumpy pavement in corners, they'll hop, and with all that centrifugal force, they'll hop sideways. You were asking about how to corner faster? That ain't how.
Quoted: 18883 Post(s)
Liked 10,646 Times
For the OP, I run 70 to 80 psi @ 28 mm depending on the day and what I'll be riding on.
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
Yeah I just like rear tire higher psi
I am gravitating to 85psi rear and 65 front
guess I just got used to it
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Likes For Sy Reene:
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
There are nuances to these of course but making these statements as fact is dangerous and could get people injured.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
I dunno if I'd go that far. If Larry and his bike together weigh about 285 lbs, plugging that into the 15% drop calculator gives 130 psi for 25mm tires. He's only a bit north of that.
Quoted: 406 Post(s)
Liked 389 Times
Liked 2,563 Times
It wouldn't be my choice either, but I've seen bigger people use smaller tires.
Liked 8,918 Times
If he asked me, of course I would suggest 28 but even at his weight he would likely do well at 100-105F and 110-115R. 140 is way too high. And the 15% drop rule is arbitrary, I am not an expert but pretty sure there is no science to that versus 18% or 12%. It’s a round number.
Liked 2,563 Times
Advocatus Diaboli
Liked 1,531 Times
Maybe why Vittoria Corsas have 145psi max on their sidewalls.
Likes For Sy Reene:
Liked 11,849 Times
Larry ain't even on the chart. Hell, I ain't even on the chart and I weigh 60# less!
Advocatus Diaboli
Liked 1,531 Times
Likes For Sy Reene:
Quoted: 345 Post(s)
Liked 237 Times
Wow
Reduced pressure by 5psi per tire and was surprised how much more comfortable and less bouncy on rough roads it was for downhills.
latest setting is 75 psi rear 60 psi front for 28mm GP5000
(at least on the rear tire) I felt 70 psi was too squishy and 80 bounced a bit on rough roads doing fast descents. Really surprised
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
I am close to you (weight, bike model, tire model) and am at a similar spot on pressures as where you are at now. I run them a bit less in wet conditions.
Likes For scottfsmith:
Advocatus Diaboli
Liked 1,531 Times
What is tangentially interesting is how most everyone might suggest that the LarryS scenario of 140psi in 25s is way too much, but this same chart also says that's correct. What would cause the Berto vs "Modern" models to incrementally diverge further apart from one another at higher rider+bike weights?
don't try this at home.
Quoted: 972 Post(s)
Liked 509 Times
It's interesting how many of the riders in this thread are using similar pressures, or scaled similarly to their different weights.
At 170 pounds, I was using 65 and 72-75 psi. Now, it's usually 70-72 and 78-80.
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 411 Post(s)
Liked 895 Times
I weigh 220 lbs, and am running my 28s (different brand) at 80/85 psi f/r
Quoted: 406 Post(s)
Liked 389 Times
I don't know if I find it humorous or what, but you're pretty much matching the Berto graph chart a couple posts up for a 45/55% F/R split on your total weight.
I find the Silca calculator to be pretty spot on.
