Tips to make my TRP Spyre/Tiagra disc brake more powerful
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, Circe Morpheus, 2021 Rose Backroad, 2017 Devinci Hatchet
Quoted: 181 Post(s)
Liked 14 Times
Hi all,
I have a gravel bike with TRP Spyre mechanical disc brakes and Tiagra 4700 STI levers. The levers feel fairly stiff and I need a lot of hand force to getting close to locking up the rear tire (as a reference point, not saying that that capability is the desired outcome). I would like a bit more power for emergency stops, it's not quite enough, especially not when pulling my kids trailer with live load.
For reference, this is what I have done so far (and am close to being out of ideas):
The only other thought I have is to start using a 180mm rotor (but that won't work on the front because of fork ratings). I'm trying to avoid a conversion to hydraulic because of cost (Tiagra ST-4720 levers + calipers are EXPENSIVE!)
Thanks,
alias5000
- New, full-length, compressionless housing, high-quality housing caps
- New polished inner cables
- New high quality pads (confirmed braking power improvement), sanded and cleaned the rotors.
- Caliper arms set up with little pretension
Thanks,
alias5000
Quoted: 5779 Post(s)
Liked 2,576 Times
If I'm reading you correctly, you already have more leverage that a non-mixed brake, not less. Leverage and travel are opposite ends of the spectrum. Pulling more cable (greater lever movement) means greater leverage and should mean more stopping power. The only problem is that given hand limit the design of levers, and more travel means less clearance when open, so can be a problem with warped rotors.
It could be that the pads and rotors are not bedded together well. Consider doing a bedding ride with a series of longish braking intervals separated with a cooling rest. (ride up and down a medium grade slope a few cycles)
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 181 Post(s)
Liked 14 Times
Thank you. The pads are bedded in, I did the bedding in rides and had plenty of hard braking since.
What I'm trying to describe is that when open, I have a significant amount of pad spacing, not very little. I have plenty of brake lever movement range available for brake actuation - opposite of running out of lever range.
So, I think it's opposite to what you were describing
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
I am a heavy rider, and for me upgrading TRP Spyres to cable actuated hydraulic Juin Tech R1's made a huge difference. FWIW I run Sora 3503 levers and Jagwire Pro compressionless housing, this setup is similar to yours.
Liked 2,576 Times
OK, so a quick analogy so you know where I'm going. Imagine you're hanging from a rope tied to the hands of a tower clock. At noon and six the hand won't move no matter how you hard you pull the rope. As you approach 3 or 9 you reach peak leverage, with everything in between being less.
So, now (if you can see it) look at the brake's cable actuating arm at the point the pads are engaged. (close lever and tie it so you can focus on the caliper). I suspect that it's now comparable to the clock's hand having over traveled and now nearing 5 O'clock.
If so, the fix is fairly easy. Reposition the brake (shim if needed) so the moving pad is close to the rotor with the cable fully slack, Then adjust the fixed pad to proper minimum clearance, rather than taking up cable with the adjuster. From there it's just some fine tuning. The brake should now work so that the arm is closer to 3 o'clock (90 degrees to cable's line of motion) and you'll get maximum leverage at the point of brake engagement.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Quoted: 181 Post(s)
Liked 14 Times
Also thank you for the Juintech pointer!
Quoted: 1819 Post(s)
Liked 1,693 Times
Perhaps in your case the Spyke mountain bike version might work better. You would only need one if your rear braking is adequate
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times
In addition to large cantilever brakes, we have a rear TRP spyre on our tandem (200 mm rotor on a Rohloff IGH). We tour with camping gear, so overall the bike is heavy (470 lbs w/gear). I was not sure but I suspected the spyre was lacking. On a tandem with 3 brakes we have the luxury of testing brake strength independently. Perhaps not surprising, given the smaller pad area and smaller disc radius vs rim, the breaking power of the spyre was poor relative to a cantilever. I did not wish to use hydraulics on a touring bike, so I decided to try a Paul Klamper brake.The Klamper brake is beefier, without plastic internal components. The lack of plastics is also important if the brake becomes hot. On a 15% slope the Klamper brake was noticeably better than the Spyre in slowing us. My suspicion is that the force your hand puts into the caliper can cause the internals of the Spyre to flex more than the Klamper and so a significant amount of your hand force goes to flexing stuff. This would be an expensive experiment for you, since the Klamper is pricey. However, it is of high quality and can be easily broken apart to clean. Good luck.
Quoted: 181 Post(s)
Liked 14 Times
Quoted: 181 Post(s)
Liked 14 Times
Many good suggestions above and you should pursue those recommendations. If you decide you still need something better the following may be helpful.
It looks like I'm getting about as much as possible out of the spyres now... Pay $CAD200 to get slightly nicer cable hydraulics (Juin tech R1), pay $CAD400 for 4 piston juin tech gt-p (which review very well and appear to certainly be significantly more powerful), or pay $CAD600 to make the full switch to hydraulic.
I wish it was possible to just test ride the two juins against each other before purchase.
Clark W. Griswold
Quoted: 4350 Post(s)
Liked 3,989 Times
You might try a nicer rotor, the new Magura rotors (MDP and MDC) are quite nice and very stiff which helps. I am unsure if they make them in 160 but I feel like I have seen them but I could be wrong.
Quoted: 217 Post(s)
Liked 155 Times
Video where Path Less Pedaled reviews mechanical disc brakes
I think no one mentioned this, but maybe you can try different pads as a last resort?
Thread where I saw people mention Juin Tech which prompted me to upgrade.
Quoted: 2026 Post(s)
Liked 1,096 Times
I think that this is probably your situation. Shimano in its wisdom decided to redesign its mechanical brakes a couple of generations ago. Their newer road brake levers pull more cable for a given amount of brake lever travel thus reducing mechanical advantage. I simply don't know if your brake callipers are designed to account for that reduced mechanical advantage.
Basically those Tiagra levers have given up some leverage and the Spyres were designed to work best with the older cable pull design.
Quoted: 217 Post(s)
Liked 155 Times
Another evidence that TRP brakes are optimized for the new (longer) Shimano pull design is that there exist short pull conversion arms for HY/RD.
Maybe Spyres are just what they are. For me they were lacking stopping power from the hoods.
Likes For csport:
I run Juin Tech R1 (105 R7000 levers) on my drop bar bike and Paul's on my mountain bike. The Paul's are nicer and stop better, but the cost has prevented me from buying more. I haven't ridden Sypre or Juin Tech GT-P. I have ridden BB7 which I think are adequate on a flat bar bike. I didn't like BB7 with a drop bar.
Likes For katsup:
Likes For trailangel:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Likes For tyrion:
Quoted: 181 Post(s)
Liked 14 Times
Quoted: 181 Post(s)
Liked 14 Times
Incorrect.
He said it won't work because of "fork ratings". My theory is (correct me if I'm wrong you mechanical engineers out there) is that the fork doesn't know what the size of the rotor is, all the fork knows is the torque being put through the brake mounts, and that a wired/mechanical 2 piston system on a 180mm rotor probably won't put more torque through the brake mounts than a hydraulic system with a 160mm rotor. If the OP doesn't feel like he's getting enough braking power then he's probably not close to stressing the fork over it's designed specs.
Liked 2,576 Times
Incorrect.
First of all the maximum braking force is determined by rider weight and geometry. Specifically the angle of the line from the contact patch to the center of gravity. Fork designers have to allow for heavier riders who can position themselves lower and farther back.
There has to be plenty of fudge room here because of the unknowns. Moreover, fork makers have to allow for the high forces from impacts like potholes and obstructions. Overall, while disc brakes do impose new, different, and higher stresses on fork blades, difference in rotor size isn't a great factor in the scheme of things. Also, larger rotors are easier on forks than smaller ones, as they act more like rim brakes.
That said, there may also be physical space considerations like blade clearance, or the ability to center a caliper.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 181 Post(s)
Liked 14 Times
You're mostly right.
(As for me, this is a gravel bike in urban commuting duty with a carbon fork. Max braking load is probably pulling a loaded child trailer and a few grocery panniers, doing emergency braking.)
Either way, it looks reeeeally tight on my fork to fit a 180mm rotor.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
Mine is on my Rohloff with a 203 disc, with resin pads. SA swept bar levers set to long pull. Supposedly wrong. LOL.
It will lock solid instantly. Never squealed once in 5,300 miles. I just don't see how it's possible to screwup the setup. The pad gap is not finicky IME. I do zero to clean but a paper towel wipe thru the pads when the wheel is out.
I have SA drum brakes with both long and short pull. Makes ZERO difference. I suppose it does with poor rim calipers.
