Tuebeless vs TPU tubes
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times
Okay guys i was wondering about those two things...
I'm running tubeless on my mtb since 2 years and they are awsome except that the rear require the foam insert (i have an hardtail).
Without the foam insert i ruined the rim , i hit a rock that slashed my tyre and then another rock a few seconds later , ruining the rim...
I'm a bit in fear to swith tubeless on my roadbike since this experience on my mtb.
Are they really worth on a roadbike?
Let's make this tread more complicated:
GP-5000 340 g (700x28) + 50g Seleant = 390x2= 830g (not mentioned the tyre foam insert weight...)
Continental Grand Prix black (inner tube version) 250g (700x28) + 36g TPU inner tube = 286gx2 = 572g
Continental GP black 250g+142 lightweight inner tubes butyl = 784g
Gp black 250g+latex inner tubes = 670g
TPU seems better in almost every data (rolling resistance etc) compared to the classical inner tubes or tubeless setup.
And efficent against punctures but not safe as tuebeless.
In case of a fast tyre deflation, are the TPU/Lattex better protecting the rim?
(ps. on a famous yt channel they claimed that those advanced inner tubes can save near 11w per tyre... sounds almost sci-fi)
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,990 Times
I don't see it worth while on narrower high pressure stuff but I don't get many flats. I think tubeless is fine and certainly inserts are the way to go for tubeless but I don't see it being a huge upgrade for my road stuff probably at the wider mark say 35+ I would more consider it especially on a regular rider but for skinnier road stuff I just don't. Go TPU if you want but standard Butyl tubes have done me well for years and are cheaper and less sad when I pop one which for me luckily is rare.
Likes For veganbikes:
Achtung!
Bikes: 60.1, Marvel
Quoted: 515 Post(s)
Liked 268 Times
All of my wheel sets are tubeless ready so I don't have a reason not to go tubeless other than being old and set in my ways, so I still run tubed. Plenty of people have gone tubeless and haven't looked back, so it's not some mystery of biking that people are learning about for the first time. Given your experience, I understand being hesitant, but how many times are you going to encounter a similar situation to your MTB incident? I can't imagine many. I think the question is do you want to deal with cleaning sealant off your wheels every time you change tires and if you feel confident that the sealant is going to work if you have an issue given the roads you ride.
I don't see how a tube is going to make any difference compared to tubeless when it comes to protecting the rim, only inserts are going to do that. If you hit the rim you hit the rim. My road bike's aluminum front wheel has a nice ding it from a pothole and was tubed. My hardtail mtn bike has a nice ding in both wheels from a hidden rock and it was tubeless. The only difference is the road bike with a tube blew immediately while I kept riding the mtn bike. My road bike is now tubeless and I have a set of inserts for the mtn bike but don't have them installed yet. vittoria makes inserts for road bikes.
Likes For Canker:
Quoted: 414 Post(s)
Liked 676 Times
I guess it depends on how bad your roads are... I was a TPU fan until I started flatting with all the winter debris on the road. Now I'm a tubeless convert and won't go back (never say never, though!).
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
I’ll never go back
Likes For phrantic09:
Quoted: 3949 Post(s)
Liked 7,295 Times
Likes For tomato coupe:
Thread Killer
Quoted: 3137 Post(s)
Liked 1,704 Times
I run both TPU and tubeless, and have been running road tubeless continuously since ‘14, 23mm and 25mm rubber. It’s the best…if the tire/wheel combo match up well and make installation/removal easy.
I don’t run wheel liners, nor do I see a prevailing need, preferring instead to plug or install a tube should the need arise, which it rarely does. Most punctures seal almost immediately and without stopping or need to top up pressure. Rarely, a tire will need to be rotated to place the puncture on the road so the sealant can do its job, and/or pressure needs added.
TPU tubes are very good as well, like 90% of the ride quality of tubeless, and 50% of the flat protection. That is, TPU— well, I’m referring to Schwalbe Aerothan— are quite puncture resistant in the first place, but also tend to resist catastrophic air loss since the material is highly tear resistant. It’s puncture-able, but won’t pop. Therefore, even puncturing on a fast descent most likely won’t result in sudden air loss. Also, Aerothan TPU tubes permanently patch with self-adhesive patches; I use Lezyne.
Of my fleet, I maintain 4 road tubeless bikes (23 and 25c) and one TPU gravel bike with 700x35c rubber. I’d have run the gravel bike tubed, and indeed tried, but the Rene Herse extralight casing tires would not reliably seal, not with the recommended Panaracer Sealsmart sealant, so I got frustrated and abandonded the effort…without regret, because the Herse Bon Jons ride very nearly as nicely with TPU as they did tubeless.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I remember a club ride I was on where I was forced to hit a pothole with both tires because swerving out would have meant death by car. The rider behind me also hit that pothole with both his tires and he was running tubeless. Guess who had two flats, two destroyed tires and had to call Uber? Not I.
Likes For Lombard:
Quoted: 1461 Post(s)
Liked 1,481 Times
I did an entire season last year on 28mm GP 5000 S TR's set up tubeless and didn't have a single flat. I was also on group rides where other riders flatted and I didn't - usually from running over glass or nails, etc rather than hitting potholes. I suspect my tubeless tires sealed up a number of small punctures without me even realizing it.
More to the point of this thread, tubeless isn't really a weight weenie solution. As the OP has discovered, if you're after the lightest setup TPU tubes in a standard clincher will always be lighter than tubeless. I assume a TPU tube in a standard clincher is more prone to punctures, but I'm not sure there's any way to definitively measure this. I would likely run a tubed setup at a slightly higher pressure to reduce the risk of pinch flatting on a pothole.
The benefits for tubeless road for me are puncture protection, and the ability to run tires at slightly lower pressures than I would with tubes which makes my ride more comfortable. I'm willing to live with the extra 100g of weight (or whatever it works out to) and hassle of setting up tubeless in return. I run 28mm at 60psi. If I were running tubes I'd probably go a little higher, like 70psi.
Liked 1,481 Times
GP 5000 S TR 28mm is specified as 280g. BRR measured it at 260g.
https://www.bicyclerollingresistance...-tr-comparison
280g+50g = 330/ea or 660g for the pair, or less if BRR's weights are accurate. Tubeless isn't a weight savings, but it's also not much of a weight penalty.
EDIT: I suppose you need to add in the extra weight for the valve stems on the tubeless setup, since valves are part of the tube weights? My valve stems weigh 15g ea.
Having just got my first road bike, can someone please explain what TPU tubes are?
Are they different (or better) than the butyl tubes we ran in mountain bikes before the tubeless invasion?
Thread Killer
Liked 1,704 Times
TPU is shorthand for thermoplastic polyurethane, and yes, they’re both different and better than butyl in every way, except cost. TPU is lighter, packs smaller, is better rolling, recyclable, more puncture resistant, more cut resistant, and less likey to suddenly deflate than butyl, though they are ~3x the cost of butyl tubes.
Bikes: 2013 Wilier Gran Turismo, 1983 Trek 760, 80's Colnago Super, 90's De Rosa SLX, 2009 Waterford 22 Series Singlespeed, 85 Medici Pro Strada, De Rosa Alumino frameset, Dave Molten Fuso frameset, 70's beater Peugeot PX10, Zizzo Liberte, 2022 Yoeleo R12
Quoted: 122 Post(s)
Liked 199 Times
2 of my friends tried tubeless but switched back to tube……TPU tubes. Here in the SGV area of SoCal there are plenty of potholes and road debris.
Here are a few of the flats we recently got on our group rides where the tires got damage. I don’t think the tubeless tires would have held air for these flats.
I patched this but took my chances without using a boot. Something gashed my GP5000 tire.
My friend rode into a crack on the bike path. He was in a tight group and unfortunately bent his rim and gashed the new GP5000 tire.
Here’s the crack that damaged the rim and tire. He actually double-flatted, got a flat on the front and rear wheels.
This is what the recent rains did to one of the streets where the Montrose peleton of 40-100 riders pass every Saturday morning. I ride with the group and yelled out before we got here there were major potholes ahead.
Something punctured my relatively new GP5000.
Not a bike tire, but this is a screw I picked up on my run flat Continental car tire on the way home from a road trip. I don’t like run flat tires! They are non repairable and need to be replaced! The roads near me are full of debris and tire damaging surfaces.
Sock Puppet
Liked 863 Times
Liked 2,968 Times
Those roads are like most "surfaces" here. I'm waiting to see how much worse the roads will be after the salty winter season is done. Ice pushups are a pretty big (ignored) problem here & it can create some crude speed bumps that'll quickly turn to a dredge hole spanning across a whole lane.
-Oh Hey!
-Oh Hey!
Quoted: 122 Post(s)
Liked 199 Times
That tire is squaring off pretty early if that is sorta new...
Quoted: 122 Post(s)
Liked 199 Times
My order of 20 Ridenow TPU tubes arrived yesterday. It was $142.56 for 20 tubes and 2 patch kits so about $7/tube. It arrived in 8 days with free shipping from a seller on Aliexpress. My friends want to try them so I ordered for them.
3 tubes and a Park GP-2 patch kit (which supposedly works according to a poster in another TPU thread on this forum) weigh the same as the butyl tube I carry in my saddle bag.
Liked 1,481 Times
If you slam into a pothole hard enough to damage your rim, or ride over screws and nails on a road bike with 28mm or narrower tires you're probably going to get a flat tire.
I don't think this is really a tube vs tubeless or TPU vs butyl situation.
Quoted: 6193 Post(s)
Liked 4,808 Times
I have some roads and paved trails that look like that in places. I ride on the smooth parts and avoid the cracks and potholes. You should too.
I don't remember flatting at all last year. I just use butyl in 25mm GP5000's. The tubed version.
TPU, Butyl, Latex, Tubeless.... It's all about what the individual prefers. The things that annoy or appeal one person about them might not be the things that annoy or attract the other.
Liked 1,481 Times
Yes, hitting the pothole or getting caught in the crack at speed would definitely cause flats and/or crashes. I'm not sure the type of tubes/tubeless really matters in this situation.
Quoted: 122 Post(s)
Liked 199 Times
I occasionally stop and take pictures to post in Strava so my followers who ride the same streets have some warning of possible hazards. There was a cyclist in a fast peloton that hit a pothole a few hundred feet from my picture above 5-6 yrs ago and died from his head injury. He was experienced and rode with the fastest of the 3 Montrose groups with 40-100 in each peloton.
Back to the topic, I do have tubeless tires and rims but I haven’t tried them yet. I may not since the TPU tubes weigh 36g and I can carry 2-3 of them, some Park GP-2 patches and a micro pump, CO2 cartridge, and dollar bill tire boots. That should get me home even with multiple flats.
Liked 1,481 Times
Liked 2,968 Times
When I ride in my local area & come across fresh smooth pavement, I get suspicious real quick..... like "will a sinkhole develop right beneath me?"
-Oh Hey!
-Oh Hey!
