Addiction 2021.4
#5151
So it is
Quoted: 11321 Post(s)
Liked 4,634 Times
Yet Velo Vol was ready to throw dirt on my casket because of a couple of eggs. Protein. It's important.
#5152
So it is
Liked 4,634 Times
My view is that sugar, starch - carbs generally - are fuel. Just fuel. If you're burning energy, you need fuel. If not, you don't. Fat is also fuel, but slower burning - though more energetic per gram. Important to remember that your brain only runs on glucose - part of why one feels so stupid when bonking.
#5153
Quoted: 10060 Post(s)
Liked 5,040 Times
First, when you're in Workout Mode, Erg or not, Zwift doesn't change resistance to match 'terrain'. It's either flat, or in Erg mode it adjusts the resistance with your cadence to match the specified power output for that section of the workout. So, you could be on Alpe du Zwift and it would seem flat, in Workout Mode.
SO, if you did the Ramp Test without Erg Mode, you'd just have to keep shifting gears to increase resistance, just like with a dumb trainer, but your trainer would be providing Zwift with your power output.
The other thing is that you can also change how closely the trainer tries to match the terrain. It's under "Settings" on Zwift. You have to be In Game, in a world. Click Menu, then Settings. Default for Trainer Difficulty = 50%, so it will mimic a 3% gradient when you're climbing a 6% gradient in the game. I generally run it at 100%, since I'm trying to mimic riding in the real world, but if I were to try Alpe du Zwift, I'd probably cut it to 50% the first time.
Two things about Trainer Difficulty - First, even set to 0%, so everything seems flat, your speed In Game is STILL determined by power output, gradient, weight, and aero profile, so if at 0% Trainer Difficulty on a 15% gradient, you might be spinning easy, putting out 150W, and feeling like you're on the flat, but you'll probably be going 2 mph.
Second, on descents, Zwift only mimics HALF of the descending gradient. So a 6% descent is really only 3%, at 100% Trainer Difficulty, and at 50% it would only be 1.5%.
Mind officially blown!!!
#5154
Quoted: 20791 Post(s)
Liked 9,436 Times
#5155
Bikes: Shmikes
Quoted: 10103 Post(s)
Liked 5,782 Times
Then, of course, a bunch of them died in WW1.
Likes For MoAlpha:
#5156
Liked 9,436 Times
#5157
Liked 9,436 Times
True, except you can make your own carbs from fat and protein and the brain only requires something like 30% glucose in the energy mix after a few days of adaptation to carbohydrate restriction. Technically, therefore, you can live on very little carbohydrate, like Shackleton's men, who survived in good health for months on a steady diet of seals and birds and then had the energy to make an arduous ocean crossing in an open boat and trek over the snow-covered spine of an island.
Prolly.
Likes For WhyFi:
#5158
VFL For Life
Bikes: Velo Volmobile
Quoted: 28433 Post(s)
Liked 1,831 Times
#5159
Liked 9,436 Times
Likes For WhyFi:
#5160
Habitual User
Quoted: 4831 Post(s)
Liked 7,821 Times
#5161
Liked 9,436 Times
I just did a Zwift workout on the London Loop and just peeked at the leader board. The KOM? I mean, come on. I'm sure that the rider is very strong, but his 2016 ride was 18 minutes and change and his average power for the duration is indicated to be 546w.
#5162
Mostly Harmless
Bikes: Have two wheels
Quoted: 13639 Post(s)
Liked 4,449 Times
#5163
Habitual User
Liked 7,821 Times
I suspect an eBike.
#5164
Liked 9,436 Times
I would think that, in 2016, this was wildly enthusiastic zPower estimate on a dumb trainer. Whatever the case, 18min at 550w just isn't on this side of reality. I mean, if you work backwards from Wiggins' hour record (was that 440w?), you're not getting those kinds of ~20min figures.
#5165
Habitual User
Liked 7,821 Times
#5166
Bikes: Shmikes
Liked 5,782 Times
Likes For MoAlpha:
#5167
Should Be More Popular
Quoted: 22513 Post(s)
Liked 8,841 Times
It's possible. That is from Zwift. And when I ride with my friends on Zwift, I am often dropped and once dropped, I can never get back. On the road, I have no problems keeping up with said friends and have no trouble dropping most (if not all) of them on the longer hills. That said, I am not "training" for anything other than fun rides. I don't want or need a power meter for my goals.
#5168
Bikes: Shmikes
Liked 5,782 Times
#5169
Liked 9,436 Times
Likes For WhyFi:
#5170
Quoted: 18319 Post(s)
Liked 15,286 Times
#5171
Liked 8,841 Times
I crush my friends' souls on almost every significant hill we have. That's good enough for me. They usually catch me on the way down because (a) gravity and (b) I descend with caution.
#5172
Quoted: 9524 Post(s)
Liked 6,267 Times
What's this crushing of souls of which you speak?
#5173
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times
I do remember early on, seeing some people I ride with IRL, on Zwift with just amazing power numbers, knowing there was just no way. And yes, it was dumb trainers and Zwift's interpretation of power.
Likes For mvnsnd:
#5174
Liked 8,841 Times
#5175
So it is
Liked 4,634 Times
