Batteries for a winter night ride is getting out of hand
2 x heated glove batteries
2 x insole heater battery packs (DIY Blackberry phone case + duct tape holder)
2 x light batteries. 6 cell is overkill for my helmet light, but my 4 cell battery died.
2 AAA in the tail light
Phone
Camera
GPS
Phone
Camera
GPS
Likes For gecho:
Quoted: 1073 Post(s)
Liked 999 Times
You're trying too hard? What's the camera for?
I've never had a need for heated gloves or insoles, I wear thicker wool hiking socks which do fine and winter gloves which have never let me down. If I start to get cold I just pedal faster and in an easier gear and if its below 10* I stay in now, used to commute as low as -10* but don't ever see that kind of temp now that I'm downstate.
I now only buy lights with built in rechargeable batteries that are replaceable. 1750 lumen for 4 hours is longer then I care to ride in the dark anyways and with another 1100 lumen strapped to the helmet, vision is fine and I'd do the same for the tail light.
Course with the GPS, phone, and 3 lights are charging at once its the dining room accessory plug that's starting to look like a tentacle monster.
Likes For Russ Roth:
I like to take a few pictures each ride. At night this time of year I'll take pictures of Christmas lights. I tried keeping my phone out to take pictures last week and it conked out after an hour in the cold. I do like that I can grab the camera out of my back pocket and take pictures one handed on the fly even while wearing gloves.
For lights I wanted something with a ridiculously long runtime for brevets. I started with 1000 lumen Dinotte XML-3, then bought a newer one that is 2100 lumen, then sent the first one back for an upgrade to 2500. The newest one should run at about 700 lumens for 13 hours on a 6 cell battery.
Pedaling faster works for heating my core, but doesn't help with my hands / feet. With raynauds I need the heated stuff to keep my fingers / toes from going white and numb.
Likes For gecho:
Liked 999 Times
Sr Member on Sr bikes
What are the general weather condition when and where you do your nighttime riding? And, how long (time-wise) do your rides usually last? Just wondering if you really need the powered hand warmers and insoles, or if you could be by without them. For example…maybe a good shoe cover would provide the extra protection and eliminate the need for the insoles. And, the right gloves/mittens might do the same for the hand warmers.
Dan
Dan
Likes For _ForceD_:
Dan
Dan
For years I've gotten by without heated gloves, but would have intermittent periods of numbness on every ride. Usually worse towards the end of the ride where my gloves start getting damp and don't insulate as well. When I started using bar mitts my hands were better. My hands are so much better with the heat, its worth the extra hassle.
Heated insoles I definitely can't do without and have been using them for a decade. Even right around freezing with winter boots I'm only good for up to an hour without heat. The mechanics of pedaling seem to hinder circulation, as when walking my feet are rarely cold in the winter. I tried adding extra insulation to the outside of boots which didn't help much.
With raynauds your body over reacts to cold exposure and cuts off circulation to the fingers / toes. Without circulation they'll get cold fast regardless of how good the insulation is. I think there is a feedback loop to it, when they start getting cold more circulation is reduced, making them colder, reducing more circulation. Active heat seems to prevent that progression.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
Maybe you could get a single battery that mounts on the water bottle cage that could feed those devices. But really…if you’re going to be in extremes like that…I don’t know if there’s much else you can do beyond the way you’ve been operating.
Something like this: https://www.batteryspace.com/custom-...0aAlAAEALw_wcB
Dan
Likes For _ForceD_:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4269 Post(s)
Liked 2,943 Times
Dynamos barely generate enough power for adequate light let alone powering anything else. Assuming a generous efficiency of 150 lumens per watt, a 1500 lumen headlight needs 10 watts while a dynamo produces 3 watts. My heated gloves alone are 18 watts combined (though not drawn continuously), if I run them off a lower voltage USB battery I can run them continuously at 12.5 watts without them getting too hot.
I'm starting to like the idea of an electric fat bike and running everything off its battery. The fat bike trails are about 12 km from home and I almost always ride to and from them. Since I end up averaging about 13 km/h, I could use some help to up my speed on the streets. Last night I did 38 km and it took nearly 3 hours. I'm also jealous of the kinds of headlights you can get for ebikes, B&M has a 300 lux model with high beam, and a new one that self levels while leaning and shifts to the side when turning.
Liked 2,560 Times
100 lux headlights are pretty impressive, though, and can be powered by an ordinary 3 watt hub. If that's not enough for you, you must be riding a lot faster than me at night. Chapeau.
RUSA #7498
Originally Posted by noglider
Quoted: 5220 Post(s)
Liked 3,564 Times
Liked 3,564 Times
it's best to charge them after a ride, rather than before a ride, right?
if for no other reason than, if they aren't charged, you can't ride, until they are charged
I usually charge them well before the next ride. If the packs are really cold I'll let them warm up first.
Likes For gecho:
I always forget to charge accessories for when I need them if I don't go ahead and do it right away. I hate starting a long ride with my bike computer already beeping at me!
Likes For RandyK1977:
Likes For cjenrick:
Liked 3,564 Times
had a working routine & a place for all my stuff. then the holidays came & some limited company & I had to move all my stuff out of our living / dining areas. getting ready for a ride after that meant more time hunting for stuff, etc. still need to find my bike computer, ugh. but I got out!
No kidding. I live in MN and I love to ride my bike. I like riding year round, but there are so many extra little pieces and clothing that it just wears me out by April. A lot of "gotta wanna" is required, not so much to go outside, but to spend all the time getting ready.
Likes For JohnJ80:
Bikes: Specilized Roubaix, 71 Raleigh Professional, 74 Raliegh Intl, 74 Peugot PX-10, 82 Puegoet PSN, Olmo Competition , Schwinn High Sierra & Others
Quoted: 42 Post(s)
Liked 59 Times
Which heated insoles are you using? I am looking to buy a pair and see lots of options.
You can buy similar heating pads fairly cheaply. The tricky part would be finding battery packs to attach to footwear. A battery exposed to the cold might need to be lithium polymer, some lithium ion batteries don't do well in the cold.
Any heated insole that is trim to fit, won't have any heating at the edge of the insole so that may limit their effectiveness at keeping toes warm.
Liked 3,564 Times
FWIW, I don't recommend buying from https://www.lightmalls.com/
by time the extra battery, which I ordered weeks ago, arrives, I won't need it!
EDIT it arrived the same day I wrote that. did a burn test w/ one headlight & it lasted a cpl hrs, then I charged it. 3 heads, 4 batteries, ready to blaze a night trail. if I can muster the gumption
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
What's the stranded rope like resistance wire you are using and where can one get some?
Lithium polymer is a type of lithium ion, and they don't like cold either. Was trying to fly some tiny RC planes and drones in the snow one winter, and even keeping the batteries in a shirt pocket they wouldn't run long one taken out and installed - the plane would get up about 30 feet and then cut out and glide in, drone would simply fall out of the sky. Lots of phone batteries die on people in the cold, too too especially when they're getting up in their service life.
The rope is made up of 12 smaller ropes, for my heat pads I used 2 parallel circuits with 4 of the smaller ropes instead of the full rope. The full rope has a resistance of about 21 ohms per meter, the individual strands about 228 ohms. The full rope uses more power than I need in a particular application. Its a bit tricky tuning the heat output, in theory the rope and strands will achieve the same temperature at a given length. But with less strands you can pull heat out fast enough it never reaches that temperature. I've started calculating the estimated wattage to give me a rough idea of how warm a particular design might get at a particular voltage as I have 5V, 7.4V and 9V batteries that I can use to power them.
I recently started using 9V with a USB C PD power banks and a USB PD decoy. More consistent heat output than 7.4V batteries which start around 8.4V and drop over time causing the heat output to drop. USB delivers a constant voltage.
