For when your fender mounts are too short...
Quoted: 981 Post(s)
Liked 1,844 Times
Today I was putting an older pair of Tanaka fenders on my Mercian Campionissimo when I realized that the rear mount was too short to reach the frame eyelets... Frustrated, I almost gave up until I noticed a pair of unused toe clip backing plates among my spares. Et voilą!
-Gregory
-Gregory
Likes For Kilroy1988:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
Great McGiver!
Reading the thread title, I thought for sure this would be another 650b conversion thread.
I.C.
I.C.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I like it! And since @Insidious C. was looking for 650B content, here's a DIY drop bolt held together by the inserts from two Crank Brothers cleats with old bearings from rebuilt Crank Brothers pedals used as spacers on the lower part. And people say Crank Brothers stuff is no good!
My Bikes
My Bikes
Likes For Andy_K:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Quoted: 469 Post(s)
Liked 2,443 Times
I'm all for using what's on hand to get the job done. On one fender installation, I didn't have any of the P clamps. Used to dabble in plumbing, so I cut up some pieces of copper plumbers strap.
Most recent fender job left me needing spacers. I used what I had, some small diameter copper tube.
Likes For Roger M:
ambulatory senior
Liked 3,661 Times
Likes For 52telecaster:
Quoted: 981 Post(s)
Liked 1,844 Times
I'd like to mention that my fix is obviously temporary. I already purchased a replacement strut that should have plenty of reach. I believe I cut this one down after fitting it to another bike years ago... Won't do that again!
-Gregory
-Gregory
Bikes: Yes
Liked 3,868 Times
I didn't use it long like that, switched back to 700c tires, but while I had this it seemed to do OK.
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 634 Post(s)
Liked 444 Times
-Gregory
-Gregory
Bikes: Yes
Liked 3,868 Times
This one I used for years with no problems.
My Bikes
My Bikes
Quoted: 4802 Post(s)
Liked 3,923 Times
Suggestion - find some thicker quality steel plate and cut to suit. The fender backup is both thin and only about a 1/4" or less at the midpoint. So, not stiff. Stiffness means less fender oscillation on rough roads. Having the stay come to an eye which is securely anchored to the frame with a bolt is a big plus.
So, congratulations. But keep your eye out for that perfect steel sheet.
Ben, who's been riding and modifying fenders for 50 years.
And edit: Just remembered, - I saw stays on the SKS website the other day as separate items. So, a shop, should be able to get them for you. (I've asked a local shop to inquire with SKS about making yellow fenders. SKS got back to them. No, they couldn't with their current plastics. Shucks. But kudos for listening and replying.)
Second edit! Andy K gets it! Stiff!
The rear fender of my avatar (that didn't go for the ride where the photo was taken) is an SKS Chromoplast cut in two ahead of the brake bridge. The rear portion was then stretched out by cutting the fender flanges to the "corner" at the top. Fender was then spread and fiberglass laid inside to make that stretched shape both permanent and stiff. Last. I made a River Cities like bracket for the rear section but out of heavy steel flatbar, not the light and sexy SS RC uses. End result looks a little ungainly but no oscillation at all, never rubs and I can use the entire 2" of dropout track with the biggest tires the bikes was designed to fit.
Quoted: 981 Post(s)
Liked 1,844 Times
And edit: Just remembered, - I saw stays on the SKS website the other day as separate items. So, a shop, should be able to get them for you. (I've asked a local shop to inquire with SKS about making yellow fenders. SKS got back to them. No, they couldn't with their current plastics. Shucks. But kudos for listening and replying.).
-Gregory
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Old Schwinn fenders (sometimes) had a Y-shaped piece of stamped sheet steel connecting the two fender braces to the one axle (this is before they invented those eyelet thingies). It gave you a lot of control over the fender line. More control points alas does not always translate to more control.
www.rhmsaddles.com.
www.rhmsaddles.com.
