No gear markings on SRAM Eagle 12 speed shifter?
Guys thanks for the feedback. I did not want to start a philosophical discussion here. All valid points brought up. I am going to use a simple approach and just use some paint or markers on my shifter. I really only want a visual gear indicator to make sure I am getting down to a good gear to start before I have to come to a stop. And there are plenty of them on my ride to work.
Likes For Harhir:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
I love the people who keep saying you should be able to feel what gear you're in. Have they never encountered a headwind?
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,886 Times
Likes For genejockey:
Liked 11,886 Times
I don't have a preferred gear for any particular situation. As I'm slowing down to a stop, I change gears so I'm in a gear that feels like what I'll need to start. Back when I was trying to get my kids into cycling, they had Grip Shift with numbers, and they'd ask me what number they should be in, which was impossible to answer, of course, since I wasn't riding their bike.
Quoted: 4803 Post(s)
Liked 3,925 Times
A thought - maybe we need gear indicators that work like CX bar-top levers when not in use. Say at the inboard end of our handlebar tape. Have a band that clamps round the HB with two cable housing stops. In between, an indicator clamped on to the cable corresponding to the gear. Done right, it could be small, barely noticeable, near friction free, simple and reliable.
I won't invent this. I'm still riding those easy to see DTs but those who feel the need should don their thinking caps.
Edit: I too was one who thought (and almost commented) "why no just look down?". Glad I didn't. (Now, a mirror could be set up in the right place to make that look easier, but I wouldn't. But I might scrounge the closet for that magic cap.)
Liked 3,925 Times
Likes For 79pmooney:
Tragically Ignorant
Liked 9,098 Times
I propose Lycrasplaining as the term for "real cyclists don't..." type of correction.
How about Schwinnsplaining for the reverse snob "it's all market hype for suckers" kind of correction?
Likes For livedarklions:
Tragically Ignorant
Liked 9,098 Times
Enjoy! Now's the part of the thread where we goof on the people who went after you.
Quoted: 18409 Post(s)
Liked 15,530 Times
Lower the blast shield as use the force.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,646 Times
It is not just 1-2 cogs. Going from start to 15 mph I guess I am going through 5-6 or more gears. Same the other way. Since I ride a recumbent it makes a big difference if I am starting on 2nd or 4th cog since I cannot use my body weight by standing up. Therefore it is important for me to know if I need to downshift 8, 5 or just 2 gears. Plus being on a recumbent I am constantly shifting up and down to get a similar spinning frequency in every gear. So I really don't know know what gear I am currently in without looking at my shifter. I may get used to it but for now I will mark my shifter. At least for the lower gears. It is my first bike in over 40 years which does not have gear shifters with markings on it.
This is obviously the sort of issue that demands managers be talked to.
Likes For Paul Barnard:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
it is most likely that SRAM believes that real cyclists don't need them and they want to differentiate their high end products from those SRAM grip shift type products sold on low end bikes.
That is most likely why SRAM leaves off a seemingly innocuous feature that few cyclists will use. It is almost SRAM's way of saying, "We know you are going to take abuse by just using these, so we are going to try to make them look more "pro" and keep them blank.
Wow. Out of thin air, you've somehow identified Sram's "most likely" reasoning, and presented it as though they actually thought it and said it. You have amazing powers of conjecture.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
They chose not to include something that some people might want that would pose zero downside and (for all practical purposes) no extra expense.
Really, the only explanation that makes a lick of sense to me is that they thought the cool kids would make fun of them.
Likes For Kapusta:
Quoted: 2975 Post(s)
Liked 1,180 Times
When I'm on a MTB trail there is no time to check the chosen gear (risk of crashing) and it is mostly irrelevant to have the gear displayed. There is only one chainring so just shift the gears for the given riding conditions...by feeling
When I'm on a road bike there is no time to check gears either cruising along at 18-22 mph. Again...it's easy to feel if you are in the right gear.
Liked 1,180 Times
Numerous times. 20 mph headwinds on my 51 mile ride this past Tuesday. Guess what...It felt hard to pedal...So I switched to an easier gear so I wouldn't blow up my legs and lungs for the remaining 25 miles home into the wind.. Pretty darn simple.
Quoted: 1943 Post(s)
Liked 2,164 Times
But then there is Di2. If someone is so inclined to go to Shimano’s electronic shifting system, you can add a digital display that prominently shows the gear.
I know Di2 is UCI compliant, although the digital display may not be, but it is somewhat ironic.
But there is some sense to it. The mechanical gear indicators are a bit funky, especially the inline ones. But with electronics it is not an issue; even if it is merely an unneeded convenience for some.
Maybe someday we can remove our feelings from the sport and just ride.
John
John
Liked 1,180 Times
Apparently this was covered here 7 years ago. The overall consensus back then (like now) is by feel.
https://www.bikeforums.net/hybrid-bi...-shifters.html
NOT a safe thing to do.
By the time you put your eyes back to the road, your front wheel is about to roll into a giant pothole or there's big truck stopped right in front of you and it's too late to evade.
You don't really need to know what gear you're on if your drivetrain is shifting through the whole range including cross-chaining without any problems. Especially on 1x. Shift as you need. Downshift at least two gears when coming to a stop but that will depend on the gapping of your cogs and the size of your cassette. On a tight range cassette, you'll have to downshift a lot more.
Advanced Slacker
Liked 2,537 Times
Likes For Kapusta:
Advanced Slacker
Liked 2,537 Times
Liked 2,164 Times
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Tragically Ignorant
Liked 9,098 Times
Here's where you all go off the beam. I don't use them, but I don't think I or anyone else is qualified to tell someone who finds them useful that they shouldn't. Why should any individual rider care about the consensus of people who aren't on the bike with him?
