Gravel to Road Bike Conversion
OM boy
Bikes: a bunch
Quoted: 510 Post(s)
Liked 639 Times
The LA region has quite a few 'River Trails', all going from inland/hills down to the ocean (also reverse ride). Most are MUPS, so 12-ish ft wide, and generally bypass 'hills' (follow 'river' down), so long stretches mostly straight/gentle curve, until you get to road under-crossings - those can be hairy and usually a bunch of slow speed 90 deg kinks. Many ride the trails down then use some form of transit to go back up. Some ride both ways...
I've done a few rides with friends from LA - fun, but best not to do high pace, especially on weekends - can;t imagine what they were like during and after COVID...
Don't remember if we did the Santa Ana Trail, think so... on these rides I was mostly on 'auto-pilot' and just followed the lead... safely... LOL!
https://www.traillink.com/trail/santa-ana-river-trail/
24 mph on some sections was doable, but not advised, in my mind. These rides were mostly 'fun' rides, fast guys just wanting to 'cruise' without motor vehicles around and lights/other traffic.
There were some scary encounters along the way...
Just can't imagine the nightmare now, with the proliferation of e-bikes of every kind... scary... I now avoid these ride invites... happy to stay in my neck of the woods.
Ride On
Yuri
Ride On
Yuri
Quoted: 3234 Post(s)
Liked 2,079 Times
Thats Pro Cycling paceline speed. I think they avg. 25 or so for 6 hrs. per day, for 3 weeks on a major tour. I'd bet there are Cat 1-2 teams in the states (and Europe) that train near that. Not something the OP wants to get involved in, not that they'd let him.
Quoted: 1109 Post(s)
Liked 1,200 Times
If you find yourself out of gear on long downhills and spinning out in a 46/11, then only option is to swap to a compact road crank that will get you a 50 big ring or a 39/53 crank. But that maybe yields 4 mph in the 53/11, so your call.
You can play with different cassette and crank options and find out speed here. Mike Sherman's Bicycle Gear Calculator (mike-sherman.github.io)
You can also get a 2nd wheelset and put the road tires, maybe 28mm's on that with a road cassette like an 11-28. Then keep the gravel tires and hills gears on the original wheel set. On the carbon Topstone you would have to have a shop re-dish the rear wheel but that easy and cheap. A 2nd wheel set is what a lot of users of this bike do, it's how I have my aluminum Topstone setup, works great.
And FWIW, my experience is that my alu Topstone at 22 lbs with the road wheels on it, is about 5 lbs heavier and maybe 1/2 mph slower than my 17 lbs carbon road bike. I notice it on group rides.
thank you for your tips...
we were on Santa Ana river trail to Huntington Beach and I was averaging 16mph and one of the member averaged 24mph. i wasn't wearing tight cycling clothes and I remember the members posture was much more aerodynamic than I, lowered upper body hunched closer to the stem. I wasn't thinking about the aerodynamic but common sense hindsight...
I'll try the new tires, clothing, and posture...
thanks again for such a detailed explanation.
This is true, but I don't think the geometry is affecting his concern about not keeping pace on a typical recreational road ride. The handling isn't the issue. I don't believe anything in a gravel bike - assuming road tires, etc. - keeps a person from fitting in on a group ride. A gravel bike fitted out as a road bike with good quality road tires and the high and low gearing like his currently has should be limited only by his fitness and ability to ride in a group.
Quoted: 1248 Post(s)
Liked 1,323 Times
Not sure if less trail will help the op maintain an average pace of 24 mph or affect their average speed in any way. Very few if any mainstream gravel bikes have trail north of 70mm.
Quoted: 446 Post(s)
Liked 1,043 Times
Those are some fast riders. Your bike seems like it can handle a road bike conversion with an Ultegra groupset. I'd switch to some skinnier road slicks, bigger crankset and get a smaller cassette like an 11-28t. After that, I'd focus on training more. I can hang with above average roadies on my gravel bike with a GRX 46:30t setup, but you'll definitely need a bigger crankset on serious fast group rides. Even on my road bike with a 50:34t front crankset, I struggle with serious riders going at a fast pace line at around 26-30mph on the flats. I can only drop them once we hit the hills!
Thread Killer
Quoted: 3133 Post(s)
Liked 1,700 Times
Wow, I’m surprised folks think a 46/11 is sufficient for fast club rides; the gear range is not nearly tall enough, in my opinion.
Quoted: 3241 Post(s)
Liked 2,512 Times
Sunshine
Quoted: 10954 Post(s)
Liked 7,483 Times
But to apply it to the OP, based on what he has said, he is not able to push 46/11 at 80rpm and ride at 27mph so that is plenty of gearing for now.
Thread Killer
Liked 1,700 Times
46/11 at a very reasonable 80rpm is 26.7mph on 30mm tires. That may not work for everyone, but it is more than a lot of people can handle. As for it being enough for fast club rides, it may not be on downhill. On flat or uphill though?...very few fast club rides I have seen are moving faster than 27mph. I do see that speed on flat road for sure. Again though, this is at just 80rpm.
Sunshine
Liked 7,483 Times
All the more reason to have a better range at the tall end, so they can fine tune their output. Two shifts up off the 46/11 and you’ve only got 93gi to work with, and I can tell you from how I ride, that is not enough to stay on a fast bunch, and for the OP who doesn’t like to pedal above 80rpm anyway, they’re going to have trouble finding the torque load they prefer and get the speed they need. 46t is way too small for fast road work.
As for the OP not wanting to pedal above 80rpm, then why would 70 and a larger gear inch be realistic? Setting that aside, 50/11 at 70rpm is 25.44mph. Reminder, 46/11 at 80rpm is 26.71mph. So if he gets a larger chainring and pedals slower, he will ride slower.
In the end, the OP just needs to ride more and build up ability(stamina, speed, etc).
