Go Back  Bike Forums > Bike Forums > Advocacy & Safety
Dabrim and helmet effectiveness
Advocacy & Safety Cyclists should expect and demand safe accommodation on every public road, just as do all other users. Discuss your bicycle advocacy and safety concerns here.
Old 06-28-22, 01:29 PM
greatbasin
Quoted: 198 Post(s)
Liked 84 Times in 65 Posts
I'm interested the "Da Brim" for sun protection, but since it is mostly out of stock at the moment, I'm left to deliberate my decision to buy one. What I wonder is to what degree the brim affects the helmet's protection. It seems like the brim would be crushable and not likely to severely deflect or rotate the helmet provided the strap was adjusted properly. This is only speculation though, and without any evidence.
According to https://helmets.org/visors.htm , there appears to be some concerns with hard plastic visors causing lacerations. This would not be a concern with a soft brim. The same site https://helmets.org/helmet22.htm also published, "We recommend looking for a helmet that fits you well, pleases you as wearing apparel and has a rounded, smooth exterior with no major snag points."
The "rounded" shape is something that is proven. Arai, a premier motorsports helmet producer, has since the 1970's maintained a loyalty to what they call their R75 shape -- a round shape with a minimum of 75mm radius curves. https://parts.araiamericas.com/the-arai-difference/r75 I am a loyal Arai user for over 25 years. Some independent tests have shown the R75 shape to be just as effective as MIPS at managing rotational energy. This is an objective fact that can be measured. I do appreciate that what this means for injury is much more ambiguous. It seems intuitive to me that a round helmet will direct forces tangentially whereas a helmet with sharp radii, protrusions, or square edges has the potential to snag, increase neck torsion, and especially in the case of a lower-coverage bicycle helmet, deflect the helmet out of the position that's necessary for maximum protection.
I am currently looking to replace my helmet, a Giro MIPS model, simply because it is worn out, and to possibly add Da Brim so I don't have to goop-up my face, head and neck so much.
greatbasin is offline
Old 06-29-22, 06:51 AM
noimagination
Quoted: 364 Post(s)
Liked 418 Times in 247 Posts
If da brim is what you really want, order it on back-order. If you can't wait, to tide you over until it's delivered: buy an appropriate hat, cut the crown out (you can even hem the cut-out area to prevent fraying/make it look better), sew some velcro to the inside, glue some velcro to your helmet. Voila!
It might look like hell, depending on your sewing/crafting skills, but lets be honest - da brim will never be "cool" (in the esthetic sense) anyway, so who cares?
noimagination is offline
Old 06-29-22, 08:18 AM
greatbasin
Quoted: 198 Post(s)
I've considered what you're proposing. Have you done this? I am supposing I would need a hat that is exceptionally large for the crown to fit over the helmet. I understand I would cut the top of the crown off, but the inner circumference of the brim would need to fit around the perimeter of the helmet. I also considered if I could make my own brim perhaps out of canvas.
Old 06-29-22, 12:55 PM
njkayaker
Quoted: 4242 Post(s)
Liked 1,342 Times in 931 Posts
It seems very unlikely that a soft brim would do anything to make the helmet less effective. There's some chance that it could even help a tiny bit.
Nothing is 100% risk free. This seems close to 0.
If you see it having a clear benefit to you, I would find something else that is more of a risk to worry about.
njkayaker is offline
Old 06-30-22, 05:41 AM
noimagination
Quoted: 364 Post(s)
Nope. I do see the utility of a 'da brim'-type hat, though, for example if you're cycling in the desert or are especially sensitive to the sun. If you just want a visor, though, IMO worries about being cut by a plastic visor in case of a crash are overblown (I don't use a visor, personally). Yes, it could happen. Is it likely? Not in my opinion. In 40-ish years of cycling I've crashed and landed on the front of my helmet once, and my eyebrow got cut by the rim of my glasses, much worse than I would have gotten cut by a visor. If it worries you, though, then just wear a cycling cap under your helmet if all you need is a visor.
QUOTE=greatbasin;22557796]I am supposing I would need a hat that is exceptionally large for the crown to fit over the helmet. I understand I would cut the top of the crown off, but the inner circumference of the brim would need to fit around the perimeter of the helmet. I also considered if I could make my own brim perhaps out of canvas.[/QUOTE]
Yes, you'd probably need an exceptionally large hat size. Not sure if my suggestion is really practical, it's just an option to consider.
Old 06-30-22, 10:47 AM
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
Or buy one of those shading brims that don't have a top on them - just an adjustable band. Then there's nothing to cut off; you just shorten the band and add the velcro type pieces to attach it to the helmet.
Cheers
Miele Man is offline
Old 06-30-22, 01:47 PM
I-Like-To-Bike
Been Around Awhile
I-Like-To-Bike's Avatar
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,527 Times in 1,040 Posts
Originally Posted by noimagination
...then just wear a cycling cap under your helmet if all you need is a visor.
An inexpensive baseball-type cap (without an extra cost logo) would have an even more effective sun blocking visor.
I-Like-To-Bike is offline
Old 07-01-22, 06:52 AM
dmwill
Bikes: 1989 Dahon Stainless Steel Classic, 1993 Burley Samba Mixte tandem, 2002 Gary Fisher Hoo Koo E Koo, 2003 Co-Motion Speedster tandem, 2021 Trek Verve 3, 2021 Priority Current
Quoted: 13 Post(s)
Liked 31 Times in 20 Posts
We have da brim and it seems soft enough that it would not deflect your head in any way in a crash, and it's not so tightly attached to the helmet that it will give grip to the ground and yank your helmet around that way. The biggest issue we have had with it is getting it to sit flat. The curve of the edge wants to undulate - front right a little higher than front left, adjust that and it goes the other way. Definitely suggest buying at LBS and having someone who has done it before attach it for the first time.
dmwill is offline
Old 07-01-22, 08:07 AM
Quoted: 18391 Post(s)
Liked 15,465 Times in 7,306 Posts
At the cost of ventilation. Da Brim does not cover your scalp or helmet vent holes.
Old 07-01-22, 01:36 PM
mr_bill
Quoted: 2112 Post(s)
Liked 663 Times in 443 Posts
The squatchee of a baseball hat can be a real pain if you don't have a centered vent hole too.
And the bills of baseball hats can be too large.
And unless you get a mesh baseball hat, they are often hot.
And few baseball hats have neck coverage, which some Da Brims do. Of course, you can buy an inexpensive neck cover to add onto your inexpensive baseball hat.
Or you could just get a Da Brim.
Finally, last I looked, there are inexpensive cycling caps (without the *gasp* extra cost logo) that are just as inexpensive as inexpensive baseball hats.
But *some* people are more likely to sneer at someone wearing a cycling cap. (Or, I would guess, sneer at someone wearing a Da Brim.)
My advice? Wear what ya wanna. I wear a headsweats without a bill, but there are headsweats with bills. And don't overthink it.
-mr. bill
mr_bill is offline
Old 07-02-22, 11:15 PM
Leisesturm
Quoted: 2488 Post(s)
Liked 735 Times in 520 Posts
I wear a (branded) Golf visor under a Giro MIPS helmet because I do not need sun protection I need eye protection, from glare. A Golf visor keeps sun (and rain) out of your eyes, but all of your neck and maybe chin will be vulnerable to sunburn. My wife has a Da Brim for her helmet and there really is no substitute. There is no hat on the market with a body large enough to fit a helmet through! There are few hats with brims wide enough to be worth destroying to make ersatz Da Brims out of. It really is a unique product with no equal out there at the moment.
Leisesturm is offline
