Slippery saddles are better than "sticky" ones.
Quoted: 144 Post(s)
Liked 119 Times
After riding a couple of bikes with saddles that allow me to squirm around a bit rather than locking me into one position due to the texture of their material, I've decided that slippery is better for me.
Is this a thing or are people generally advised to be locked into one position? I've seen at least one YouTube bike-fitter who says locked-in is best. Not for me!
Quoted: 425 Post(s)
Liked 454 Times
In the 90s "anti-slip" saddle surfaces may have been a thing. I've had saddles that had anti-slip surfaces as well as saddles that were more slippery. I personally like a more secure feeling on the saddle and don't really like moving around too much on the saddle, assuming that my fit is dialed in. I think some modern saddles have longer noses that specifically allows the rider to sit more forward for situational use cases (get more aero, for example).
Quoted: 365 Post(s)
Liked 418 Times
Ideally, you should not need saddle "stickiness" to maintain a proper position on the saddle, and having a more slippery saddle should allow you to more easily shift position as circumstances demand. Me, being a duffer who gets a few thousand miles a year, and who gets tired and lets his form go to heck sometimes, I prefer a medium saddle, a little smooth and a little sticky. Many saddles start out pretty slippery but then moderate to medium after a few hundred miles.
Likes For noimagination:
Quoted: 18397 Post(s)
Liked 15,493 Times
Yes. Personal preference is a thing, and not just in cycling.
Likes For indyfabz:
Quoted: 207 Post(s)
Liked 108 Times
Nice to know I am not the only one! I have to have the slip, and more and more saddles these days seem to be built to be the opposite. I've even tried additives to put a slide on a seat but it does not last past one short ride.
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
I can’t even remember the last time I sat on a saddle that was “grippy” (vs “slippery”) on any bike I’ve borrowed, rented or demoed.
Likes For Kapusta:
climber has-been
Quoted: 3414 Post(s)
Liked 3,542 Times
Locking into one position on the saddle is a sure-fire recipe for saddle sores.
Ride, Rest, Repeat. ROUVY: terrymorse
Likes For terrymorse:
Advanced Slacker
Liked 2,534 Times
A couple/few years ago someone came out with a saddle with a ridge poking up in the center that wedged itself in your ass crack. That’s one way to lock you in place.
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,856 Times
I bought some bibs a few years back that were great in all respects except one - the fabric was slippery. I kept sliding forward, and had to consciously push myself back on the saddle every couple minutes. I tried roughing up the saddle surface with sandpaper. I tried these shorts on multiple different bikes with at least 4 different models of saddle, but no matter what I did, I kept sliding forward, which didn't happen with any other bibs. I ended up having to chuck them. So, put me on Team Non-Slip. It's not that I want to be locked in, but I want to stay pretty much where I choose to be.
Habitual User
Quoted: 4926 Post(s)
Liked 8,058 Times
I don't want to be locked down, but I also don't want to be sliding around. I want to move how and when I want to move, and stay put when I want to stay put. Fortunately, that's the case for all the saddles on my various bikes (typical lightweight racing saddles)
A properly adjusted saddle will usually keep you more or less in position, and even slippery saddles start to grip a little more when they get warmed up. Slippery or not, it doesn’t matter so much to me, I get out of the saddle regularly for circulation, and changing positions is easy enough. For the last decade I’ve been using Brooks saddles, which form to the shape of your backside, and will keep you in position.
Likes For 50PlusCycling:
Quoted: 1062 Post(s)
Liked 665 Times
Quoted: 892 Post(s)
Liked 2,052 Times
Last year I went through a series of test saddles from an LBS, and one of them had a surface that prevented movement. I thought it was awful; I couldn't easily make small adjustments that normally happen without thought. Moving hand position, climbing or descending, or just changing level of effort might lead to a slight shift in position. Not to mention just wanting to move a bit for comfort.
I tend to think if you need a sticky saddle to stay in place, your bike fit is probably off. Bike fit has enough variables it's indistinguishable from magic, IMHO.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3869 Post(s)
Liked 6,458 Times
Likes For KerryIrons:
Butt Butter will work it's way through shorts and make any saddle slippery.
I always have a big oil slick on my seat after every ride. No, it is not from a bad diet.
Wearing through a Brooks saddle into the sticky leather underneath will take your skin off quicker than a wood rasp.
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
One reason I didn't like the rubber Brooks Cambium saddle I had for a bit.
Quoted: 4791 Post(s)
Liked 3,918 Times
I liked the suede covered saddles of the early '80s. Nice compromise. Of course, that suede does pull a fast one (slow one?) and becomes ordinary leather.
Advocatus Diaboli
Liked 1,531 Times
señor miembro
Liked 6,458 Times
Advocatus Diaboli
Liked 1,531 Times
señor miembro
Liked 6,458 Times
I prefer a saddle that has some slip but not to the point where I'm sliding around. I like to be able to re-position with little effort. I also don't like a saddle that Velcro's my bum in one place.
I don't wear Spandex any more (always slide around on my Brooks) and instead wear Endura Hummvee shorts that allow a bit of slip on my Brooks saddles. I am breaking in a brand new Brooks Swallow saddle and even with those shorts I am sliding around a lot. That will stop once it gets sweated into a bit more though.
I remember back in the 1990's I think it was when non-slip saddles were very popular. I never liked mine because it chafed my bum. It was also hard to re-position on climbs, downhills, corners, etc. My shorts seemed to "stick" to the saddle. No Bueno.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2567 Post(s)
Liked 5,599 Times
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
