Proper order to setup new bike fit with known dimensions?
Quoted: 192 Post(s)
Liked 11 Times
I am trying to map current fit settings on one bike to another. The question is, what’s the correct order, if any?
I assume I want to start with getting the saddle height relative to pedals along with saddle angle and setback from pedals.
Then get bar height relative to ground.
then tip of saddle to bar for reach.
this order seems to make sense. Am I missing anything major?
what’s the best way to get the orientation of handle bars consistent?
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
This is not rocket science just get the bike out and set it up. How complicated can it be? The seat sits up off ground and pedals, the seat is suppose to be level. The handlebars you can measure but really just get it in the ballpark and tweak it after you ride a bit. No bikes of different models have exact geometry.
Likes For deacon mark:
Quoted: 479 Post(s)
Liked 277 Times
1. Cleats
2. Saddle - Height and fore/aft relative to pedals (spindle) not bar
3. Bar - height (spacers) and fore/aft relative to saddle/reach/hip rotation/flexibility... (obviously, fore/aft means swapping stems) and rotation
Full disclosure: I've doing fits for a long time... mostly for this one guy
(I'm not a professional)
Likes For Dean V:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Put differently, the position of the cleats is what really determines where your body will be relative to the BB (once you do all the adjustments that work with it).
Otto
Likes For ofajen:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Other unspoken assumptions:
1) crank length
2) handlebar shape - specifically reach, drop and width
So, the sequence is foot-to-pedal, pedal-to-saddle, crank spindle-to-bar (clamp), and then shifter/lever placement - bar pitch.
Iterations go from there on saddle pitch and stem variation, as well as bar pitch.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Then get bar height relative toground saddle (or bottom bracket).
Orientation of the bar and shifters? I take a picture from the side as a guide, but ultimately I just keep tweaking it til it feels right. This sometimes ends up meaning I need to add or remove a spacer under the stem to compensate for the change in height.
In any event, this has gotten me REALLY close on the last two new road/gravel frames I set up for myself.
I am assuming same length cranks, here.
Quoted: 6193 Post(s)
Liked 4,808 Times
Saddle height over the pedals reigns supreme. Get that right if nothing else. If the head tube angle and seat tube angle are different enough, it's going to feel different anyhow. You may never make it feel the same as the other bike. And that doesn't make the bike wrong for you. Might be that one is better for you on certain types of rides and the other is better for other certain types of rides.
Likes For Iride01:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1944 Post(s)
Liked 1,468 Times
Also, when I think of the "bar" position (reach and hieght), I am thinking of the tops of the hoods. guess a really different drop style could call far a slight change, but in the end I spend a lot more time on the hoods and that is what I care most about.
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,897 Times
I got a great bike fit about 25 years ago and I try to replicate that with each new bike. Some bikes can't quite reach it, but mostly I'm within half a cm or so. I take the model bike, and I set it up on a level floor with the rear wheel against a wall or door. Then I measure from the door and the wall to the center of the bottom bracket. Then I take a series of measurements, all from the door and wall, and put it all into an Excel spreadsheet that automatically calculates reach, stack, saddle height from BB, saddle setback, handlebar drop, handlebar reach, etc.
I did run into issues with a couple bikes from the 1980s that I acquired. I've been using 175mm cranks since the mid-90s, but they have 170s. That took a bit of experimentation. I ended up, unsurprisingly, with about 5mm higher saddle height on those before they felt 'right'.
But, yeah, set the saddle height and setback first and leave it while you bring the bars to the right place.
Likes For genejockey:
Quoted: 4400 Post(s)
Liked 4,849 Times
Unless you are using the same saddle I wouldn't go off this measurement alone for reach as saddle nose length can vary a lot between different saddle models - easily an inch or more. So I find it better to measure from the back of the saddle as with most saddles you tend to sit in a similar position relative to the back rather than the nose. At least check the length of both saddles you are comparing to see if there is a big difference. Different saddles make this measurement quite tricky to get right.
Likes For PeteHski:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Otto
Quoted: 7652 Post(s)
Liked 3,473 Times
If the OP knows how to set up his/her bike because the bike is set up correctly, and just wants his new bike to fit the same .... then it doesn't matter in which order he adjusts things.
All s/he needs to know is the relation in space of the various contact points relative to the BB and each other, and s/he can duplicate that relationship on any other bike with a similar-sized frame.
If the OP truly doesn't have a clue then we will need seven ages of detailed instructions, interspersed with the OP going and making measurements and reporting back ......
Also, I think we have to assume that either the OP would be abler to make micro adjustments based on how the new bike feels, or we have to assume s/he is so ignorant that we could not possibly help him/her. For instance, if the new bike's bars and stem are a different shape and size, the OP would need to orient brifters based on measurements not based on the bars .... but either s/he is smart enough to just see this or too not smart to get it from a few hints.
I would probably suggest something like @genejockey suggests, taken to an extreme----get an old carboard bike carton or similarly big box, and use one side as a backdrop and out of the other cut a giant protractor and right triangle. Get a plumb bob (which is a big nut on a string) and a carpenter's level and a tape measure, and lay things out in three dimensions---top of the saddle center (where the projected seat post would hit the top if it stuck right through) to the center cap, to the junction of the bars and stem, to the bases and the tops of the brifters .... and the angles side-to-side and up-and down for those measurements,. Top of the saddle center to the pedals at farthest extension, to the center of the BB .... angle of the bar tops, angel of the brifters off center and off the bars .... whatever the OP might need to transfer the parts so they have the same relationship in space.
I wouldn't worry about the position of the cleats on the pedals unless I was using different shoes, cleats and pedals, or I was planning to use different legs and feet. I try to use the same pedals on all my bikes so I don't have to mess around much but I do have two- and three-bolt bikes, a couple of each. Either way, the cleat position is pretty much the same, and pedal stack is within a few millimeters .... and if they are different cleats, shoes, and pedals, i am going to need to experiment to see exactly where I need the cleats based on that new combination, and I cannot figure out where the cleats are going to go if I don't know where the saddle is .... maybe you guys ride standing? Otherwise the ball of my foot and the length of my leg don't change positions much, so if I can get the seat set, minor cleat adjustments are easy.
But .... if the OP rides some, s/he will get all this and if not .... we should send the OP to either the Fitting your Bike page (https://www.bikeforums.net/fitting-your-bike/) or to YouTube to learn bike basics.
Quoted: 3949 Post(s)
Liked 7,295 Times
Liked 3,473 Times
Liked 7,295 Times
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Measure to the widest part of the saddle. Some saddles have heart shaped backs, some have tapered backs, etc. but most saddle are designed to have your sit bones at about the widest part.
It's like riding a bicycle
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I think the OP has the correct order... or at least a correct order.
Liked 4,849 Times
Yeah I like that idea. It is a tricky measurement to get right when comparing bikes with different saddle shapes and lengths. Measuring from the saddle nose to the bars only works if you are comparing fit with exactly the same saddle.
Likes For PeteHski:
Advanced Slacker
Liked 2,537 Times
Yeah, different saddles would throw a wrench into things.
