Pictures of your loaded rigs?
Old 08-27-21, 04:49 PM
  #4576
mgopack42
Bikes: 2020 Argon 18 Krypton Pro, 1985 Masi 3V Volumetrica, 3Rensho Super Record Aero, 2022 Trek District 4.
Quoted: 343 Post(s)
Liked 424 Times in 206 Posts
4 water bottles, Handle bar bag, stem mount feed bag, 2X fork bags, top tube bag, and triangle frame bag. Still exploring options. handlebar bag and feed bag for photgraphy equipment.
mgopack42 is offline
Old 08-29-21, 11:51 AM
  #4577
RayLee
Bikes: YT Izzo, Privateer 161, Carbonda 696, Mason InSearchOf, cheap SC High Ball knock off
Quoted: 20 Post(s)
Liked 8 Times in 5 Posts
light weight set up
first time using smaller "bike packing" bags because I could fairly easily find stores and even a hotel if something failed from DC to Pittsburgh via the C&O and GAP trails... ended up working even better than expected with the unplanned PawPaw tunnel detour, I was able to ride up a fair amount of it and all the way down.
Did not have as much time as I would have liked and managed to do it in three and a half days so I had plenty of time to cruise around my old hometown of PGH
RayLee is offline
Likes For RayLee:
Old 08-30-21, 12:11 PM
  #4578
matkyne
I've got the same Ibera system and really like it.
matkyne is offline
Old 09-01-21, 07:05 AM
  #4579
djb
Quoted: 2737 Post(s)
Liked 970 Times in 793 Posts
Originally Posted by Coilavana
that red bag on the front wheal look amazing and dangerous at the same time! Insane
What red bag?
djb is offline
Old 09-01-21, 02:41 PM
  #4580
str
Quoted: 272 Post(s)
Liked 487 Times in 236 Posts
str is offline
Likes For str:
Old 09-06-21, 12:40 AM
  #4581
nuxx
nuxx's Avatar
Bikes: S-Works Tarmac SL6, Custom Carbon Flatbar, Giant XTC Composite 29er, Trek FX 7.6
Quoted: 47 Post(s)
Liked 42 Times in 18 Posts
Tailfin
Packing light for a short trip. This Tailfin system is rad.
nuxx is offline
Old 09-11-21, 06:29 AM
  #4582
Quoted: 18409 Post(s)
Liked 15,520 Times in 7,324 Posts
Outside the train station in Philadelphia. Off to St. Albans, VT to start a ride home.
Likes For indyfabz:
Old 09-17-21, 05:30 PM
  #4583
JaccoW
Overdoing projects
JaccoW's Avatar
Quoted: 784 Post(s)
Liked 1,238 Times in 686 Posts
My setup for this summer (left bike). I carried way too much stuff in hindsight but with 45L (17L + ~5L + 23L) I could probably carry camping gear as well.
I guess that's something I will try to fit inside some time in the next couple of weeks.
JaccoW is offline
Likes For JaccoW:
Old 09-17-21, 05:37 PM
  #4584
antmaster5000
Bikes: BMC TeamMachine, Surly Pacer, All City Big Block
Quoted: 92 Post(s)
Liked 62 Times in 30 Posts
Really cool setup! How do you like those bars? The drops look pretty unusable but the hoods look very comfy. I'm intrigued. Also very cool drivetrain. Big ring and a very small ring.
Also what's that lever on the seat tube for?
antmaster5000 is offline
Likes For antmaster5000:
Old 09-17-21, 05:45 PM
  #4585
JaccoW
Overdoing projects
JaccoW's Avatar
Quoted: 784 Post(s)
You would think so right? But no, they are flared bars and those flat portions are really comfortable. They originally came off a Koga Beachracer but they serve as gravel bars as well. They are essentially the same as the Velo Orange Dajia Cycleworks Far Bar but also made by Satori IIRC.
48/28 x 11-32 11-speed drivetrain. Works pretty well with the 11-speed Dura-Ace front derailleur to be honest. But it helps to use a chaincatcher. It's a big drop with a 20T difference. I think for the next iteration I might go for a 44/26T x 11-36T setup.
The lever on the seattube was for a bottom bracket dynamo. It would enable you to enable a special type of dynamo to roll against the rear tyre. Apparently it worked pretty well but fell out of favor when dynamo hubs became available.
JaccoW is offline
Likes For JaccoW:
Old 09-18-21, 11:06 AM
  #4586
tombc
Quoted: 44 Post(s)
Liked 63 Times in 28 Posts
tombc is offline
Likes For tombc:
Old 10-04-21, 04:38 PM
  #4587
KC8QVO
Bikes: Surly Disk Trucker, 2014 w/Brooks Flyer Special saddle, Tubus racks - Duo front/Logo Evo rear, 2019 Dahon Mariner D8, Both bikes share Ortlieb Packer Plus series panniers, Garmin Edge 1000
Quoted: 405 Post(s)
Liked 115 Times in 99 Posts
Originally Posted by tang1223
This is just ignorance with simple physics. The lower your center of gravity, the stabler is your ride. Not only does a heavy bag on the handlebar raises the center of gravity of the rig, the bag catches more wind and impacts the steering. This can be a serious problem with strong cross winds.
Weight/mass is what affects center of gravity. Not bulk/volume.
You can have a bulky bag on top with lighter stuff - like clothes, sleeping bag. If your weight is concentrated low this will still ride OK. Yea, the heavier your stuff "up top" gets the worse the handling is.
KC8QVO is offline
Old 10-09-21, 06:10 PM
  #4588
Bulette
Quoted: 84 Post(s)
Liked 97 Times in 49 Posts
Bulette is offline
Likes For Bulette:
Old 10-13-21, 01:25 AM
  #4589
CMAW
Pining for the fjords
CMAW's Avatar
Quoted: 130 Post(s)
Liked 444 Times in 150 Posts
Mini skinny tire tour to the French coast.
CMAW is offline
Likes For CMAW:
Old 10-14-21, 06:42 AM
  #4590
AeroGut
Quoted: 254 Post(s)
Liked 182 Times in 141 Posts
Obligatory campsite photo during an overnighter this week in Ohio. Apologies to the purists for being non-drive side. Briefcase panniers are a bit unorthodox, but I had one that I use for commuting and picked up a second cheap from a BF member, so I've never invested in regular touring bags. Helps to have extra capacity since my 25 year old sleeping bag and 2+ person tent aren't exactly compact. Bike is a late 90's Bianchi Boardwalk hybrid frame that I built up as a drop bar bike mostly with parts I could find at the co-op. Wheels are mismatched because the front has a dynamo hub and I got it used already laced to the rim, but with no matching rear.
Other details for anyone interested - drive train is 3x8 Sora with chainrings reduced to 26-39-50 (from original 30-42-52) and 12-34 rear cluster. Brakes are Tektro CR720s that stick out far enough that they're basically resting on the top of the front bags. Racks are Jandd Expedition racks from a BF member. Tires are 700x32 Panaracer Tourguard, which I've actually found to be disappointingly flat prone despite the name. Maybe just getting old. Pedals for this trip were some MTB platforms from Origin8, but I go back and forth between SPD and platform depending on my mood.
AeroGut is offline
Likes For AeroGut:
Old 10-18-21, 12:02 AM
  #4591
str
Quoted: 272 Post(s)
str is offline
Likes For str:
Old 10-18-21, 06:01 AM
  #4592
djb
We'll, at least for once you cleaned your damn bike before leaning it up against that beautiful wall!
tschus
djb is offline
Likes For djb:
Old 10-18-21, 06:08 AM
  #4593
Vermont to Philly last month.
Likes For indyfabz:
Old 10-18-21, 11:12 AM
  #4594
str
Quoted: 272 Post(s)
str is offline
Likes For str:
Old 10-20-21, 02:18 AM
  #4595
CMAW
CMAW's Avatar
Quoted: 130 Post(s)
You're packing a tent plus sleeping gear in that rando bag, str ? Fairly spartan set-up for 10 days.
CMAW is offline
Old 10-20-21, 03:19 PM
  #4596
str
Quoted: 272 Post(s)
in the seatbag is the sleeping bag and tools. in the frame bag is the tent (only the outer shell, I don't bring the inner tent anymore), tent pools, tent footprint, tent pegs.
Handle bar bag: 250ml propane gas, a cup for tea, tea bags, cooker, off the bike clothing, underwear, rain jacket, down jacket, bag with chargers, cables, battery pack, 2 spare inner tubes,
head lamp, sleep mattress, second cycling jersey, second cycling underwear, knee warmers, arm warmers, 2 pairs of socks for off the bike, 2 Pais of socks for on the bike.
maybe I forgot something would not bring much more if touring 4 weeks.
str is offline
Likes For str:
Old 10-20-21, 11:50 PM
  #4597
CMAW
CMAW's Avatar
Quoted: 130 Post(s)
I guess that rando bag must be around 15 liter. Not sure if I would like to have most of the weight up front, though.
CMAW is offline
Likes For CMAW:
Old 10-21-21, 12:11 AM
  #4598
str
Quoted: 272 Post(s)
works fine, no problem, only light stuff in there. it is a Carradice Nelson Long Flap.
for colder days, and warmer clothing, warmer sleeping bag and mattress + food supplies this version:
str is offline
Likes For str:
Old 10-21-21, 04:26 PM
  #4599
SapInMyBlood
Enthusiastic Sufferer
SapInMyBlood's Avatar
Bikes: 2015 Specialized Roubaix, 2014 Salsa Fargo, 2013 Trek Remedy, 2014 Cannondale Synapse
Quoted: 124 Post(s)
Liked 311 Times in 107 Posts
What width are your drop bars?
And what have you also got in your panniers?
SapInMyBlood is offline
Likes For SapInMyBlood:
Old 10-22-21, 02:54 PM
  #4600
str
Quoted: 272 Post(s)
46mm Salsa Cowbell 2
setup for colder days:
pannier, warm sleeping bag, warm mattress, complete tent,
pannier, second set of cycling clothing. one set of clothing off the bike, including rain jacket and down jacket. cooking stuff, food, propane gas, off the bike shoes, long underwear for sleeping, underwear, thin towel.
str is offline
Likes For str:
